20 Most Recent Aqua Vu Scout SRT Fishfinders Questions & Answers
Check your camera cable & 'FISH' camera for kinks,punctures, or tears. Reconnect the cable into the monitor. Have a nice day.
Aqua Vu Scout... | Answered on Jan 11, 2016
Check the battery voltage. It should read around 12 volts. I have the same unit that did the same thing. The battery voltage was down to 6.5 volts. That was enough to power the LED but not enough to run the unit. Once I used a known good battery everything worked fine. Good luck!
Aqua Vu Scout... | Answered on Feb 08, 2011
and what is your question?
Boating | Answered Yesterday
I would start with the carbs. Buy new carb kits with float for each carb and clean and rebuild them then change the fuel filter before starting it back up.
Boating | Answered on Oct 10, 2019
On some boats there is a manual handle to direct water to either wash down or livewell. If you hear a pump running, but no water in livewell, look for that manual handle in the hose plumbing.
Boating | Answered on Oct 08, 2019
Not knowing the engine manufacturer and horsepower it is still one of two items. Most of today's engines have an automatic oil feed if it is a two-stroke engine. The four-strokes have something similar, except it deals with maintaining a constant oil pressure for the engine and recognizes a low oil condition as well. Another potential issue is a restricted fuel supply going to the engine. Larger engines obviously, require more fuel. An air leak into the fuel line or a fuel restriction between the fuel tank and the engine can also cause alarms to activate.
Boating | Answered on Oct 06, 2019
Make sure you transducer is sitting level with the bottom of the boat. Follow the transducer cable down the line from where it plugs into your unit. There should be a tag on the transducer that says which model the transducer is. Go into "setup" in your settings and make sure the correct model of transducer is chosen.
Boating | Answered on Oct 03, 2019
Motor Guide Wireless Remote Pairing.
To pair a new remote, disconnect The trolling motor from batteries and re-connect. Then, within 10 seconds hold the + and - buttons until you hear a long beep indicating the remote has been paired.
I have one the New 115 Thrust and had the same problem.
This will correct your issue.
Walld"
Boating | Answered on Oct 02, 2019
Go to settings and either change the depth using the icon DownScreen/Down Imaging and turn off. Or go to com and follow Doctor Sonar on Facebook and read the tutorial articles on understanding sonar. Or google doctorsonar.com
Walld"
Yes you reprogrammed your unit to bottom depth.
Go to settings and use the arrow buttons until you get to the top of the unit. The menu will have several different settings you need to change the sonar settings. After you play around with all the different settings you will see what I'm talking about.
Walld"
Join the Facebook group 'Everything Boston Whaler'. It is the best resource, Jeff Rohlfing is the owner and personally vets every member. Tell him I sent you. He knows every model like an encyclopedia. Also 'Continuous Wave'.
I am pretty sure the only Jet Boat was called the 'Rage' and produced from 1996. The EBW group has a section called Files and a PDF lists models and years.
This should help you
Boating | Answered on Sep 30, 2019
Aqua Vu Scout SRT Fishfinders Logo
13 questions posted
Top Aqua Boating Experts
ray gallant
ray gallant
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you an Aqua Boating Expert? Answer questions, earn points and help others
View Most Popular
Aqua Boating
  • Aqua Boating
Most Popular Question
screen camera lite up but no
  • Boating
