20 Most Recent Kohler Engines Command V-Twin Horizontal Engine with Electric Start 25 HP, 1 7/16 Inch x 4 29/64 Inch Shaft. Model: PA-CH730-0040 Questions & Answers
Is the small wire on the ignition module to ground out the ignition to stop the engine?
Yes most times except on systems with points. It be ungrounded except when you the ignition system killed.
12/21/2014 2:04:12 AM • Kohler Engines... • Answered on Dec 21, 2014
My Craftsman kohler 16-hp-OHV runs on full choke, but as soon as I back off choke it surges and dies. Is this an adjustment issue or something more serious?
sounds like the carb has a problem with one of the jets. You need to remove the carb and rebuild it.
5/9/2015 3:25:01 AM • Kohler Garden • Answered on May 09, 2015
Kohler engine 241 as no spark
there is a piece next to the flywheel tha has a magnet and grabs resistence that may need replacing. I had this happen on mine. call your local repair shop and ask. I found the answer to mine on youtube and replaced it in about an hour,
10/20/2014 4:04:50 PM • Kohler Garden • Answered on Oct 20, 2014
Spark and fuel but engine wont fire
Usually a solenoid or battery issue. may be the flywheel too. It does turn and the flywheel on top spins horizontally, yet it will not catch? if so then it may need a solenoid next to the flywheel which grabs resistence as the flywheel spins. cheap fix and on youtube.
10/20/2014 4:02:56 PM • Kohler Garden • Answered on Oct 20, 2014
0answers
Have no spark
Be the first to answer 3/17/2014 3:30:45 AM • Kohler Garden • Posted on Mar 17, 2014Be the first to answer
The Casino I work at
Working at a Casino: Since you haven't specified a particular question or topic about working at a casino, I'll provide some general information and potential areas you might be interested in: Casino Job Roles: Gaming/Dealers: This includes roles like blackjack dealers, poker dealers, roulette dealers, craps dealers, and more. These positions require specific skills and knowledge of the games they operate. Security: Casino security personnel ensure the safety of guests and employees, monitor for suspicious activity, and enforce casino regulations. Surveillance: Surveillance operators use cameras and other technology to monitor all areas of the casino and identify potential security risks or cheating. Food and Beverage: This includes roles in restaurants, bars, and other food service outlets within the casino. Customer Service: Casino hosts, cashiers, and guest services representatives interact with guests, provide information, and resolve issues. Management: Casino managers oversee various departments, ensure smooth operations, and manage staff. Aspects of Casino Work: Customer Interaction: Many casino jobs involve direct interaction with guests, requiring excellent communication and interpersonal skills. Fast-Paced Environment: Casinos are often busy and energetic, requiring employees to be adaptable and able to handle pressure. Shift Work: Casinos operate 24/7, so employees may work nights, weekends, and holidays. Regulations and Compliance: The casino industry is heavily regulated, and employees need to be aware of and adhere to various rules and procedures. Security and Safety: Security is a top priority in casinos, and employees play a role in maintaining a safe environment for guests and colleagues. Potential Areas of Interest: Career Development: Many casinos offer opportunities for growth and advancement within the organization. Training and Certification: Depending on the specific job role, training or certification may be required. Compensation and Benefits: Casino employees typically receive competitive wages and benefits packages. Challenges and Rewards: Working in a casino can be both challenging and rewarding, offering unique experiences and opportunities to interact with diverse people.
4/23/2024 9:46:10 PM • Garden • Answered 8 hours ago
Parts diagram for wall kennel pro model 8800
It looks like you meant 'Wahl', this is why upper case letters are important for 'proper names' because Spell check won't alter them. Here are the parts diagram and suppliers, including Wahl themselves. https://www.google.com/search?q=wahl+kennel+pro+model+8800+parts+diagram You can safely ignore the answer from the African Prince as he is just copying and pasting from AI Chat GPT4. ..
4/23/2024 9:17:53 PM • Garden • Answered 8 hours ago
I've a 5 litre garden pressure sprayer and it's not functioning properly. It is pumping pressure but then it's leaking it all out at top of the green handle.
Here are some steps you can follow: Check the Seals and O-Rings: Release the pressure: Make sure there's no pressure in the cylinder by releasing the pressure release valve. Unscrew the pump: Remove the pump to access the internal components. Inspect the seals and O-rings: Look for any damaged or worn-out rubber seals. Check the rubber seal at the bottom of the tube (where the plunger sits) and ensure it's in place. Examine the one-way valve (usually at the bottom of the tube) and clean it. Lubricate it with silicone grease. Lubricate the rubber washer on the plunger with silicone grease and reassemble it in the tube. Reassemble the pump: Put the plunger back into the tube and lock it with the handle. Test the sprayer: Pump it up and check if it maintains pressure without leaking. Inspect the Handle and Hose: Handle connection: Ensure the handle is securely attached to the cylinder. Hose inspection: Check the hose for kinks, twists, or blockages. Straighten out any kinks and remove debris that might be blocking the hose. Check the Nozzle and Wand: Nozzle adjustment: Adjust the nozzle to the desired spray pattern. Wand inspection: Examine the spray wand for clogs or obstructions. Lubricate O-Rings and Seals: Apply silicone grease to the O-rings, seals, and other moving parts to ensure smooth operation. Test the Sprayer: Fill the cylinder to the desired level (avoid exceeding the maximum fill mark). Screw down the pump firmly to create an airtight seal. Manually operate the pressure release valve to ensure it's working.
4/23/2024 5:45:51 PM • Garden • Answered 12 hours ago
2answers
Is weed membrane fabric any good for applying to stone driveway
Ensure the membrane is protected with sand before laying the stone to avoid piercing the membrane.
4/23/2024 12:28:45 PM • Garden • Answered 17 hours ago
2answers
What are the top advantages of online flower delivery services?
As a customer, the advantage is that I don't have to drive to the florist. Saves time and gas. I could make a phone call, but then I wouldn't see the available flowers.
4/23/2024 10:14:23 AM • Garden • Answered 19 hours ago
What is the transportation ring on a huskvarna chain saw
The transportation ring on a Husqvarna chainsaw is a small metal ring that is sometimes fitted onto one of the bolts when the saw is new. Its purpose is to prevent the chain from rotating during transportation or storage. If your chainsaw has this ring, you should remove it before using the saw. Keep it in a safe place so you can use it again if needed. If you're looking for more information about Husqvarna chainsaws, you can refer to the operator's manual for detailed instructions. https://www.manualslib.com/manual/3145215/Husqvarna-440.html
4/20/2024 9:45:09 PM • Garden • Answered 3 days ago
Kohler Engines Command V-Twin Horizontal Engine with Electric Start 25 HP, 1 7/16 Inch x 4 29/64 Inch Shaft. Model: PA-CH730-0040 Logo
1 questions posted
Top Kohler Garden Experts
Paul Bade
ADMIN Andrew
ADMIN Andrew
David Littlefield
Are you a Kohler Garden Expert? Answer questions, earn points and help others
View Most Popular
Kohler Garden
  • Kohler Garden
Most Popular Question
small wire ignition module ground out
  • Garden
