20 Most Recent Lenovo BT820-US 2.0 Speaker System - 3 W RMS - Wireless Speakers Questions & Answers
I'm hearing buzz sound continuously n i'm unable
check audio settings and audio cables. Also the imput port could be at fault. try connecting the speaker cable using the port in the front of the computer instead.
12/12/2017 9:47:01 AM • Lenovo Audio... • Answered on Dec 12, 2017
tip
How to Fix a CD Player When It Won't Play
Although CDs are still the preferred method of audio distribution, CD players are quickly being phased out in lieu of MP3 players. If your old CD player stops working, it might be a little panic-inducing, but fear not. If the CD player turns on but does not play CDs, then the problem is not with the power cord or the circuity (which are generally more expensive to repair rather than fix) but with the lens. There are several troubleshooting steps that you can take to fix a CD player when it won't play.
Step 1
Remove excess dust from the CD player. Dust is the number one enemy of electronics, and it can corrode even the most resilient device. Make sure to dust in between buttons, knobs, power cord(s) and audio-out ports. Note: use a dry duster, as moisture will harm your CD player further.
Step 2
Use a disk-based lens cleaner to remove ground in dust or dirt from the CD player's lens. These lens cleaners look like a regular CDs, but have specially-made bushes on the reverse side that gently remove excess dirt from the CD-reading lens. Simply put the CD in your player, and press the "Play" button to clean the lens. Do not run the cleaner more than once, as excess brushing can cause scratches on the lens.
Step 3
Polish the lens. Use a glass or eyeglass cleaning solution and a lint-free cloth to gently polish the reading lens. Clean it by using a low amount of pressure and softly polishing the lens and its surrounding area using soft, circular motions. Do this for about a minute or two and then allow the player to sit for a few minutes before trying to play a CD. SOLVED Why won my computer read any CDs or DVDs Lenovo IdeaCentre K410 https://forums.techguy.org/threads/cd-wont-play.560139 Help some CDs won play on my computer Laptop won play dvds or cds My computer won play CD DVD etc anymore How To Fix No CD Errors How to Fix PC Errors cd won play Google Search
Lenovo H320 very slow
There are a number of possible reasons can cause your Lenovo H320 computer running slow than it used to, it is hard to identify just what might be dragging down its performance, let alone implement the necessary technical adjustments to fix it. So if you want to address the issues more easily, I'll recommend you try a Lenovo speed up software, available here: http://www.speeduplenovo.com/Good luck!
9/3/2012 1:45:43 PM • Lenovo Audio... • Answered on Sep 03, 2012
0answers
The computer turns on and
It sounds as though you have a faulty hard drive. The system recognizes that your hard drive has a problem, and is unable to correct it. Unforunately, there is a very, very low chance that you will be able to get any data off of the drive.
Contact Lenovo; if you are still under warranty, they will walk you through steps in order to determine if your hard drive truely is defective. They will also be able to replace your hard drive and reinstall the operating system at no charge.
If you are not under warranty, you will have to take your laptop to a local computer repair shop, or use a service such as Geek Squad, and have them replace your disk (for a price).
3/21/2011 11:50:00 PM • Lenovo Audio... • Answered on Mar 21, 2011
0answers
I've purchased recently a Lenovo
This isn't a hardware problem. Sometimes, it has to do with the jack of your headphone. These jacks looks the same but they have different heads. We have 3.5mm jack and 3.0mm jack. So try other headphones on the Lenovo G465 and see if there would be any changes.
If there is still no changes, then you can try the alternative;
On a typical laptop running Windows, left-click on the double chevrons of the "Show hidden icons" button in the Quick Launch toolbar at the bottom-right corner of the screen. This will display all your hidden quick-launch icons, and usually these will an include an icon of a speaker that launches the "Volume Control" utility.
If not, then you can also access the Volume Control utility from the Control Panel, via the "Sounds and Audio Devices" application. Simply launch that application, click on the "Volume" tab, and click on the "Advanced" button in the "Device volume" section.
