20 Most Recent
Vizio E600i-B3 60" Full HD 1080p 120Hz Class LED Smart HDTV Questions & Answers
How do I fix a Vizio TV, model E600i-B3, SN LFTRPUBQ2804782.
All of the on-screen menu settings can be reset to the factory defaults.
If you restore the TV to the factory default settings, all changes you have made to the settings will be lost!
This includes any V.I.A. Plus Apps that you have added and any changes you have made to the settings for those Apps.
To restore the TV to its factory default settings:
1. Press the MENU button on the remote.The on-screen menu is displayed.
- Use the Arrow buttons on the remote to highlight System and press OK.The SYSTEM menu is displayed.
- Highlight Reset & Admin and press OK.The RESET & ADMIN menu is displayed.
- Highlight Reset TV to Factory Defaults and press OK.
- If you have changed the default parental control passcode,
enter it now.
The TV displays,"Select Reset to restore all TV settings to factory defaults and clear all account information."
- Highlight Reset and press OK.
- Wait for the TV to turn off. The TV will turn back on shortly afterward and the Setup App will begin.
If you dont have the manual for this model, one can be found here: http://www.brandsmartusa.com/pdfs/manuals/20184183.pdf
Vizio all in one computer VIZIO CA-27 voltage and part number for subwoofer/power supply replacement
The power supply/subwoofer for the VIZIO CA-27 series all-in-one PCs is identified by the part number 715G6960-P02-001-002S or ADTVE1825AC71. The power supply connects to the motherboard via a proprietary dual jack Audio/Power cable. I couldn't find specific voltage details for the subwoofer/power supply in the available resources. For precise information, I recommend checking the user manual or contacting VIZIO customer support directly.
Why is my Vizio TV stuck on mute.
The one logo is coming from the set top box that is supplying the signal, cable box, satellite box, Android box etc. Look for Mute on that remote, or cut the power to all your devices by removing the wall plugs. Wait 15 minutes and plug back in.
How do I fix a Vizio TV?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Vizio E50-C1 power on light is on but can't turn off. No picture or sound.
You have a balling issue with the main CPU IC, you can try baking the board in the over, it's possible you will get it to work again for a while doing that, see youtube vids on baking a main board in the over for how to do it. The correct way to fix the TV is replace the main board, here is a listing for a board, stay away from ebay on buying TV parts. https://www.shopjimmy.com/vizio-756txfcb02k0450-main-board-for-e50-c1-ltc6skar-serial/
