20 Most Recent
Sony Cyber-shot DSC-H300 Digita Camera - Black Questions & Answers
The camera will not turn off and the lens is not fully retracted
from your question I understand there may be problems in the lens unit, in some cases totally open the lens unit fully re assemble it again,clean the sensors at side of the barrels, can override this snags.
the below picture is not the same, but similarly you take the cam sect out and reassemble it.
When I turn camera on, lens goes fully out and back in again, about 4 times, then Turn the power off and on again.
Guess work.
When fine sand (or similar particles) get stuck in-between the tubes (lens barrel) the lens will behave that way.
Your case may be caused by something else but its worth trying to fix it yourself first.
Prepare a blower or fine brush, ready in one hand and switch on the camera (either fixed to a stand or stand it on a solid surface) Give it a good blow and brush gently (all around the tubes) while the lens is moving. It will stop and work normal when the foreign body is removed. If this does not work, keep asking because other people might provide a better answer.
What memory sticks do i need
Quoted from the technical specifications available on the Sony website UK.
http://www.sony.co.uk/electronics/cyber-shot-compact-cameras/dsc-h300/specifications
Storage Media
Internal MemoryApprox.55MB
Compatible Recording MediaMemory Stick Duo, Memory Stick PRO Duo, Memory Stick PRO Duo (High Speed), Memory Stick PROHG Duo, Memory Stick Micro*10 , Memory Stick Micro (Mark2)*10 , Memory Stick XC-HG Duo, SD Memory Card, SDHC Memory Card, SDXC Memory Card, microSD Memory Card*10 , microSDHC Memory Card*10 , microSDXC Memory Card*10
Dsc h300 shows message to reinsert memory card. I do and then still same message appears
You stated the problem, but left an open ending. There is not enough details to provide you some good answers but try these ---
1 Make sure the SD card is readable - check the tiny slide switch on the side is not aligned to the lock position. If it does, slide it back.
2. While inserting the SD card, be sure to face it the right way.
3. If you have access to a computer, check to make sure the card is working.
You need to provide sufficient information in future for better answers.
thank you.
Need usb transfer cable code or number for a sony cybershot n50
I believe you are looking for a USB transfer cable for your Sony Cybershot N50. I found a replacement USB camera transfer data sync charging cable cord for Sony Cybershot Cyber-Shot DSCH200, DSCH300, DSCW370, DSCW800, DSCW830, DSC-H200, DSC-H300, DSC-W370, DSC-W800, DSC-W830 digital camera on Amazon . This cable is compatible with several Sony Cybershot models, including the N50. The cable is priced at $7.95 and comes with a 30-day return policy.
Amazon.com: Replacement USB Camera Transfer Data Sync Charging Cable Cord for Sony Cybershot Cyber-Shot DSCH200, DSCH300,DSCW370,DSCW800,DSCW830,DSC-H200,DSC-H300,DSC-W370,DSC-W800,DSC-W830 Digital Camera (Black) : Electronics
1/23/2024 10:01:12 PM •
Sony Cameras
Answered
on Jan 23, 2024
How can I change the language on my Sony DCR PC-100? I'm trying to change it from Japanese to English but I cant seem to find the solution online as well as from reading the manual.
The Sony DCR-PC100 is a camcorder model that was released before touch screen interfaces and language settings became more common on consumer electronics. As such, it's possible that this specific model might not have a built-in option to change the language from Japanese to English, especially if it was originally sold for the Japanese market.
However, there are a few general steps you can try that might help:
- System Menu: Check the camcorder's settings menu for any language-related options. Look for a "System" or "Language" menu where you might be able to change the language settings. Keep in mind that the menu options might still be displayed in Japanese, so you might need to rely on symbols or context.
- Reset to Defaults: Some devices have a "Reset to Defaults" option that might reset all settings, including language, to the factory defaults. This might be worth trying if you're unable to find the language settings.
- Contact Sony Support: If you're unable to find a solution through the manual or online resources, it's best to contact Sony customer support for your region. They might be able to provide specific guidance or let you know if changing the language is even possible on the DCR-PC100.
- Third-Party Resources: Search for user forums or online communities where other users might have faced a similar issue and found a solution. Sometimes, enthusiasts or experts in those communities can provide helpful insights.
- Professional Assistance: If all else fails, consider reaching out to a professional technician or service center that specializes in Sony camcorders. They might have experience with older models and could potentially assist you.
8/5/2023 10:14:51 AM •
Sony Cameras
Answered
on Aug 05, 2023
