20 Most Recent Nor-Lake KLB810CL Questions & Answers
Unfortunately, this model has had quite a few problems, because it is such a complicated refrigerator. Many times a shorted component that is connected to the Iceland main control board will affect completely unrelated items making it easy to chase your tail for hours. I would suspect the freezer thermostor - only because we have had to replace it many times in the past.
Suggest you go to the www.searspartsdirect.com and copy the electrical diagram and then verify electrical reading on the main PCB, to try to isolate the problem.
Nor-Lake... | Answered on Jan 26, 2012
There are a few companys that make temp chart recorders that are battery controled and you could get one of these and just put it inside the refrigerator, problem solved. Check at United Refrigeration, and Johnstone Supply they both have manufacturers that will allow you to keep charts. The 2 things to keep in mind 1 How often are you going to change charts, 2 what temperature range are you looking for.
Oh yes and Im sure there is a company that makes a remote sensed temp recorder that can tie into a computer and print out charts as needed. This is a little more specialized but I know the technology is asvailable. Probably Johnson or Penn Controls would know about this.
If this helps you in any way please rate me as high as you can. If you need to contact me and I can do the searching for you post back.
Nor-Lake... | Answered on May 29, 2009
Error Message
"Data Call Failure
Error Code : 67
Error Code 67 Registration Failure. Your PCS Vision username and/or password may be incorrect. Please try again."
This error message is an example of the error message you might have received. You may find that your computer is running slower than you first got it. After frequent use, you may also have system crashes or even blue screen of death.
We strongly suggest that you run a quick scan for error code 67 for your PC to check and fix the errors.
Buy Now (Only $34.95)
30-Day Money-Back Guaranteed
What Is Error Code 67? One thing you should know is that when you access the Internet, your system will have some access to the recourses of a remote computer. If the name of the particular network cannot be found, error code 67 will show up to your computer screen. And you will not be able to use the resources provide in the network.
Fix Error Code 67 Error Now! How to Fix Error Code 67? Sometimes, Windows error codes also indicate a faulty hard ware in your computer. It could be a hard ware that has not been installed properly. Or it could also be insufficient free space in your hard drive. When you receive error messages like that, you should go and check the condition of your hard drive immediately in case of further damages.
Now that you know what the causes of error code 67 are, you have to learn to fix the relating problems. To do this, you can take a look at the tips below:
  • Remove files you do not need from your hard drive. You might have stored files in your computer like movies, music or images that you have accessed for a long time. If you do not need these files, you should better delete them from yourcomputer. This will ensures the sufficient free space in your hard drive.
  • Uninstall unnecessary software and disable startup programs. If you have some software that you no longer need, uninstall them from your computer. Besides, too much startup programs will hinder the process of starting up of your system. You could check and disable the programs you do not need in startup.
  • Scan your system in a regular basis. If your computer keeps on giving you error messages and your system performs slower and slower, you should pay attention to the safety of your computer. Chances are that your computer has been infected by virus or Trojan that hinder the efficiency.
  • Clean your registry. If the registry of your computer is corrupt, you would also receive irritating error messages. So you should scan your registry, identify and fix all the errors in your registry.
Refrigerators | Answered 1 hour ago
The most likely causes are an evaporator fan not working or a defrost system failure. If there’s a layer of frost building up on the back wall of your freezer then you have a defrost problem and not enough cold air can get to the fresh food section. I would recommend getting a professional out to fix it. If you want to try to fix it yourself, look up “LG fridge not defrosting”.
Refrigerators | Answered 14 hours ago
If leaking from the back and outside of the box, you need to tighten the water line. If it is leaking water from inside the box , bottom front then you need to defrost the fridge and after you defrosted check that the fan or fans are operating when it's on and no more ice is left.
Refrigerators | Answered Yesterday
Nor-Lake KLB810CL Logo
0 questions posted
Top Nor-Lake Refrigerators Experts
Marvin
Marvin
David Emmel
David Emmel
Are you a Nor-Lake Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Nor-Lake Refrigerators
Most Popular Question
type refrigerant
  • Refrigerators
