20 Most Recent General Electric JVM1540 Over-the-Range Microwave 1.5 Cu. Ft., Stainless Steel Questions & Answers
I have no electricity.
You must have electricity for that unit. The ignitors are electric and so are the valves.
9/8/2017 8:31:28 PM • General Electric... • Answered on Sep 08, 2017
The replacement GE WB27X10910 transformer I purchased has the connector lug pattern in the reverse order when looking at it with the base of the unit to the left...wide lug to the left and two narrow
thinking the the different connector sizes denotes positive and negative terminals so put the right size connectors on the terminals
5/9/2017 10:44:12 PM • General Electric... • Answered on May 09, 2017
The fan on my general electric microwave model no. Dvm1850sm4ss won't turn off it stays on I unplugged and still turns back on as soon as I plug it in?
You might have a "normally open" thermal protector that is stuck in the closed position. Or, the controlling device (relay or triac) is defective. Or, something less probable. If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
5/3/2016 12:08:02 PM • General Electric... • Answered on May 03, 2016
Why is the microwave suddenly has no power.
Is it a wall mounted microwave? If it's not, did you try another outlet?
10/28/2014 8:30:39 PM • General Electric... • Answered on Oct 28, 2014
Why can't you run a microwave without anything in it? I ran mine for 4 minutes without anything in it and now it won't heat anything.
What was the point of running it empty?. Looks like you, as many users out there, never read instructions for any thing. No offence! First let me explain what a MICROWAVE does, then you will understand the damaged you have caused to your unit. A microwave is an electromagnetic wave (radiation) with a wavelength in the range 0.001 to 0.3 shorter than a radio wave but longer than an infrared. They are used in various scenarios; industrial processes, communications and heating. When these waves enter the food or liquids they are absorbed by their molecules which turns into an increase of the temperature of the items exposed. If nothing is exposed to absorb these microwaves, they will be reflecting in all the walls of the cooking chamber and eventually entering the grills (of the intake and exhaust vents) damaging the the electronic components exposed to these waves. Hope that helps! Al
10/28/2014 8:27:10 PM • General Electric... • Answered on Oct 28, 2014
WHAT IS THE CUBIC FEET OF JVM1339WB-002 GE MICROWAVE SPACE SAVER?
Determining the cubic feet of any given appliance, Microwave, Oven, Freezer or Refrigerator is quite simple. Follow these steps. Open the door of your microwave and measure the length, width and height in inches of the interior cavity. Multiply the length by the width by the height using a calculator to get the total in cubic inches. Divide the cubic inches by 1,728, which is the volume of a cubic foot. The resulting number will be your microwave's measurement in cubic feet. You can also use an online conversion calculator to simplify matters Hope that helps
10/28/2014 8:06:08 PM • General Electric... • Answered on Oct 28, 2014
What is the watts for jes831wb 002
900.0 Watts, http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SpecPage&Sku=JES831WB
10/28/2014 7:56:15 PM • General Electric... • Answered on Oct 28, 2014
0answers
0answers
0answers
I want to defrost my
Since you did not include a model number this is my best guesses:
http://manuals.appliancesonline.com.au/kcm2100wc/kcm2100wc.pdf (Page 1 w/pic)
and
http://www.appliancesdirect.com/InstallationPdf/49-60442.pdf (page 7 no pictures)
For Complete Defrosting
Turn the temperature control to the
OFF position and unplug the freezer.
Remove all food and place it in
corrugated boxes, insulated bags,
picnic coolers, etc. Use towels and
newspapers for insulation as needed.
With the door/lid open, use pans of
hot water to speed loosening of frost.
Remove large pieces before they melt.
Chest models have a defrost water drain
at the front.
NOTE: Water may drip from the back flange of
the lid cover during defrosting. This is normal.
Ice builds up in the lid insulation when the lid is
open for adding or removing food, and melts
during the defrosting operation.
Sponge excess water from the bottom
of the freezer as it collects to prevent
overflowing.
After defrosting, clean the inside of the
freezer (see Care and Cleaning).
Replace the drain plug inside the
cabinet and the cap on the defrost
drain. Fold over and dry the gasket
on the hinge side of the lid.
Plug in the freezer. Return the
temperature control to its previous
position and return food to the freezer.
Hopefully with this information you can find the drain. If not go to www.ge.com and click on service and support to download your manual. (Model number required)
or contact them here:
800 GE CARES
(800.432.2737).
Thanks for choosing FIXYA,
Kelly
7/24/2011 6:28:58 AM • General Electric... • Answered on Jul 24, 2011
Would like to learn how
You can download GE owner's manuals and installation instructions here.
We're
happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
6/7/2011 11:50:43 PM • General Electric... • Answered on Jun 07, 2011
0answers
General Electric JVM1540 Over-the-Range Microwave 1.5 Cu. Ft., Stainless Steel Logo
1 questions posted
Top General Electric Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a General Electric Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • General Electric Microwave Ovens
Most Popular Question
model 8006262000
  • Microwave Ovens
