20 Most Recent TDK 8mm MP 120 Minute Premium Camcorder Tape P6-120 8mm Tape Questions & Answers
tip
Always look for Video Splicing tape on google
<span><b>Never!!!</b> Never use Scotch tape on your audio or videotape, eventually a chemical reaction will cause the glue to melt down and leak to adjacent parts of the tape and damage it beyond repair. Splicing tape is specially formulated for magnetic Mylar tape, Guaranteed not to melt or bleed.Splicing Blocka device used for positioning and holding down a section of magnetic tape while splicing and joining splices with splicing tape</span>
The tape film has been
use scotch tape to reattach tape
trim carefully so no extra tape hangs over sides
the "magic" tape works well - it is one that dissapears more when you rub it hard
4/10/2011 3:19:48 PM • TDK 8mm MP 120... • Answered on Apr 10, 2011
I would like to tranfer
It requires a specific software program to be able to do it.I found that out when researching about my VCR tapes to computer to DVD.Although I do not know how successful you will be with 8mm.Just search for it at various stores.Or better yet,begin by checking with your camcorder manufacturer to se if they know anything.Good luck,Greg
2/11/2011 7:54:59 AM • TDK 8mm MP 120... • Answered on Feb 11, 2011
I have video cassett size 8...I dont have the
look online or in some electronic stores for an adapter--the tape fits into a vhs format case and the vhs adapter is inserted into player theirs a vhs play adapter made for just about all compact tape units
4/26/2010 9:23:29 PM • TDK 8mm MP 120... • Answered on Apr 26, 2010
Sonilex mp3 player
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwjb3NfpyqODAxV8pIkEHdrGARoQFnoECCIQAQ&url=https%3A%2F%2Fwww.flipkart.com%2Fsonilex-sl-mp16-8-gb-mp3-player%2Fp%2Fitmeamgzmehkuxfy&usg=AOvVaw1cDMtU5SJ-HeoZJow0fXKZ&opi=89978449
12/22/2023 5:38:48 PM • TDK Electronics... • Answered on Dec 22, 2023
I formatted my TDK 16gb udb drive and now my win7 does not recognize it at all.
Please check if it behaves the same on another computer system. Otherwise reformat it again with FAT32 or NTFS format.
1/1/2017 8:55:32 AM • TDK Electronics... • Answered on Jan 01, 2017
How do I get the film taped on MiniDV60 TDK to my macbookpro?
depends on your camera, firewire if available (4 pin)
6/2/2014 9:50:29 PM • TDK Electronics... • Answered on Jun 02, 2014
How to open vvf video file
Use the following softwares: 1.File View Pro 2.Vi Verify Fingerprint
4/9/2014 1:48:44 AM • TDK Electronics... • Answered on Apr 09, 2014
Works to start with the all of sudden reports parameter problems
Skip Try creating a folder and just copy files. The size of the folder is too big.
4/7/2014 9:50:31 PM • TDK Electronics... • Answered on Apr 07, 2014
How to open a vvf file
Dear, You should switch to VLC Player. Please use following link to download this player for different OS version http://www.videolan.org/vlc/download-windows.html Regards, Rakesh Kumar
3/25/2014 7:29:38 AM • TDK Electronics... • Answered on Mar 25, 2014
Tdk data recovery
You can try 4Card Recovery. It is freeware and very helpful. Detailed steps are here. And it's quite easy. Step1. Download 4Card Recovery on your computer and launch it. Step2. Select the files that you want to recover, or you can choose to recover all. Step3. Choose the 'next' button to scan it and just wait for about ten minutes. Step4. Keep your recovered data or files on other part, this is very important. How to Recover Photos Videos off SD Card after Formatting Unformat SD...
3/16/2014 11:42:54 AM • TDK Electronics... • Answered on Mar 16, 2014
Can not format
at command prompt type chkdsk x: /f /r where x is the flashdrive /memory card
12/31/2013 2:33:30 AM • TDK Electronics... • Answered on Dec 31, 2013
I can't add files to my 16gb TDK gold flash usb
Try RMPrepUSB - Quick Size Test (it will destroy all data but test the drive) or FakeFlashTest. If it tests OK, reformat using RMPrepUSB - Prepare Drive.
11/1/2013 9:21:10 AM • TDK Electronics... • Answered on Nov 01, 2013
Online ups
Hi amin_amin Check to make sure the switch on the side of the card is not locked
5/3/2013 1:52:36 PM • TDK Electronics... • Answered on May 03, 2013
Can't remove write protect from my tdk flashdrive
You have to be the computers administrator to change any values on any hard drive on your computer click start control panel user accounts on the users tab click the name of the computer administrator you must have full control click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7 click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP click start right click on my computer select open Right click the icon of your usb drive (It should be E:/ or something) Click Properties in the menu that comes up Click the Sharing tab Click permissions And finally, click Allow next to Full Control. if you need more help with this post a reply Hope this helps.
1/13/2013 10:44:37 PM • TDK Electronics... • Answered on Jan 13, 2013
Electronics - Others Logo
Popular Tags
7 questions posted
Top TDK Electronics - Others Experts
 Grubhead
Grubhead
john h
David Kassin
David Kassin
Are you a TDK Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • TDK Electronics - Others
Most Popular Question
tape film
  • Electronics - Others
