20 Most Recent
Pioneer AVH-X5600BHS DVD Receiver Questions & Answers
Radio Resets when I turn off my car
Hi
You haven't provided enough detail to work with.... but
In general terms. Check the wires going into the rear of the Pioneer. Use a 12v test light or voltmeter. When you turn the key off, one of these wires will lose 12 volts but there should be another wire supplying power when the key is off. Thats how it holds it's settings. One wire from Ign Key switch & one from 12v fuse box with power on all the time. So, check the fuse box if thats easier, as wire may have come off or a blown fuse.
Cheers TJ
6/29/2014 8:41:28 AM •
Pioneer...
Answered
on Jun 29, 2014
Pioneer AVIC-F900BT not picking up satellite pot new antener in
if the lnb is okay and the dish is on target , for certain, I would have to check all the settings in the setup menus. Ensure the box is set to the correct stellite. If the box has a blind search faility run it.
I would check that all settings, not just the satellite, are correct.
If you have a signal meter check at the dih , then at the receiver end of the cable for signal strength, Ensure the sat cable is in the aerial / lnbinsocket and that , if required, a loopthrough cable is in the appropiate / correct sockets.
Checking the menus would come after this.
GOOD LUCK
6/13/2016 11:03:00 PM •
Pioneer GPS
Answered
on Jun 13, 2016
