20 Most Recent Toshiba 40 Class 1080p 60Hz LED HD TV - 40L1400U Black 40 to 49 in Questions & Answers
If it, or your receiver has a headphone jack, search on the web for "wireless headphones for tv", or visit Best But or a local electronic shop.
Toshiba 40 Class... | Answered on Aug 08, 2014
ok what do we know now.
we know it fails on 2 PCs, all usb ports fail
and we know the drive motor is dead,
there are 3 parts here not one.
1: bad USB cable.?
2: bad chip in the enclosure, USB to SATA ESD zapped dead.?
3: bad HDD ,inside same. casing.?
we know now you have data there, not to be lost.
ok those are facts. best I can tell.
if the data is important and not backed up else where (endless choices that)
then that is your decision what to do next.
any hdd like that 2.5" sata
can be removed from case
and put in any computer made from year 2001 to now.
all have sata ports, (some early Laptops not)
so we install that (means open PC up and put it in the SATA cables or port jack)
the PSU turns on and the data cable must be connected for the start command to be received.
for you, I have 3 newer 2.5" hHD
here on a bench (have vast spares and tools)
I connect power to 3 drives, they are silent
this is because the data cable , gets command from he host (SATA) the drive startup command.
this is SATA spec, this, after all on huge systems say RAID all starting at once is FAIL, power overload so drives are staged up, this is normal
so we connect the data cable and the drive spins up, all tested did that.
also for you I have spare enclosures but in my cans the good kind with a power pack 2amps.
the drive how has +5vdc power for sure.!!!
I connect it up and the drive is silent
then with me plugging the USB cable to a running PC the PC sees it and sends the drive start signal.
this is how it works.
if you really need the data, no better way exists on earth than:
DIRECT SATA HDD connections and means to the INSIDE OF THE PC.
ok>
Toshiba... | Answered 1 hour ago
If UK keyboard click the 2 key with the alt key depressed. It varies with country code.
Toshiba... | Answered Yesterday
try the following
1. put a fresh battery for the battery .
2. check the remote with ur mobile camera.
3. if it works it shows you a flash light
Toshiba... | Answered 2 days ago
Hello Eufemia, several reasons can cause this problem and I leave you a video to help you solve it. Also in the description of the video, there are other solutions for different problems.
Toshiba... | Answered on May 19, 2019
Hello Kevin, try to connect a monitor to the monitor output, and see if it shows that it is working, if so, you would have broken the interconnection Flex with the screen
Also try, disconnect it from the power grid and take out the battery and let 30 minutes pass and replace the battery, and connect the power supply and test if it works
If with all these tests, you do not get results, look for a specialized technical service
I hope you can solve the problem
Greetings Franco Dosil
Hola Kevin, prueba conectarle un monitor en la salida de monitor, y ve si muestra que esta funcionando, si es as?, tendr?as roto el Flex de interconexion con la pantalla
Tambi?n prueba, desconectarla de la red de energ?a y s?cale la bater?a y deja pasar 30 minutos y vuelve a colocar la bater?a, y conectale la fuente de alimentaci?n y prueba si funciona
Si con todas estas pruebas, no consigues resultados, busca un servicio t?cnico especializado
Espero puedas resolver el problema
Saludos Franco Dosil
https://data2.manualslib.com/pdf2/33/3295/329500-toshiba/satellite_l555ds7005.pdf?d36b15a01a569dea5496149fa5362cf7&take=binary
Toshiba... | Answered on May 16, 2019
There are five basic steps to caring for teeth and gums:
  1. Brushing
  2. Flossing
  3. Eating right
  4. Visiting the dentist
  5. Rinsing
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Toshiba... | Answered on May 15, 2019
There could be many causes. First check for dirt in the cooling fan and radiator (just blow the dirt out).
Toshiba... | Answered on May 10, 2019
Last I knew, unless you have some odd 3rd party application installed, the Internet Download Manager was free.
http://www.ea.com/soccer/fifa/pc
Toshiba... | Answered on Apr 22, 2019
its a nice laptop
Toshiba... | Answered on Apr 21, 2019
Old power supply? Sounds to me like the power supply is sending a faulty signal to the motherboard, thus causing the computer to try to correct the problem with a re-boot. My Alienware is bad for that when the power supple gets weak. Buying a new power supply always corrects it.
Toshiba... | Answered on Apr 20, 2019
What browser are you using?
Internet Explorer? Chrome?
Try using a different one and see if you can access youtube from there, if not, check if you are the only one with the problem, there is a page to see if a site is down.
http://www.downforeveryoneorjustme.com
does any other page gives you trouble?
where are you? House, work, friends house?
Toshiba... | Answered on Apr 18, 2019
Toshiba 40 Class 1080p 60Hz LED HD TV - 40L1400U Black 40 to 49 in Logo
1 questions posted
Top Toshiba Computers & Internet Experts
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Computers & Internet
Most Popular Question
hook up wireless headphones toshiba
  • Computers & Internet
