20 Most Recent
Hoover HST5143WE White 204 l Fridge Freezer Top Freezer, A Energy Rating Questions & Answers
Hoover blade brush won't rotate. brush clean, belt good
If the brush on your Hoover Blade vacuum cleaner won't rotate, there are a few things you can check to try and fix the issue:
- Check for obstructions: Check the brush roll for any obstructions like hair, string, or debris that might be wrapped around it. Remove any obstructions you find.
- Check the belt: Even if the belt looks good, it might be stretched or damaged. Check that the belt is tight and not slipping. If the belt is stretched or damaged, replace it with a new one.
- Check the motor: The brush roll is powered by the motor, so if the motor is not working properly, the brush won't rotate. Check that the motor is working by turning on the vacuum and listening for a humming sound. If you hear a humming sound, the motor is working. If not, there may be an issue with the motor that requires professional repair.
- Check the brush roll bearings: If the bearings on the brush roll are worn or damaged, it may cause the brush to stop rotating. Try rotating the brush roll by hand. If it doesn't turn smoothly, the bearings may need to be replaced.
If none of these solutions work, it may be best to take your Hoover Blade vacuum cleaner to a professional for repair.
5/1/2023 6:46:37 PM •
Hoover...
Answered
on May 01, 2023
Why is my, hoover fridge 423, leaking water from underneath, sometimes? Posted approx 7am.
there is a drain line that goes to the top of the pump motor, has a plastic tray on top of the pump were the water is turned to vapor/steam, can become blocked at the top and to much water goes into the container. inside the fridge is a round huck at the back you pull this out to clean the line. but it sometimes needs a drain cleaner line putting down if the blockage is down the pipe.
5/7/2018 5:36:23 AM •
Hoover...
Answered
on May 07, 2018
