20 Most Recent HP Officejet Pro 8610 Inkjet Multifunction Printer - Color - Plain Paper Print Automatic Duplex Print Questions & Answers
2answers
Printer showing missing or failed printhead
In Inkjet printers there is no separate print head as in dot matrix printers. They have, instead, tiny nozzles at the bottom of the ink cartridges. When and if they are choked, as can happen when they are kept unused for some time, then the printing will have missing portions. You can try to clean the nozzles using the printer software provided by HP. If this does not work then you will have to replace the cartridges. Even after this the problem is persisting then you will have to replace the data card - an electronic circuit board - inside the printer. You may also try to to uninstall reboot and reinstall the UB and printer drivers first, to rule out any problem from the software side.
10/24/2018 8:15:26 AM • HP Officejet Pro... • Answered on Oct 24, 2018
My printer won't print, it says it's disconnected but everything is plugged in. I rebooted my computer, unplugged everything and let it rest but it is still indicating "not connected"
So what is the connection ? USB or Wireless or Ethernet ? Did you try connecting though other ports ? Connectivity, standard
  • 1 Hi-Speed USB 2.0
  • 1 Host USB
  • 1 Ethernet
  • 1 Wireless 802.11b/g/n
see wireless setup shown in the below video at 24.34 minute mark HP Officejet Pro 8610 Unboxing Setup
3/16/2016 3:00:44 AM • HP Officejet Pro... • Answered on Mar 16, 2016
When printing labels (Avery 5160) the labels start being shredded half way through and then the printer jams.
Have you setted up in the printer driver to print on label? the printer will automatically adjust the internal parts for printing on a higher density paper! If you done it gently remove the Duplexer unit from the behind of the printer and chech for pieces of paper or everything could cause the paper jam! Hope you found it useful, for futher questions i'm here :)
12/17/2015 2:19:51 PM • HP Officejet Pro... • Answered on Dec 17, 2015
My printer is only printing one copy at a time
Your question is not clear. You mean it print only one page of a document with several pages? Guess you should unistall drivers, look for a more recent version of drivers in HP website and reinstall your printer
11/9/2015 2:15:26 PM • HP Officejet Pro... • Answered on Nov 09, 2015
Trouble faxing using a USB cable to connect to network. Is it the USB cable, or do I need Ethernet?
First, fax only works over a phone line. Network is for printing and scanning, not fax. USB is for connecting typically to a computer, not to a network...
5/6/2015 1:39:02 AM • HP Officejet Pro... • Answered on May 06, 2015
Photos have a line across the middle of the picture
Try to run alignment or clean heads features.
2/16/2015 11:48:09 PM • HP Officejet Pro... • Answered on Feb 16, 2015
How to print envelopes?
Adjust the paper feeder gear to envelope size, then print.
8/21/2014 3:40:55 PM • HP Officejet Pro... • Answered on Aug 21, 2014
How do I cancel set up details?
The printer can be deleted from control panel -> printer
6/29/2014 6:30:18 AM • HP Officejet Pro... • Answered on Jun 29, 2014
3answers
My hp deskjet 2300 printer is not printing. its says in the desktop it is printing
  1. Click and select. (Settings) > Devices > Printers & scanners.
  2. Select your product and click Manage.
  3. Click Printer properties.
  4. Select the Ports tab.
  5. Select the Enable bidirectional support checkbox and click OK.
Or else google for troubleshooting.
4/20/2024 11:06:50 AM • HP Office... • Answered on Apr 20, 2024
2answers
HP LaserJet Pro 500 color MFP M570dn. I have to wait for 10 minutes before it starts printing!
Question edited for a lot more clarity.Duplicate question deleted. Refresh page to see your question.This is likely to be a computer issue not a printer issue. Connect it to a newer laptop to test the theory.You can try a reset, but the issue is not known.https://www.google.com/search?q=hp+laserjet+pro+500+color+mfp+m570dn+won%27t+print+for+10+minutes..
4/16/2024 6:49:26 AM • HP Office... • Answered on Apr 16, 2024
2answers
HP Deskjet F2480 All-in-One Printer. How to find the IP address of my printer HP Deskjet F2480 series please?
Question edited for clarity 'make model (what it is)'.
Find the IP address for an HP printer
Hewlett-Packard https://support.hp.com > ish_6039801-6039767-16 Find the IP address for an HP printer ; HP Smart app: From the app home screen, click the image of your printer, and then click Network Information to find the . ..
4/14/2024 7:15:56 PM • HP Office... • Answered on Apr 14, 2024
2answers
HP LaserJet Enterprise MFP M631 stuck on initializing after trying to update the firmware. How should I fix it?
This video shows you how to fix initialization issues from firmware updates:
4/6/2024 7:51:44 AM • HP Office... • Answered on Apr 06, 2024
HP Officejet Pro 8610 Inkjet Multifunction Printer - Color - Plain Paper Print Automatic Duplex Print Logo
20 questions posted
k24674
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
  • HP Office Equipment & Supplies
Most Popular Question
printer showing missing or failed
  • Office Equipment & Supplies
