20 Most Recent
Pioneer DEH-2400F CD Player Questions & Answers
Were is the sub woofer
You should have two (or more) RCA plugs on the back of the deck that will act as pre-amp outputs for subwoofer and speakers.
Failing that, your wiring harness should have come with a wiring diagram that will let you know which is the subwoofer output.
Failint THAT, the deck itself should have a wiring diagram on the bottom or side telling your which wire is which.
And if that fails, Your deck may not have a subwoofer output. Just attach your sub to the amp pre-out like everyone else.
5/11/2011 11:50:49 PM •
Pioneer...
Answered
on May 11, 2011
I have a pioneer DEH
Normally the source button on the front panel control can be pressed on each time for the source tto change from radio- CD and AUX. Make sure that a signal is connected .
9/18/2010 11:26:17 AM •
Pioneer...
Answered
on Sep 18, 2010
How to change time on Pioneer Carrozzeria avic hrv22 it has only Japanese, that's what my car's audio/GPS system and, please, help me out with changing language to English and finding maps?Thanks!!
Changing the language and updating maps on a Pioneer Carrozzeria AVIC HRV22, which typically comes with Japanese language settings, can be a bit tricky, but it's possible. Here's a general guide:
- Locate the Settings: First, try to navigate through the menu to find the settings option. It might be represented by a gear icon or a wrench icon.
- Use a Translation App or Guide: If you can't understand the Japanese menu, use a translation app on your smartphone to translate the menu options. Alternatively, you can search online for a guide or manual in English for your specific model.
- Change the Language: Once you've located the settings menu, look for an option related to language settings (???? in Japanese). Select it and then choose English (or ?? in Japanese). Confirm your selection.
- Update Maps: Updating the maps might require accessing a specific section of the menu, typically labeled something like "Map Update" (????). Once you're in that section, follow the prompts to update the maps. This might involve connecting the device to a computer and downloading the updated maps from the manufacturer's website.
- Follow On-Screen Instructions: Throughout the process, pay attention to any on-screen instructions or prompts, even if they're in Japanese. Sometimes, the navigation buttons or layout might remain consistent regardless of the language.
- Reset if Necessary: If you accidentally get stuck or lost in the menus, there might be a reset button somewhere on the device. Pressing this button will restore the device to its factory settings, allowing you to start over.
If you find it challenging to navigate the menu or if the options are not readily understandable, you might want to seek assistance from someone who understands Japanese or consult a professional who specializes in car audio/GPS systems. They can guide you through the process more efficiently.
