20 Most Recent
Xerox WorkCentre 432 ST Copier Questions & Answers
U3-3
I think u3 is fuser code. YOu can check this by opening front cover. Look on dorr and you will see a plastic "finger" sticking oout from the door. oposite this will be a slot that the finer slides in. Find a popsicle stick and GENTLY insert it in the slot until you hear movement, then look to the left side and a light should go on. if not you should see the u3 momentarily. If you do this means that the fuder lamp is out. the fuser lamp heats the roller that melts toner into the paper as the copy comes out the machine. If you see the light thenit is an optics movement or lamp problem.
It could be a thermo fuse fuser lamp or control board(not real likely). Before I can tell you how to furthe check it or replace the parts, I need to know your technical level.
Machine does not start
You probably have a bad power supply 105K17807.
This is probably something you will hire a technician for unless you are very handy.
Whit
Item, Inc.
I bought a 432 dc
The 432 DC is sold as a stock standard copier. If you want to connect it to a network then you have to purchase the upgrade option to have a network card fitted
Contact your seller to arrange for this option
Thanks for using FIXYA
