20 Most Recent Xerox WorkCentre M123 Copier Questions & Answers
2answers
My Xerox cpoier # 604P1837
I would think you could fix it by turning the machine off , disconnecting all the cables from the scanner and document feeder, then reconnecting them tightly. Turn back on, If not here is the info on the fault.
At the adjustment of CCD output after power on, CCD does not make a correct output which it should when it receives a specified amount of light.
arrwup.gifInitial Action
  • Refer to BSD 6.3.
  • Power OFF/ON
arrwup.gifProcedure Check the lamp, lens, mirror and the white correcting plate for abnormalities such as contamination and deterioration.
Abnormality such as contamination or deterioration of the lamp, lens, mirror or the white correcting plate is found. Yes No Unanswered
Replace the lamp, lens, mirror or the white correcting plate.
Execute Component Control[062-002 IIT Exposure Lamp].
The Exposure Lamp ( PL 11.6) lights up. Yes No Unanswered
Check the connections of P/J703, P/J702 and P/J723.
P/J703, P/J702 and P/J723 are connected correctly. Yes No Unanswered
Connect P/J703, P/J702 and P/J723.
Check the wire between J702 and J723 for an open circuit or a short circuit (BSD 6.3 Flag 4).
The wire between J702 and J723 is conducting without an open circuit or a short circuit. Yes No Unanswered
Replace the Lamp Wire Harness ( PL 11.6).
Measure the voltage between the IIT/IPS PWB ( PL 11.3) P723-1 (+) and GND (-), and between P723-2 (+) and GND (-) (BSD 6.3 Flag 4).
The voltage is approx. +24VDC. Yes No Unanswered
Replace the IIT/IPS PWB ( PL 11.3).
Replace the Exposure Lamp ( PL 11.6). If the problem persists, replace the Lamp Ballast PWB ( PL 11.6). if the problem persists, replace the IIT/IPS PWB ( PL 11.3).
Check the connections of P/J700 and P/J710.
P/J700 and P/J710 are connected correctly. Yes No Unanswered
Connect P/J700 and P/J710.
Replace the CCD PWB ( PL 11.4). If the problem persists, replace the IIT/IPS PWB ( PL 11.3).
2/25/2023 6:26:54 PM • Xerox WorkCentre... • Answered on Feb 25, 2023
How to solve error of fuji xerox document centre
How to solve error code 012-284 fuji xerox ap-II 6000
1/21/2014 11:41:00 AM • Xerox WorkCentre... • Answered on Jan 21, 2014
0answers
0answers
0answers
0answers
What stands for 'OTSC'
OH THAT'S SO COOL (OTSC)
8/17/2011 12:17:17 PM • Xerox WorkCentre... • Answered on Aug 17, 2011
C123 convat to128
Would be easier and cheaper to buy a new machine. You have to replace a ton of parts that would cost a more by piece then to buy a new machine. The only advantage is 5 pages per minute. Zero different features.
5/21/2011 2:27:07 AM • Xerox WorkCentre... • Answered on May 21, 2011
I have a WorkCenter XD105F
There are two possible cause of this, either the fuser assembly may be damaged or at the end of its life. The solution is to replace the fuser assembly. Repairing a fuser assembly is generally not recommended because the fuser is considered a consumable printer part and not worth the time or effort to fix. Second, the toner cartridge may be defective and letting too much toner out at one time, the solution is to replace the toner cartridge.
Take care.
8/11/2010 4:23:14 PM • Xerox WorkCentre... • Answered on Aug 11, 2010
Trying to change paper size from A4 to 8.5x11 on a
  1. Pull out the paper tray.
  2. If necessary, slide the paper tray edge guides so that the guides are open.
    1. To adjust the side and rear guides, pinch the guide lever on each guide and slide the guides to their new position.
    2. To secure the guides in position, release the levers.
  3. Load the paper against the left-hand side of the paper tray. Paper can be loaded either short edge feed or long edge feed.
  4. If necessary, slide the paper edge guides so that they just touch the edge of the paper stack.
    NOTE: When loading standard size paper, set the edge guides onto the notches on the paper tray to match the paper size.
  5. Close the paper tray.
  6. Set the machine to detect the paper size automatically, or manually specify the required size.
    NOTE: Paper sizes detected by the machine vary depending on the Machine Administrator setting. See the Related Items below for additional information.
  7. If the type of paper has changed in the paper tray, then the paper type must be changed on the Control Panel as well. See the To modify the paper type on the Control Panel section below.
Normally just the guides need to be set correctly in the paper tray, The tray size sensing switched may be bad or the actuator on the tray may have slipped position.
7/23/2010 4:18:04 PM • Xerox WorkCentre... • Answered on Jul 23, 2010
Xerox 423 DADF seting
what do you mean dadf seting
you choose the dadf from the front screen
9/14/2009 12:01:22 AM • Xerox WorkCentre... • Answered on Sep 14, 2009
As my company is very small it is expensive to buy new cartridge
you can the toner is change
3/30/2009 10:43:32 AM • Xerox WorkCentre... • Answered on Mar 30, 2009
I have an H4 error!
what is the model of the copier
2/20/2009 7:35:46 PM • Xerox WorkCentre... • Answered on Feb 20, 2009
2answers
Xerox workcentre xd105f
It is entirely possible you have a small piece of paper that got ripped off somehow and it is now blocking the sensor leading the machine to think it has a paper jam.
Follow your jam clearance instructions again and pay close attention and rotate all movable parts in the jam area many times, then reboot the machine multiple times and allow the machine to completely come up before rebooting again, it may be necessary to reboot the machine 3 or 4 times to clear this error, each time following the jam clearance, if this doesn't resolve then you should have an expert take a look at the machine.
12/12/2008 5:13:23 PM • Xerox WorkCentre... • Answered on Dec 12, 2008
Xerox WorkCentre M123 Copier Logo
43 questions posted
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Xerox Office Equipment & Supplies
Most Popular Question
fuji xerox document centre c250
  • Office Equipment & Supplies
