20 Most Recent
Air Conditioning and Heat for Mitsubishi Eclipse Questions & Answers
When turn on AC the
sounds like a problem with a control module.need to take it to an A/C mechanic to check it out
Not colling well
or heavy machinery cars etc. luckily there are many websites
that can help you repair
for eg site like reliable-store is very active in this.. instant help, emails and all that's fantastic
Diesel engine fault finding fuse 14 keeps blowing
Isolate the circuit remove all devices from it but one, if that one does not blow the fuse, disconnect it, and reconnect another one in that circuit till you find the culprit.It's not always that easy, but good luck
How do i remove the front brake disk on a 96 pajero
The hub needs to be removed from the car the disc is held on by bolts through the rear of the hub. If you have no experience working on brakes I would recommend that you leave this to a competent workshop. It is quite involved and impacts on yours and others safety. (Read Life!)
How to remove rear rotor on 95 pajero
after you jack it up and remove the tire you then need to remove the caliper and brakes. then the rotor should just slide off sometimes it may need just a slight bump with a hammer on the backside
