20 Most Recent
Hotpoint tcm570p Aquarius Condensor Dryer Polar white Questions & Answers
Water light stay on even after being emptied.
The water full switch isn`t on the water container but in the sump where the water is collected and then pumped up to top container,so it`s possible that the sump is full and the float has risen (this switches heater off and illuminates the water full lamp) it`s most likely then that your pump or pipework is blocked or pump has failed.
Hotpoint VTDOO dryer works but timer does not move and no reverse
sounds like you may have a timer with the contacts sticking closed at certian intervals. or a bad pcb check visual inspection of PCB look for burns or bulges, on the diodes or capcitors, Ihave in the past taken timers apart and fixed sticking contacts by sanding with emery cloth.
Hotpoint Aquarius dishwasher DWF34S/42 no power - possible fuse blown
Based on your description, it sounds like there was a short circuit in the dishwasher which caused the fuse to blow and the burning smell. It is possible that the burnt connection you are seeing is related to the short circuit.
If you have experience with electrical repairs, you can try to identify and replace the burnt connection. However, if you are not comfortable with electrical work, it is recommended that you seek the assistance of a qualified technician to avoid any potential safety hazards.
In any case, before attempting any repairs, make sure that the dishwasher is disconnected from the power source and that all safety precautions are taken.
Hotpoint TCFS93B is the motor starting to fail or ?
It is possible that the motor in your Hotpoint TCFS93B tumble dryer is beginning to fail if it is experiencing difficulty starting up and exhibiting similar symptoms to a failing capacitor. However, without more information or further diagnosis by a qualified technician, it is not possible to accurately determine the cause of the issue
The drum wont spin on my Hotpoint CTD00 dryer
Remove top cover, and see if the belt is intact, if it is then it could be the motor is not working for one reason or another, this would entail further investigation.
Please rate my solution.
Thanks.
How do I remove bra wire from hotpoint v3d01 tumble dryer
It really depends on where it is stuck, and you don't tell us that. If it is down where the filter is, you can get it with a magnet taped to a stick. If it is between the drum and the outer drum you may be able to open out a coat hanger and pull it towards the edge. Depending on the age of the dryer, it might be time for a full strip-down service and do some maintenance. Grease the bearings, oil the drum slides and remove all the lint that hides inside and causes 'Dryer Fires'.
You are not alone, and there are videos to help you.
https://www.google.com/search?q=remove+bra+wire+from+hotpoint+v3d01
