20 Most Recent
Nikon COOLPIX AW120 Waterproof Digital Camera Black Questions & Answers
I AM UNABLE TO CONNECT THE SMART PHONE TO THE NIKON AW120. IT DOES NOT ALLOW ME TO GO THERE IN THE CAMERA
I do NOT have this camera. The Camera has to be in WIFI mode. (This mode uses more power) If you have done that you have to have a APP (Nikon WMU) on your Phone. If you do NOT connect rather quickly to the Camera it may shut OFF WIFI Again the WIFI really uses more power so if you do not connect it will turn it off. This may drive you nuts. Please make sure the batteries in the camera are fully charged and make sure for a test they are near each other.
How to connect Nikon AW120 to wifi?
It is in the manual page 92, but I print it here:
I don't like to type things what are already in black and white.
If you never have setup any wifi connection, this won't help, neither will a typed version I do. so if you don't understand ask someone close to you to help, with the description here.
Just bought Nikon p600 and cant connect to WiFi help
U need to download nikon wmu software from google playstore or appstore. Then start wifi of ur camera and then start wifi connection in ur mobile.select "nikon p600" in wifi setup.when connected, start application named "wmu" in ur mobile.wait for the connection.after few seconds wifi connection will be established.hope this would help u!
My Nikon b500 Coolpix won't turn on just flashes green
It flashes green when it is basically on but in a sub mode that I'll call CHARGE MODE. If it is flashing that means the battery is charging. I suggest to let it continue to charge until it stops flashing and then remove the charger connection. When the camera is sitting all by itself with nothing connected you can then turn it on.
