20 Most Recent Hisense RS731N4AC1 Stainless Steel 562 l Fridge Freezer Side-by-Side Freezer, A Energy Rating Questions & Answers
How do you fix the bottom cover or plinth?
very possibly they are not actually screws but simulated. if you cant figure this out: CALL A PROFESSIONAL
1/3/2015 3:53:26 AM • Hisense... • Answered on Jan 03, 2015
Hisense americanfridge freezer RS731N4AC1. Can the doors be removed to fit through standard door frames.
yes the doors are always removable. Also you can open the door and swing the fridge till it will reach second door .Open second door and complete the chore
12/29/2014 9:20:13 AM • Hisense... • Answered on Dec 29, 2014
2answers
I bought hisense HR6TFF222 a month ago, and then week later there's a problem occurs on the fridge part (the lower section), it's not working very well, it's warm as in room temperature wh
Ive just had the same issue as the op with the same model fridge. The warranty center said to adjust the front level feet to elivate the front of the unit open both doors , defrost for 8-12 hours at least. This seems to be a problem in the colder months of the year. Once a full defrost has occurred level the feet again , and turn your fridge back on. Problem solved
4/25/2017 4:06:42 PM • Hisense... • Answered on Apr 25, 2017
2answers
When Should You Consider Copper for Water Storage?
Copper has anantibacterial effect. Studies recommend storing water in copper containers for several hours before consumption to maximize this benefit. Some research suggests 48 hours. perhaps explore dedicatedcopper water bottlesfrom reputable sources for optimal water storage. This refers to water, not juices.
4/15/2024 9:35:55 AM • Refrigerators • Answered Yesterday
I have a 1984 Norcold 8310 series RV refrigerator that isn't working. How can I troubleshoot it?
Question edited for clarity. Help and videos in the link. However it is 40 years old and has probably seen better days. There isn't much you can do if it needs refrigerant gas as you need a certified engineer. https://www.google.com/search?q=1984+Norcold+8310+series+RV+refrigerator+that+isn%27t+working ..
4/13/2024 5:04:34 AM • Refrigerators • Answered 3 days ago
3answers
Is it normal that the compressor is too hot too touch?
yes it is
4/9/2024 3:41:40 AM • Refrigerators • Answered on Apr 09, 2024
Question mark flashing next to temperature numbers
All questions need 'make model (what it is) first 3 words please. https://www.google.com/search?q=Refrigerator+Question+mark+flashing+next+to+temperature+numbers ..
4/6/2024 11:28:44 PM • Refrigerators • Answered on Apr 06, 2024
2answers
Freezer is over freezing resulting in the the fridge not cooling. model of fridge RS22DCMS water dispensing upright fridge freezer
Sometimes the timer jmalfunctions and the refrigerator will not go in to a defrost mode. Try unplugging it and defrost the refrig and plug it in again.
4/5/2024 9:37:23 AM • Refrigerators • Answered on Apr 05, 2024
2answers
Uline beverage fridge loose door handle.
Hi
You are right. The only way to repair this is by replacing the complete door assembly. If under a year it should be covered.
3/25/2024 5:55:15 PM • Refrigerators • Answered on Mar 25, 2024
Where is the defrost timer located in hisense upside down fridge freezer on model NO# HR6BMFF520S
The defrost timer in a Hisense upside-down fridge freezer, model number HR6BMFF520S, is typically located within the control panel or the refrigerator compartment. Here are the general steps to locate it:
  1. Check the Control Panel: Start by inspecting the control panel of the refrigerator. Look for any knobs, buttons, or switches that control the defrost cycle. The defrost timer may be integrated into this panel.
  2. Inside the Refrigerator Compartment: If you don't find the defrost timer in the control panel, check inside the refrigerator compartment. It might be located near the temperature control settings or the light fixture. You may need to remove any covers or panels to access it.
  3. Consult the User Manual: If you're having trouble locating the defrost timer, refer to the user manual that came with your fridge freezer. It often contains detailed diagrams and information about the location of various components, including the defrost timer.
  4. Contact Hisense Customer Support: If you're still unable to locate the defrost timer, consider reaching out to Hisense customer support for assistance. They can provide specific guidance based on your refrigerator model and help you locate the timer.
Once you've located the defrost timer, you can follow the manufacturer's instructions for troubleshooting or replacing it if necessary.
3/21/2024 2:20:27 PM • Refrigerators • Answered on Mar 21, 2024
2answers
Artic Air Commercial Freezer keeps freezing up. the drain tube, around the fan. It is only a few years old.
This is your freezer. https://www.google.com/search?q=Artic+Air+Model+AF49EX My advice is to check the defrost heater for efficiency and also for correct placement. You could also add an additional heater rod or heater blanket to the place where is freezes up. https://www.google.com/search?q=Artic+Air+Model+AF49EX+defrost+heater ..
3/17/2024 4:41:14 AM • Refrigerators • Answered on Mar 17, 2024
When I OPEN the refrigerator door, it starts cooling the freezer and refrigerator. When I CLOSE the door, it stops. How can this happen??
When you open the door, all the cold air tumbles out, so the fridge starts up to replace the cold air. As you close the door it is running, but you can't hear it. One it gets to temperature, it stops. It can sometimes do this is seconds. If it was truly stopped, everything would be defrosted in the freezer and everything in the fridge would be warm. ...
3/11/2024 3:07:29 AM • Refrigerators • Answered on Mar 11, 2024
How do I replace the boards in n'finity pro hdx 77-bottle wine refrigerator. Model BU-270D-A1
Remove all bottles and shelves from the unit. Unplug the power cord from the outlet and wait for the unit to cool down completely. Locate the screws that secure the boards to the back wall of the unit and remove them with a screwdriver. Carefully pull out the boards and disconnect any wires or connectors attached to them. Replace the boards with new ones and reconnect any wires or connectors. Secure the boards to the back wall with the screws and tighten them firmly. Plug the power cord back into the outlet and turn on the unit. Reinstall the shelves and bottles and adjust the temperature settings as desired.
3/10/2024 10:06:09 PM • Refrigerators • Answered on Mar 10, 2024
WHY IS MY SUB ZERO 611 RUNNING ALL THE TIME?
Condenser coils blocked with fluff. Door gasket leaking and letting the cold out. Loss of refrigerant gas. Faulty Thermostat / Thermistor. https://www.google.com/search?q=sub+zero+611+compressor+running+continuously ..
3/2/2024 7:03:26 PM • Refrigerators • Answered on Mar 02, 2024
Hotpoint Air Tech Evolution fridge freezer. You need a university degree to understand the temperature settings.
Yes, or you find a 12 year old child. In most cases they are already calibrated. You can ask the shop to show you how to adjust either are the showroom or in your home. Or phone Hotpoint Customer Support. There are a couple of videos in the link https://www.google.com/search?q=Hotpoint+Air+Tech+Evolution+fridge+freezer ..
2/28/2024 6:50:08 PM • Refrigerators • Answered on Feb 28, 2024
Hisense RS731N4AC1 Stainless Steel 562 l Fridge Freezer Side-by-Side Freezer, A Energy Rating Logo
2 questions posted
Top Hisense Refrigerators Experts
ZJ Limited
ZJ Limited
john h
Are you a Hisense Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Hisense Refrigerators
Most Popular Question
hisense americanfridge freezer
  • Refrigerators
