20 Most Recent
Epson Expression XP- 605 Inkjet Multifunction Printer - Colour - Photo/Disc Print - Portable Printer, Scanner, Copier - 32 ppm Mono/32 ppm Color Print - 12 ppm Mono/9 ppm Color Print ISO - 20 Second Photo - 5760 x 1440 dpi Print LCD - 1200 dpi Optical Scan Questions & Answers
Epson xp-605 switches off
Someone at SuperUser contacted Epson and was told to turn off the WiFi router (break connection), then disable Google Cloud Printing. That had mixed results.
Others found it easier to disable WiFi on the printer, then disable GCP.
How to improve the quality of pring photos
Use Epson Photo Paper, and set your printer to "best" quality.
I could help you better if you would:
1. give model of printer
2. tell me what paper you're using
3. what the problem is with your photos.
Stop the two red lights on my epson r200
Please try this procedure one more time using the instructions below.
- Turn the printer off, and disconnect the interface cable.
- Turn the printer back on.
- If the error lights disappear, turn the printer off and reconnect the interface cable. Turn the printer back on and try printing again.
- If the error lights continue, unplug the printer power cord for a few seconds and reconnect it to a different power outlet.
- If the printer is plugged into a power strip or surge protector, try plugging it directly into the outlet.
Note: Also check that the ink cartridges and lids are pushed down fully.
If the problem persists, an unknown printer error has occurred. The printer may require service.
