20 Most Recent Bush 42" LCD TV 1920x1080, 50 Hz, Freeview HD, HDTV, LED Backlight, 3D Questions & Answers
There are many reasons for this fault. If you wish to get some details; check the site linked here. Pull up older posts.
Search the site by type in the "brand name" to your device; (Exclude the model number), or "Double image" in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Bush 42" LCD TV... | Answered on Jun 09, 2016
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Bush 42" LCD TV... | Answered on May 08, 2016
Codes are in the remote. Finding the code depends upon knowing the "brand" of remote and whether it is universal (URC-???).
Bush 42" LCD TV... | Answered on Feb 01, 2016
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Bush 42" LCD TV... | Answered on Jan 09, 2016
if it is not connected to a soung system that might be at fault reset it to factory default through the settings menus available on the remote and see if that makes a difference. If it only works via a remote control ensure the remote is functioning .
If you reset successfully and thereis still no sound, (and the cause is not a sound system or such,) vthen you probably need the services of a technician. No doubt , even in todays modern tvs, the sound output can go independently of the video output.
Bush 42" LCD TV... | Answered on Jun 03, 2015
I think that the tv is trying to return to its last state and can't log itself into Netflix or something along those lines and it's confusing its brain. I pressed the power off button while I had Netflix on and it's just switching itself on and off now. Mines 4 months old so it can't be wear and tear.
Bush 42" LCD TV... | Answered on Apr 05, 2015
It's possible it may be an error code. Depending on the number of blinks it will tell you what to look for when diagnosing the TV.
Bush 42" LCD TV... | Answered on Feb 19, 2015
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Bush 42" LCD TV... | Answered on Feb 09, 2015
Free bush tv software update downloads Try this link to download the firmware. You can get it from the authorized service centre for Bush too. http://electronicshelponline.blogspot.com/
Bush 42" LCD TV... | Answered on Nov 05, 2014
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Bush 42" LCD TV... | Answered on Sep 16, 2014
Bush 42" LCD TV 1920x1080, 50 Hz, Freeview HD, HDTV, LED Backlight, 3D Logo
Popular Tags
20 questions posted
Top Bush Televison & Video Experts
Joseph Hoffmann
Raj Patel
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Bush Televison & Video
Most Popular Question
screen gone two tone get back normal
  • Televison & Video
