20 Most Recent Transmission & Drivetrain for Jaguar XF Questions & Answers
Jaguar transmission fault
Go to http://www.jaguarforums.com/forum/xf-xfr-x250-44/ and do a search for the codes you are getting, or the specific problems you are having. Consider joining this forum, they can answer ALL questions you may have now or in the future about the car, and are really nice folks! (and to answer this question as asked: Yes, the transmission on a Jaguar usually is the fault!) Your Jaguar is a World-Class Motorcar. Do NOT drive it like it is a Sportscar, it ain't. The very first thing you will "munch" will be the transmission if you do. I know, I learned the hard way. My Jag was over ten years old when I had to replace the transmission. That alone set me back over seven-and-a-half thousand dollars. Even though your car can likely go over 150 mph, take your time getting to high speeds. "Goosing" it is the #1 tranny killer. (The other killer is the 150 mph. at that speed, if you can take your foot from the gas pedal to the brake pedal in 3/4 of a second, you will have traveled 165 feet before you even start stomping down on the brake!) See ya in the forums! Bruce.
7/28/2014 5:28:27 AM • Transmission &... • Answered on Jul 28, 2014
Transmission rumble between 70/80 mph
Ussually pending tire ratings, it is the tire of wich is only balanced for certain speeds up to 80 mph. Have it balanced for 105-125 MPH of wich will resolve the problem. Z rated tires will be easier to balance for this speed. So take it to your local tire shop. If the problem somehow prersists, check your half shafts coming out of the tranny to the wheels. Their joints might already be worn out and need replacing.
1/5/2011 10:52:25 PM • Transmission &... • Answered on Jan 05, 2011
My dash lights dont work
Check your fuses. Also check the control knob for your headlights. If you turn the knob, it usually controls the dash lights.
1/28/2016 1:40:23 PM • Jaguar Vehicle... • Answered on Jan 28, 2016
Brake light
Typical Jaguar Dealership attitude. You didn't have them repair the collision damage, and they are punishing you. Great car, lousy dealer attitude. Go to http://www.jaguarforums.com/forum/xj-x308-xj8-xjr-27/ and do a search. If no help found, join the forum and post this question.
7/28/2014 6:30:56 AM • Jaguar Vehicle... • Answered on Jul 28, 2014
Turn off passenger airbag
Ahhh, you have the notorious Jaguar always-on passenger airbag light, too - eh? So do I. I "fixed" mine by covering the light with a spot of black tape. Go to http://www.jaguarforums.com/forum/ and search for the problem in the specific sub-forum to your car. That one is usually related to a bad ground to the passenger seat, or a loose wire under the seat, but it can be a myriad of things. You will find ideas and answers at the forum website if you search. Just reach up under the seat and start wiggling any and all the wires you find. More often than not, that will fixya! The Jaguar dealership will charge you an arm, a leg, and your first-born to effect the repair if it is not under warranty or recall. The folks at the Jaguar forum will charge you nothing to diagnose your problem and tell you how to fix it yourself, and do a better job.
7/28/2014 6:07:07 AM • Jaguar Vehicle... • Answered on Jul 28, 2014
Weak signal to driver back door centre locking not working
check for break in the wire were the wire goes into the door frame.
12/2/2013 8:23:55 PM • Jaguar Vehicle... • Answered on Dec 02, 2013
0answers
Telephone System in Jaguar Stype R
sounds like feedback form electrical system?
5/27/2012 9:09:28 PM • Jaguar Vehicle... • Answered on May 27, 2012
2001 Cadillac Deville Northstar Engine thermostat location
4.6 Northstar V8. It is located on the rear of engine (driver side) in front. It is in the the water pump housing cover. Remove air box and intake tube and bottom radiator hose. 2 bolts(believe 10mm) on thermostat housing. These systems are a little finicky about air pockets....so fill slowly and let run at idle until operating temp and let cool and check level.....fill as needed and repeat if needed.
3/28/2024 3:46:39 AM • Vehicle Parts &... • Answered on Mar 28, 2024
Peugeot expert central locking not working
A faulty central locking system might be due to several reasons, such as a blown fuse, faulty solenoid, or electrical wiring issues. Also, it's good to remember the fault might not be with the central car locking system but the key fob instead; over time, fobs require battery changes.
3/24/2024 2:38:44 PM • Vehicle Parts &... • Answered on Mar 24, 2024
3answers
What is hashtag
hash·tag noun
  1. (on social media sites such as Twitter) a word or phrase preceded by a hash or pound signand used to identify messages on a specific topic."spammers often broadcast tweets with popular hashtags even if the tweet has nothing to do with them"
    • the hash or pound sign (#)."Hunt mistook an @ for a hashtag while tweeting derogatory thoughts about him"
2/25/2024 9:46:45 AM • Vehicle Parts &... • Answered on Feb 25, 2024
Manual for XT-90LCD-autopage auto start
Yes
12/20/2023 6:51:49 PM • Vehicle Parts &... • Answered on Dec 20, 2023
Dynamite autopower DP-300 will not fully recharge no matter how long I leave it on the charger does not go above low charge
Hi, You need to check the output on the charger first, with a meter. Let me know and we will go from there.
10/22/2023 10:19:36 PM • Vehicle Parts &... • Answered on Oct 22, 2023
1944c Furuno radar array won't spin 7 years old. Just beeping
It seems like you're dealing with a technical issue related to a Furuno radar array. If the radar array is not spinning and is emitting a beeping sound, there could be several possible reasons for this problem. Here are a few steps you can take to troubleshoot the issue:
  1. Check Power Supply: Ensure that the radar array is receiving proper power. Check the power cables, connections, and any fuses that might be relevant. Make sure the power source is functional and providing the correct voltage.
  2. Inspect Mechanical Components: If the radar array won't spin, there could be a mechanical issue with the rotating mechanism. Check for any obstructions or debris that might be preventing the rotation. Lubricate any moving parts if necessary.
  3. Connection and Wiring: Examine the connections between the radar array and its control/display unit. Loose or damaged cables could cause communication problems and result in the array not spinning. Ensure all connections are secure and undamaged.
  4. Software and Configuration: Sometimes, software settings or configuration options can affect the operation of the radar array. Check the user manual or documentation to ensure that the radar is properly configured. Try resetting the settings to default and see if that resolves the issue.
  5. Error Codes or Messages: If the radar is emitting beeping sounds, it might be indicating an error condition. Refer to the user manual or any accompanying documentation for a list of error codes or messages and their meanings. This could help pinpoint the problem.
  6. Contact Support: If you've tried the above steps and the issue persists, it might be best to contact Furuno's customer support or a qualified technician for further assistance. They can provide more specific guidance based on the model of your radar array and the symptoms you're experiencing.
Remember, working with electronic equipment requires caution to avoid electrical hazards. If you're not comfortable troubleshooting the issue yourself, it's always a good idea to seek professional help.
8/9/2023 10:12:59 AM • Vehicle Parts &... • Answered on Aug 09, 2023
Transmission & Drivetrain for Jaguar XF Logo
3 questions posted
Top Jaguar Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Denis Houle
Are you a Jaguar Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Jaguar Vehicle Parts & Accessories
Most Popular Question
jaguar transmission fault
  • Vehicle Parts & Accessories
