20 Most Recent
Celcus LED40S0913FHD 40" LCD TV 1920x1080, 50 Hz, HDTV, LED Backlight Questions & Answers
Turn volume up and the TVs volume goes back down to zero straight away everytime
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
4/12/2017 7:45:47 AM •
Celcus...
Answered
on Apr 12, 2017
There is no sound on our Celcus TV and the mute button has been checked
Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "
brand name" to your device; in the "
Search box at the top right of the display window of the Homepage" to get gathered related posts.
http://electro-medical.blogspot.com/
9/1/2016 8:43:01 PM •
Celcus...
Answered
on Sep 01, 2016
My celcus t.v keeps turning it self on and off,remote control has no effect.
8/22/2016 10:56:40 AM •
Celcus...
Answered
on Aug 22, 2016
Why does it have picture but no sound?
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
3/27/2016 5:16:14 PM •
Celcus...
Answered
on Mar 27, 2016
How do i get rid of the horizontal line going through the TV
Could be your display panel. check all your connections between the T-con & display panel, look specifically for corroded contacts at the panel plug, if you have that, try to clean those contacts.
If that doesn't cure it you may need the display panel. This would not be cost effective unless you found a used unit with a known good panel & could purchase very inexpensively.
3/5/2015 11:13:04 PM •
Celcus...
Answered
on Mar 05, 2015
Change the stored programme on the my button
Do a factory reset to this set. It will wipe off all. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
12/28/2014 3:13:28 PM •
Celcus...
Answered
on Dec 28, 2014
How do I change the picture size?
You can change the picture size by using either the TV remote or the cable box remote (which ever you are using). Just go into the TV settings option, scroll through the different options that adjust everything from color and tint, sound, contrast, etc, and you should find one for changing the screen size (my Sony TV can be changed from normal, and wide, to wide zoom).
9/20/2014 6:40:31 PM •
Celcus...
Answered
on Sep 20, 2014
Picture but no sound
Dear Amanda,
Please check in the TV remote control whether the volume is in mute or its in low.
Regards,
Samy
8/10/2014 7:40:33 AM •
Celcus...
Answered
on Aug 10, 2014
Celcus tv will not play movies
Your passport is just an external hard disk. Perhaps it even contains movies, but without a PC or a media centre, capable of playing the movie formats you have on the hard disk you won't see any movie.
Sometimes you just need an extra device.
if you have a lot of MP4 media, ending on '.mov', '.m4v' of '.mp4', you can play them with the Apple TV. But I'm sure there are more devices capable of playing video formats.
7/16/2014 7:00:53 PM •
Celcus...
Answered
on Jul 16, 2014