In the Volume Control utility, click on the "Advanced" button near the bottom-left area of the window. Near the bottom of the advanced controls window, there will be a section labeled "Other Controls." Here you should see some kind of check-box option labeled something to the effect of "PC Speaker Mute." If you check that box and save your changes, the laptop's speakers will be shut off, but you will still be able to listen to any music or other sounds through your headset.
It's as simple as that. To cancel the shutoff, simply uncheck the box and save your changes. This method works for all versions of Windows still widely in use.
I hope you understand the above.
Good luck.
2/15/2011 7:36:37 PM • Lenovo Audio... • Answered on Feb 15, 2011
My cursor will not move
Is the computer frozen itself? If is solely the curser,you may need a new mouse. Try using a different mouse to see if you get the same occurence. If it is a wireless mouse , try to change the batteries.
11/16/2010 5:05:38 PM • Lenovo Audio... • Answered on Nov 16, 2010
Setting time on fmdott085 V398
All questions need clear 'make model (what it is)' first 3 words. https://www.google.com/search?q=fmdott085+V398 ..
4/17/2024 4:54:26 PM • Audio Players &... • Answered Yesterday
Openfit Shokz battery replacement?
Question edited for clarity, typo and CAPS. Question moved from Cars and Trucks category. Claim on the warranty irrespective of how long you have had them. They charge $180 but they cost them $20 to buy from China. Package them up and send them tracked and ask them to replace the batteries. How long is the warranty on AfterShokz? While we hope you never need it, all new Shokz purchased from authorized retailers come with a two-year warranty that begins on your date of purchase. Jan 11, 2019
How To File A Warranty Claim For Your SHOKZ Headphones
https://www.google.com/search?q=Openfit+Shokz+battery+replacement ..
4/16/2024 4:58:24 PM • Audio Players &... • Answered 2 days ago
My roadking rk4000 wont charge. I turn it off to charge it but there is no indicator light at all, any suggestions?
Are you using the charging cables that came with it? That is a type C. Are you securely attaching the charging cable? A loose connection would keep the battery from charging. If you had a low battery, you would see a red light. That you have no light at all suggests there is no charge left in the battery. I'm not sure the reset will work with no charge which is why you ought to check the cables first. But turn it off and then hold down the Multifunction button for 10 seconds to reset it. Then turn it back on and see what happens. If you can, test the charging cable on aother device. If you have another type C charging cable, try it, just to eliminate a bad cable. If these suggestions don't work, you may try the manufacturer's customer support.
4/16/2024 5:57:29 AM • Audio Players &... • Answered 2 days ago
Can f2100 remote work on my dishtv box?
The F2100 remote is not explicitly listed as compatible with the AerialBox T2100, I recommend using the remote that came with your AerialBox T2100 for optimal functionality. If you have any specific compatibility concerns, I suggest reaching out to Dish TV customer support for further assistance.
4/10/2024 6:11:44 AM • Audio Players &... • Answered on Apr 10, 2024
Zenith Allegro console stylus
I have the same model with the 8 track player, original manual, and original receipt dated 1975.
4/9/2024 1:32:47 PM • Audio Players &... • Answered on Apr 09, 2024
VIBE SOUND USB Turntable Model VS-2001-USBT. Where can I download drivers and application for it please?
Probably nowhere as this is an Amazon / eBay special so made in China. You should be able to go to Windows Settings, - Hardware and tell Winderz to find a compatible driver. https://www.google.com/search?q=VIBE+SOUND+USB+Turntable+Model+VS-2001-USBT+drivers ..
3/31/2024 1:46:10 AM • Audio Players &... • Answered on Mar 31, 2024
I'm looking for a manual to my IQ VOICE ORGANIZER
Hi I have a manual (and an IQ Voice organizer that I'm trying to sell). I would happily send you a pdf file of the manual if you contact me. Robert
3/30/2024 1:52:26 PM • Audio Players &... • Answered on Mar 30, 2024
Lenovo BT820-US 2.0 Speaker System - 3 W RMS - Wireless Speakers Logo
2 questions posted
Top Lenovo Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Lenovo Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Lenovo Audio Players & Recorders
Most Popular Question
stuck in safemode
  • Audio Players & Recorders
