20 Most Recent
Orion Xtreme XTR15 Car Speaker Questions & Answers
I have older 15
If the speakers measure zero ohms, then the coil is shot. A speaker will not work if it has zero ohms. Replace the speaker. ALL speakers should read 4ohm, 8ohm or above. Zero means the coil wire is shoted. That there is no continuity.
Orion xtr15 to a american leagacy la 660 amp
your only choice is to run the amplifier at a 4 ohm mono load - this will not reult in the amplifier making much power.
Positive on sub to Positive on amp.
Negative on sub to Negative on amp.
This is your only possibility.
Adding a second sub in the same fashion will result in a 2 ohm load, and your amplifier will run at its rated potential.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Schematic diagram for Orion hcca 275r
+12V
Fuse '
(30A) '
Power LED
(Green)
-12V
(Ground)
This is a very basic diagram showing the power input, power LED, and the three output channels for the HCCA 275R amplifier. The specific wiring and connections may vary depending on the setup and configuration of the amplifier.It is important to note that working with electronics can be dangerous and any modifications or repairs should be done by a qualified technician. Additionally, it is important to refer to the manufacturer's manual or documentation for accurate and detailed information on the specific amplifier model.
What orion cobalt sub is good for this amp?
You do not have enough listed for specifics but you do need to match your sub with the amp from an ohm standpoint and a wattage standpoint. I am sure your amp can handle down to 4 ohms but may handle 2 ohms. Find that out and then check on the output wattage of the amp. A lot of people have separate amps for the sub itself and run the system off of another amp. Either way is acceptable.
