Your cellular carrier can provide you with a "signal booster" device that can repeat and boost a cellular signal you already get in your house. For example, if you consistently have one bar of coverage but no more at home, a booster can take that one bar and turn it into more bars. If you have one or two bars of coverage near a window but no coverage elsewhere in your home, a booster near that window can capture the signal and boost it, providing a strong signal throughout the rest of your home.
Some carriers offer such devices very inexpensively - $50 or maybe even free - especially if you're in an area where they know they know they have poor coverage. T-Mobile now offers such boosters for only a $25 deposit, which you can get back just by returning the booster to them.
Contact your carrier - or look at their website - to see just what they'll offer you and for how much.
Femtocells / Microcells
A femtocell - or "microcell" - is a small, low-power cellular base station that connects to the cellular network via your broadband Internet connection. Essentially, it's a small cellular signal tower that will provide a signal in and near your home, connecting to the larger mobile network over your Internet connection. This makes it ideal for situations where you don't even have a signal bar of coverage you can boost at home. The only "catch" is that your Internet connection must have a high enough download speed. Different carriers require different minimum speeds, but you should be fine as long as you have a solid broadband connection.
Ask your cellular carrier if they offer this sort of product and find out how much it will cost you. As with boosters and repeaters, a femtocell may be available at a steep discount from your carrier in areas they know they have poor cellular service.
You can also buy them easily on Amazon or almost any decent tech store - for instance the one pictured below works for AT&T and supports LTE (though it is a bit pricey), or you can get one that supports Verizon, T-Mobile, AT&T, Sprint, Cricket, and many others, but you won't get LTE support. Of course, since you likely have Wi-Fi in your house, LTE isn't really a big deal and the 3G will work just fine for calls and texts.
Editor's Note: For the official How-To Geek office we got a Samsung microcell device directly through Verizon, which wasn't cheap, and doesn't work all that well. And since it only works for Verizon, any of the people who come by who use other carriers have zero signal, which is really annoying. If we could do it over again, we'd have started with this zBoost microcell that supports virtually every cell provider and has many different models and options to choose from depending on the size of the house. They even have an optional antenna you can install on your roof to give cell coverage everywhere around your house. It's the best choice, and cheaper than most carriers will offer you.
Wi-Fi Calling and SMS
Wi-Fi calling is a feature you might remember from some years ago, but it's coming back with a vengeance. At the moment, in the US, only T-Mobile offers Wi-Fi calling for both Android phones and the iPhone. Sprint only offers Wi-Fi calling for select Android phones. AT&T and Verizon have announced plans to activate Wi-Fi calling in 2015.
Essentially, WI-Fi calling allows your smartphone to receive and place calls and communicate via text messages over a Wi-Fi network. Your home probably has Wi-Fi, so Wi-FI calling will let you use your existing wireless router instead of needing a new, specialized device. You can just improve your Wi-Fi signal strength, and all your devices will benefit!
Wi-Fi calling works transparently. When your phone is on Wi-Fi and has a poor cellular signal, it will connect to the Wi-Fi network and your phone calls and text will be sent and arrive over the Wi-Fi network. When you leave the Wi-Fi network, your phones and calls will be sent over the cellular network as usual. This is all designed to hand-off automatically, so you could start a phone call on your Wi-Fi network and your phone would automatically hand off to the cellular network as you walk out the door, with no interruptions.
WI-FI calling will also work on other WI-Fi networks, so it's helpful if you ever end up in another place where you have a poor cellular signal but have Wi-Fi. To use this, you'll need to ensure your phone has Wi-Fi calling support and that it's enabled. Android phones from T-Mobile and Sprint will often include this feature, so look up how to enable it on your specific model of Android phone.
The iPhone 6 has built-in Wi-Fi calling, although it currently only functions on T-Mobile. AT&T and Verizon plan to support it in 2015. To enable this feature on an iPhone, open the Settings screen, tap Phone, tap Wi-Fi Calling, and activate it.
WI-Fi calling seems to be the future goal the industry - T-Mobile, especially - is pushing towards. With Wi-Fi calling integrated into your phone, you don't need to buy a specialized device. Your home Wi-Fi router works. And, when you go somewhere else where you have a poor signal, all they need is a Wi-Fi network and you'll be able to get a phone calls and SMS messages through it.
Image Credit: Carl Lender on Flickr, Nan Palmero on Flickr, Wesley Fryer on Flickr
hope that helps
Hello Garry!
To answer your inquiry, the compatibility will depend on the model that you have. Let me share with you the bands that Moto G uses, please consider if you have a CDMA or a GSM version.
Global GSM Model:
GSM/GPRS/EDGE (850, 900, 1800, 1900 MHz)
UMTS/HSPA+ up to 21 Mbps (850, 900, 1900, 2100 MHz)
US GSM Model:
UMTS/HSPA+ up to 21 Mbps (850, 1700 (AWS), 1900 MHz)
CDMA Model:
CDMA/EVDO Rev A (850, 1900 MHz)
Also, I kindly recommend you to verify with Tacfone, if your device will be compatible with their network.
