20 Most Recent Samsung 7 Galaxy Tab 4 8GB White Questions & Answers
How do I delete photos in the gallery on Samsung Galaxy tab 4?
To delete a single image, summon the image on the screen and touch the Trash icon that appears in the upper-right corner. Choose the Confirm Delete command. The image is gone. Deleting a video isn't as easy as removing an image: You have to long-press the video thumbnail in an album. The long-press activates multiple-selection mode. For removing a video, however, just touch the Trash icon that appears in the upper-right corner of the screen. Choose the Confirm Delete command, and the video is gone. You can't undelete an image or a video you've deleted. There's no way to recover such an image using available tools on the Galaxy Tab. You can apply the Delete command to an entire swath of items in the gallery at once. To do so, you must know the secret, found below:
  1. Open the album (pile) you want to mess with.
  2. Long-press an image to select it. Instantly, you activate image-selection mode.
  1. Continue touching images and videos to select them.Or you can choose the Select All command.
  2. Perform an action on the group of images or videos.
To deselect items, touch them again. To deselect everything, touch the Done command. The type of commands you can use on a group of items in an album depends on the group. Some commands, such as Delete and Share, can be performed on any old group. Other commands, such as the image rotation commands, work only with pictures, not with videos.
5/30/2019 4:07:26 AM • Samsung 7 Galaxy... • Answered on May 30, 2019
4answers
How do i connect my tablet to my tv using a usb cord
you'll need a micro usb to HDMI adapter. But not all tablets support it.
2/9/2016 10:47:43 AM • Samsung 7 Galaxy... • Answered on Feb 09, 2016
I put an SD card in to get more storage and I don't know if it is acknowledging the card because when I want to download it still tells me that I don't have sufficient storage.
Unfortunately, the SD card in most tablets and cell phones doesn't get used efficiently. Most apps will not load onto the SD cards since the developers don't write the programs to run from them. Thus, you are limited to what's in the tablet or phone natively. The only thing the SD card does mostly is to allow you to store more pictures and video files. Some apps will put their data there, but you must direct them to do so in the app management menu. Until manufacturers put more memory in the devices or programmers write the apps for the SD card, that's the way things will remain.
2/5/2016 11:49:02 PM • Samsung 7 Galaxy... • Answered on Feb 05, 2016
Is a samsung galaxy tab 4 7.0 compatible with straighttalk ?
It depends on which model of the Galaxy Tab 4 you have. The unlocked Galaxy Tab 4 3G is compatible with the Straight Talk GSM network and has a SIM card slot. There is a Wi-fi only model which will only talk to a cellular network through a hot-spot device. I hope this helps. Cindy Wells
1/8/2016 12:49:35 AM • Samsung 7 Galaxy... • Answered on Jan 08, 2016
My tab beeps every 10 seconds when I disconnect the charger, stops beeping while on charge, and a lightening symbol flashes in the battery symbol ant the same time as the beep
Let it charge overnight. Dont use it while its charging for 8hours . Reboot it and try again
8/2/2015 5:43:09 PM • Samsung 7 Galaxy... • Answered on Aug 02, 2015
The touchscreen on my Samsung Galaxy tab 4 does not work sometimes, any suggestions?
You are probably at the beginning of a hardware failure. The screen may have been damaged by moisture or other mishap. You can take it to a mobile repair shop and see if they can do a test to see if the screen is fully operational.
4/14/2015 3:56:19 PM • Samsung 7 Galaxy... • Answered on Apr 14, 2015
0answers
Samsung 500T Tablet. How to hard Reset please?
Question edited for clarity. Question moved to Samsung Tablet. https://www.google.com/search?q=Samsung+500T+hard+reset Standard Android Reset
9/15/2023 1:59:05 AM • Samsung Tab... • Answered on Sep 15, 2023
Tablet problems with touch of the screen
let's start with the basics first in order to solve your tablet issue. Once we go that, we can move forward as necessary. I would recommend performing an antivirus scan on your device. You can search for "avast" or "malwarbytes" in your app store to get started. If that doesn't work, then you can perform a factory reset as described by Samsung here: https://www.samsung.com/us/support/answer/ANS00062842/ . You'll be advised to back up your files before performing the factory reset. Please let me know if this helped you or not.
10/17/2021 6:32:52 PM • Samsung Tab... • Answered on Oct 17, 2021
2answers
I need to obtain a user manual for my husband's Samsung Tablet A8 (he is 82 an needs explicit instructions)
try going google and typing in ---user manual for samsung a8 tablet-- if there is a manual available it will be in pdf version for download
2/1/2018 2:53:47 PM • Samsung Tab... • Answered on Feb 01, 2018
tip
How to make my tablet run faster
The cache on your Samsung tablet is designed to make things run smoothly. But over time, it can become bloated and cause slowdown. Clear out the cache of individual apps in the App Menu or click Settings > Storage > Cached data to clean all app caches with one tap.
Speed up a slow Samsung tablet - Which Computing Helpdesk
https://computing.which.co.uk/hc/en-gb/.../209878085-Speed-up-a-slow-Samsung-tablet Turn off or reduce animations. You can make your Android device feel snappier by reducing or turning off some of animations. You'll need to enable Developer options in order to do this. Go to Settings > About phone and scroll down to the System section to look for Build number.6 Aug 201411 tricks to make your Android run faster - Android Authority.
tablet running really slow Google Search
Samsung tab 4 8" can not open put new screen digitizer screen on still can't open
I don't know anything about a Samsung tab
1/7/2017 10:39:14 PM • Samsung Tab... • Answered on Jan 07, 2017
I cant get help cause you wont give me any. I have wasted almost an hour asking the same question over an over.
You would get better response if you ask just once and provide all the details available. For example, is the screen flashing blue, or another light? Exactly which model Samsung Tab E are you asking about? Have you tried contacting Samsung tech support?
12/1/2016 2:17:59 AM • Samsung Tab... • Answered on Dec 01, 2016
Why is this so hard to figure out? I am afraid of damaging it.
if its saying open it up to reset the battery..it means open it up and to take the battery out and put it back in. please let me know if this is what you are asking,or this is what its telling you to do.
12/1/2016 1:45:51 AM • Samsung Tab... • Answered on Dec 01, 2016
Samsung 7 Galaxy Tab 4 8GB White Logo
12 questions posted
Top Samsung Tablets & eReaders Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
Tab Samsung
  • Tab Samsung
Most Popular Question
ask password dont pasword
  • Tablets & eReaders
