20 Most Recent Toshiba 50 Class 1080p 120Hz LED Smart HD TV - 50L3400U 50 to 59 in Questions & Answers
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Toshiba 50 Class... | Answered on Dec 01, 2016
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Toshiba 50 Class... | Answered on Nov 19, 2016
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Toshiba 50 Class... | Answered on Aug 25, 2016
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
Toshiba 50 Class... | Answered on Feb 16, 2016
Go into menu settings of tv and look to see if the energy saving box is ticked.this is usually designed to run by selection of user not by default from factory.you may even have an intelligent saver which can detect if the screen is using a lot of power when the image is predominantly white as opposed to black so it turns the brightness down.too clever for its own good!
Toshiba 50 Class... | Answered on Nov 17, 2015
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Toshiba 50 Class... | Answered on Apr 12, 2015
You should set it up with the set-up codes to Toshiba brand TVs. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes used for devices too are given, in the order of device brand name list in alphabetical order. Do a search by type in the brand name of your device, at its search box, and press "Enter". Or, pull up older posts.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Toshiba 50 Class... | Answered on Jul 19, 2014
I plug headet in the service use only of my TV toshiba model 24HV1OE and something went wrong .what should I do to fix it?
Toshiba... | Answered on May 18, 2019
Hi Daren, it's a very strange fault, the one you mention
I sent you a link that talks about a similar failure on a Toshiba TV
I hope it will help you and you can solve the problem
But I suggest you look for a specialized technical service
Greetings Franco Dosil
Hola Daren, es una falla muy extra?a, la que comentas
Te envio un link que habla de una falla parecida en un televisor Toshiba
Espero te sirva y puedas resolver el problema
Sino te sugiero busques un servico tecnico especializado
Saludos Franco Dosil
Toshiba... | Answered on May 16, 2019
If the current firmware in your blu-ray player supports multi region then try this.
1. Power on the blu-ray player.
2. Press "Setup" on the remote to enter Setup Menu.
3. Using the remote, enter "8520". A new submenu will appear.
4. Set DVD region code to "0" for DVD Multi Region.
5. Set BD region code as required using the remote buttons.
"1" = Region A, "2" = Region B, "4" = Region C
6. Press "Setup" button to exit the menu.
If this does not work then try upgrading the bluray firmware.
Search for Toshiba BDX2150 firmware and see if there is a newer firmware than the one you have installed.
Toshiba... | Answered on May 14, 2019
hi Cheryl.
Press the "MENU" button, select Prefer, highlight Parental Control and press the right arrow key or menu button to enter the PIN code entry screen. 0000 is the default password. When the correct PIN # is entered the Parental Control Menu opens and you can change your settings and PIN code here.
Changing the TV password
or read up some more at this manual.
Toshiba 19L4200U User Manual Forgotten Pin Code Changing Or Deleting Your...
or this one.
4 digit pin code for toshiba tv Google Search
Toshiba... | Answered on May 12, 2019
Hi Roy, I can not find the service manual for this TV,
Is it an overhead TV? if so, it would seem that it is out of alignment of the LCD cells
Try disconnecting all the TV's devices and see if the same happens when you put the menu?
It does not seem, a problem of interference, so it is observed in the photo
I await your comment
Hola Roy ,no encuentro el manual de servicio de este televisor,
Es un TV retroproyector? si es as?, parecer?a que esta fuera de alineaci?n de las celdas LCD
Probo desconectar, todos los aparatos del televisor y ver si ocurre lo mismo cuando pone el men??
No parece, un problema de interferencia, por lo se observa en la foto
Espero su comentario
Toshiba... | Answered on May 11, 2019
Toshiba 50 Class 1080p 120Hz LED Smart HD TV - 50L3400U 50 to 59 in Logo
12 questions posted
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
reset forgotten pin code using universal
  • Televison & Video
