20 Most Recent
LG Optimus Dynamic Black Smartphone - Tracfone microSD Slot, Android 2.3, 3 MP Camera Questions & Answers
Why does screen go black after call?
You need to disable the proximity sensor. The use of the proximity sensor is to detect if the phone is up to your ear during a call, to turn the screen off. However if there is debris on the sensor or even a screen protector over it, it constantly thinks it is up to your ear, hence blacking out the second you make a phone call.
You can go into settings and call settings to disable the proximity sensor. I’m happy to assist further over the phone at
https://www.6ya.com/expert/christopher_d13aca62d29ed9ae
How do I get my cell phone off accessibility setting It just talks will not let me do anything
I hope you got it figured out by now, but if not. The best advice I can give is to navigate your phone with your eyes closed. This setting is for people of no site to be able to use their phone as it tells them where to navigate. And by double clicking an item they can select what they choose. They can also double click, hold and drag to get to the wrap screens to the left or right for more options. I hope this helps.
Lg fb163-how to add bluetoth function
To add Bluetooth functionality to your LG FB163, you can use a Bluetooth adapter that is compatible with the device. Ensure that the adapter you choose is compatible with the FB163 model. Once you have the adapter, follow the instructions provided with it to connect it to your FB163 system.
To connect your Android phone to the FB163, you'll need a compatible cable. Typically, you would use an auxiliary (AUX) cable with a 3.5mm jack on both ends. Plug one end into the headphone jack of your Android phone and the other end into the AUX input port on the FB163 system. Then, select the AUX input mode on the FB163 to hear the audio from your phone through system.
How can I hatd factory hard reset my LG 265 if I don't have my pin # nomore or forgot it .
- Turn the phone off.
- Press and hold the Power/Lock key (on the right side of the phone) and the Down Volume key (on the left side of the phone) at the same time.
- When the Factory data reset screen appears, release both of the keys.
- Use the Volume keys to highlight Factory data reset, then press the Power/Lock key to confirm.
- Use the Volume keys to highlight Yes, then press the Power/Lock key to confirm one more time.
- Your phone will perform a factory reset.
Im locked out of my
WARNING : Performing a hard reset will remove ALL data including the Google account, system data, application data, application settings, and downloaded applications.
- With the phone off, press and hold the Home key, Volume Down key and Power button. When the LG logo appears, release only the Power button.
- Release the Home key and Volume Down key when the Android icon appears.
- Follow the on-screen instructions.
