20 Most Recent HP vp6320 Multimedia Projector Questions & Answers
0answers
Not working
Be the first to answer 2/15/2014 7:22:42 PM • HP vp6320... • Posted on Feb 15, 2014Be the first to answer
When I connect my blu-ray to the DVI(with an adatper) I get half a screen and a on screen note of 640x480. what am I doing wrong?
use tv remote change tv settings to higher resolution.
1/28/2013 2:24:31 AM • HP vp6320... • Answered on Jan 28, 2013
Red temp light
check lamp cover
8/20/2012 5:45:23 PM • HP vp6320... • Answered on Aug 20, 2012
When the power is turned
mi aparato se apago no prende y no se si es la lampara o no
4/14/2011 6:22:05 PM • HP vp6320... • Answered on Apr 14, 2011
HP vp6320 projector
You need to replace the color wheel sensor. I can fix it.
1/23/2011 5:47:42 PM • HP vp6320... • Answered on Jan 23, 2011
The projector won't turn on.
There is no fuse. Sounds like a power supply issue. How old is the projector?
10/27/2010 2:52:32 PM • HP vp6320... • Answered on Oct 27, 2010
The normally blue startup screen turned white with
In that case the image processor has failed - you must replace the entire mainboard and this will be very expensive. So expensive in fact that it might be more economic to just get a new projector.
10/12/2010 9:05:31 PM • HP vp6320... • Answered on Oct 12, 2010
I cannot adjust to get proper color mix,
check the vga cable is not missing any pins,replace the vga.
5/8/2010 11:17:44 AM • HP vp6320... • Answered on May 08, 2010
3answers
I recently bought an HP
That is exactly what the problem is. The thing about projectors is that they use a series of special mirrors to magnify a tiny image sent by the lamp's input. If even on those mirrors or lens is not in it's perfect position the image won't appear. It must have been damaged during transport ... try adjusting the position of that mirror but also be careful not to damage any of the other parts.
4/24/2010 5:21:04 PM • HP vp6320... • Answered on Apr 24, 2010
tip
Replace HP VP6321 Projector Lamp
Models: HP VP6321 / HP VP6320 / HP VP6310 / HP VP6300
Here are the steps to replace an HP VP6321 Projector Lamp:
  1. Turn off the projector and allow it to cool for 30 minutes.
  2. Unplug the power cord.
  3. Press the release latch (1) on the lamp cover and remove the cover (2).
  4. Press the release latch on the lamp connector and unplug the connector (3).
5. Loosen the two screws (4) on the lamp module, and pull out the module (5).
6. Insert the new lamp module into the projector and tighten the two screws.
7. Plug in the lamp connector.
8. Snap the lamp cover into place.
9. Turn on the projector. If the lamp does not turn on after the warm-up period, try reinstalling the lamp.
10. On the projector, press Enter.
11. Advanced setup, then Reset lamp hours.
12. Press Enter.
The lamp module has now been replaced and the projector is ready for use.
I hope that helps.
________________________________
Download Hp VP6321 Manual here.
tip
HP VP6321 Projector Manual Download
Download HP VP6321 Projector Manual
Have you misplaced your HP VP6321 Projector Owners Manual?
Would you like a digital, searchable, pdf version of the HP VP6321 Projector Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
____________________________________
Projector will not power On.
either the fuse on the power supply is blown, or the whole power supply needs to be replaced.
11/24/2009 7:11:47 PM • HP vp6320... • Answered on Nov 24, 2009
HP VP6310 projector problem
Usually it is the color wheel sensor. Know problem. I can fix it.
7/10/2009 10:39:38 PM • HP vp6320... • Answered on Jul 10, 2009
Epson projector problem. bulb flicker
Yupe, you need new lamp. Ouch.
6/6/2009 3:46:44 PM • HP vp6320... • Answered on Jun 06, 2009
HDCP compatible
There is no fix to this. basically HP did not make the HDCP very robust. It will DHCP with some DVD players, not all. HP is calling this a computer projector and down play the issue. No fix, try different DVD players. I had good luck with Toshiba HD.
6/6/2009 3:45:54 PM • HP vp6320... • Answered on Jun 06, 2009
HP vp6320 Multimedia Projector Logo
32 questions posted
k24674
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
  • HP Office Equipment & Supplies
Most Popular Question
  • Office Equipment & Supplies
