20 Most Recent
Air Conditioning and Heat for Hyundai Tucson Limited Questions & Answers
What causes 2006 hyundai tucson AC faliert ?
Could be as simple as a blown AC fuse, but also could be low on Freon. Start the engine and turn on the AC, check the pully on the AC compressor is turning. If it is, neither is bad. If not, could be either of those.
Code p0700 for hyundai elantra 2010
looks like it's hard to get..
why don't u try online
some websites deal in it real time.. along with solutions to problems how to repair fix service nd all
Oil pressure switch leaking
Try tightening but be careful it can break..if sill leaking replace it..any auto parts store carry or can order them.not a bug job..good luck..
Replacing oil pan gasket
you gotta drain the oil then drop the oil pan clean old gasket off and oil replace the gasket and reinstall oil pan put oil back in and after checking the oil level or changing oil you are ready to go
Hyundai Getz misfiring
Have you diagnosed the car for error codes? Upon reading your question I first thought about the HT leads anp plugs. You replaced those. Next step is to suspect dirty (clogged) fuel injectors. Pour a whole bottle of a good fuel injector fluid into almos empty fuel tank. Then add ONLY 2 gallons (8 liters) of fuel. Drive car around like "you stole it". Try to floor it or fully accelarate in 2nd gear as mech as you can, revvin ebgine above 4000 rpms.
If there was any dirt, varnish or clog in any injector, this procedure should fix it in a day or two.
Still do get an error code diagnosis as soon as possible. You may be surprised about what sometimes comes up.
WHERE IS THE FUEL PUMP IN HYUNDA SONATA
It is inside the fuel tank. It is one of a three part assemby device that goes inside gasoline yank. This assembly is composed by the fuel filter, fuel pump and fuel level gauge sending unit.
It is serviceable ONLY by qualified mechanics under very specific safety conditions.
P0115
Engine Coolant Temperature Circuit Malfunction
Possible causes
- Low engine coolant level
- Faulty Engine Coolant Temperature (ECT) sensor
- Faulty engine coolant thermostat
- Engine Coolant Temperature (ECT) sensor harness is open or shorted
- Engine Coolant Temperature (ECT) sensor circuit poor electrical connection
Hi , I have a problem . Hyundai getz 1.3 the car
have you changed the plug leads. or the ds pack some engines have leads or a dispack. dispack the seals can go and cause arking. leads weak leads will sort out in them self and moving them about can reconect them. if they have gone hard they should be changed as that means they are brital.
Does Hyundai veloster have standard security system
The Veloster may or, may not have a manufacturer installed security system. However, what the salesman is trying to sell you is an aftermarket vehicle security system at an inflated price. The vast majority of new car dealers sell aftermarket alarms and remote starters that are installed by an outside company that has a contract with the dealership. These same systems are available at various shops at retail price. The dealership talks you into buying these products by telling you that if you buy it from someone else that your manufacturer warranty will be voided. This is not true. Read magnusen-moss warranty act. I know this because I was the in house installer at several new car dealerships, installing alarms. remote starters, dvd, back up sensors, navigation systems, stereos, etc. for over seven years.Now, with that being said, not all retail aftermarket shop are the same. Do your research. Read what others have to say about these companies before making a decision to have them install something on your nw vehicle.
Oil pan gasket hyundai what do i need
You need a floor jack. A jack stand or two, oil catch pan and probably a 15 millimeter socket (socket size may be wrong) and an oil pan gasket. Go to a parts store an let them know what vehicle you have and a replacement gasket should not be more than 20 bucks.
