20 Most Recent
Singer Sewing Machine 7422 Questions & Answers
I have a singer 7422. The fabric has to be pulled through the machine is there a way to adjust the feed dogs
I hope this is of some help different Fabrics need more or less downward pressure for the pick up dogs to move it forward, if you have tried this and that's not the problem then your feed dogs are worn but you can shim them up by removing the and cutting a piece of thick polythene of even thin paper or card be carful that yo don't make the drive dogs to high as this will then put holes in thin fabrics it,s trial and error to get it right.
Good luck
How do I stop all the lights from linking on model 7422 singer sewing machine
I'm assuming that your machine doesn't work--it just blinks the lights. It indicates that something is stopping the machine from setting itself up to sew. Most likely, it will need to be serviced, but you CAN at least rule out user error. Download the user's manual, and starting from scratch, make sure you have properly threaded and set up your machine. They also may have additional suggestions regarding the machine's behavior. There is often a troubleshooting part at the back of the manual. You can download it free at the Singer site.
Singer Touch and Sew 756 feed dog gear replacement
DON'T cut lumps out of your machine. There will be a sequence you use to remove the parts you need to access to the gears more easily. The Youtuber you referred to sounds like they have zero knowledge when it comes to these older style machines.
'Note' Some of the gear mount nuts are on a "Reverse" thread meaning you turn them the 'wrong' way to get them off.
My limited knowledge is more on the much older hand crank and treadle machines.
Try the Youtube link below for a channel called 'Andy Tube'. He has a good reputation for correct repair methods. The link is for a 758 but they're both Touch and Sew machines.
You could also try the Facebook group 'Vintage Singer Sewing Machines' as they have loads of knowledge about loads of different machines.
https://www.youtube.com/watch?v=zxd5hKjGBlE
All my decorative stitches are comming out straight
it sounds like something has happened to the cam gears thatdo the decorative stitches, which means the sewing machine needsto be checked..but before you have the machine checked,, make sure all the dial that are used for decorative stitches are at the right settingone missed setting can cause a lot of problems