If you need further information about the specifications of your device, please follow up this link: http://bit.ly/MotoG-specs
Hope this information is helpful for you.
Best regards,
Liz
Motorola Support
Hello Anonymous. It could be that your phone is looking for a device to pair. You can go to touch Apps and touch Under Wireless & Networks; and slide your finger to the left until your Bluetooth is off. You can check this steps trough the link: Using Bluetooth
While still holding the VOL DOWN key, press and hold the POWER key
Hold both keys down for over 120 seconds. This is more than two minutes and will seem like a long time. You might want to time yourself to make sure you hold it longer than two minutes.
After holding the keys down for more than two minutes, release them.
The Flash Boot screen will display, and the Normal Reboot option will be highlighted
Press the VOL UP key and the device will start a normal reboot.
If you have tried the above and it didn't work, try this:
Hello Anonymous, You can try to go to settings and go to apps and slide your finger until you see all your apps and tap on camera. In your camera tap on clear cache and force stop and reboot the phone. If you receive the same error try to follow the same path but instead of clear cache, tap on disable and then enable it again and reboot the phone.
Model : All Motorola
1 - Switch ON your phone with a not allowed SIM Card,
2 - Phone show "Enter Special Code",
3 - You can now enter the Unlock Code we send to you.
WARNING : If one of theses messages appear :
- "Contact Service Provider"
- "Tampert Alter"
- "Wait before enter special Code"
- "Contact Service'
It's because you or somebody allready enter too many wrong codes, you just have to let phone ON on theses errors messages and after 40 min to 2 hours maximum the message "Enter Code Special" will appear again !
You were asked questions? I have been campaigning for this for 3 months. I told them you need a pop-up
All questions need 'make model (what it is)' as first 3 words.
You are missing the maker, but you do mention 'shredding'.
Then I also said 'There are 40,000 categories to choose from'.
You chose 'Cell Phones'.
and it's not a 'memo', it's a question. :>)
So, first of all, disconnect it from the mains for 30 minutes. If you jammed it, you were working it hard, and when it jams, heat builds up in the motor and trips the thermal protection device. They have a thermal cut out, some have a thermal fuse what need physically replacing, but most reset when they cool.
Does it work in reverse? A jam can sometimes damage the switch in the throat of the shredder, some are a mechanical switch, some are an infra-red sensor.
https://www.google.com/search?q=DM72C
The difference between EC-Council's Certified Ethical Hacker v8 and the new Certified Ethical Hacker v9 is not the exam format, but the content itself. People seem to assume that since EC-Council updated the certification, the exam must be brand new. This isn't the case. In order to obtain the new CEH v9 certification, you do not need to study for and pass a brand new exam with new objectives and format. The test has the same format, is identical in size, and has the same amount of questions. There are only two things that changed. CEH V9 EXAM FORMAT AND BREAKDOWN The aforementioned v9 exam follows the same format and percentage breakdown of questions as v8. For example, the section on security will still take up 25% of the exam, while the section on tools, systems and programs will take up 32% of the exam. The full breakdown of the exam is visible on our . The Exam Details are as follows:125 questionsTo pass you need a score of 70%Maximum of a 4 hour durationMultiple choice formatHOW TO PASS YOUR CEH EXAM If you are studying v8 exam materials, you are not automatically going to fail the v9 exam. The test is updated, not revamped. This means there might be a handful of questions you may not necessarily have studied in depth for, but if you studied at all, you will have some familiarity with the new questions. The new questions are not on brand new material, they are more in-depth questions on topics that have become more relevant in the cyber security world over the last eighteen months. So you can still pass v9 studying v8 material.Should I still take CEH v8 Exam? However, if you study v8 materials you can still take the v8 exam. EC-Council has not retired the exam yet. So if you are not comfortable with the idea of taking an exam that you may not know 10-15 "new" questions, then don't. The only problem with this is that once the v8 certification does retire you will eventually need to take v9. Why prolong the inevitable then?Will I need to take the CEH v9 exam? If yes, then when? The test is updated on a rolling basis. This means that occasionally EC-Council adds new questions to the exam without updating the entire certification. The fact that v9 is now available means that there are new and updated CEHv9 study materials with a new focal point to deal with the always progressing world of IT.THE DIFFERENCE BETWEEN CEH V8 AND V9 With the update to the courseware, the exam covers certain questions differently. These questions focus on topics that are becoming more prevalent in the world of cyber security and IT. The key differences are:V9 focuses on cloud computing more than v8 did and dives into best security practices for dealing with cloud computing attacks.V9 covers mobile security and tablet computers and you must understand how to perform hacking techniques on these devices.v9 addresses new vulnerabilities in cyber security such as, Heartbleed, Shellshock, and POODLE. CEH v9 vs v8 What New on the Certification Exam TechRoots
