20 Most Recent
Riso EZ221 Digital Printer Questions & Answers
Cant clear e78 error code
CR set to wrong country code in Memory Switch - Setting no. 200 (machine model setting), needs to be "B"
Where can i download free service manual for
I found one here.http://code.google.com/p/rjournal/source/browse/branches/agpk/manual/RISO%2BTR1510%252C%2BTR1530%2BParts%2BList%252C%2BTechnical%2BManual%2BService%2BManual.zip?spec=svn185&r=185
Riso mz770
How to recover system error on a riso mz 770 e
Riso Error T01-520 Drum Stuck
T01-520 is not drum stick. All the All 520 errors refer to main motor lock/ motor limit sensor faults (T01 is fault that requires maintenance). Drum error is T01-520-520. In your case 520 is the problem code, not the area code.
It is not the drum stuck, it is the main motor because there is a fault.
Replacing drum won't help , since the fault concerns the main motor.
It would be useful to know if there is an area code after 520.
Print this out, and read here how to check new Riso codes.
Riso HC5500 S01-204 error
- Code: 001 S96
- Description:Power supply remote signal not connected The control signal cable for the ON/OFF control of the 24/38-VDC output is disconnected. The signal wire grounded inside the power supply unit has been pulled up by the IP PCB to detect the level.
- Code: 003 S97
- Description:38-VDC power supply voltage error A voltage drop is detected when a voltage drop is sensed by the IP PCB based on the signal resulting from dividing the 38-VDC resistance inside the power supply unit. The detection level is approximately 18 VDC. Voltage polling is conducted at 100-ms intervals by the IP-CPU. An error is detected when a voltage drop is sensed 10 times in succession (approx. 1 sec). No detection is performed when the interlock SW is open.
- Code: 004 S97
- Description:24-VDC power supply voltage error A voltage drop is detected when a voltage drop is sensed by the IP PCB based on the signal resulting from dividing the 24-VDC resistance inside the power supply unit. The detection level is approximately 11 VDC. Voltage polling is conducted at 100-ms intervals by the IP-CPU. An error is detected when a voltage drop is sensed 10 times in succession (approx. 1 sec). No detection is performed when the interlock SW is open.
- Code: 006 S97
- Description:3.3-VDC power supply voltage error A voltage drop is detected when a voltage drop is sensed in the 3.3-VDC power supply on the MIP side of the IP PCB. Voltage polling is conducted at 100-ms intervals by the IP-CPU. An error is detected when a voltage drop is sensed 10 times in succession (approx. 1 sec).
- Code: 007 S97
- Description:1.8-VDC power supply voltage error A voltage drop is detected when a voltage drop is sensed in the 1.8-VDC power supply on the MIP side of the IP PCB. Voltage polling is conducted at 100-ms intervals by the IP-CPU. An error is detected when a voltage drop is sensed 10 times in succession (approx. 1 sec).
- Code: 008 S96
- Description:Control panel not connected The absence of the control panel unit to be connected to the MC PCB is detected. Since this configuration lacks this panel, this error indication will not be issued under normal operating circumstances.
- Code: 009 S96
- Description:Print counter not connected The absence of a print counter is detected.
- Code: 011 S96
- Description:CIS PCB not connected The connection of the CIS PCB cannot be confirmed.
HP Printer Support Phone Number 1 850 610 1013 HP Support Assistant
Riso error codes S35-2079-2
This indicates a problem with the cyan ink detection sensor. It can be reset temporarily in test mode with code 1534, but that may well not fix the cause of the error in the cyan ink supply.
Riso printer 390 u a01 -211 error message
I found a small sliver of a cut master inside the master feed assembly. Once it was removed, the machine worked fine. It was hard to locate,but if you remove 2 gold screws from the top of the master feeder you can gain access to the area.the screws are just below the coil springs for the master assy. lid.
