20 Most Recent Indesit IDV 65 White Electric Dryer 6 kg, 16 Cycles Questions & Answers
I have an Indesit idv65 Tumble dryer and the plug gets hot whilst in use. It is not the socket as other appliances do not get hot. Is this a fault with the model? What could be the problem? The plug i
-The plug it self get hot...? -If so the dryer carry lot of am through. You possibly need to get a bigger wire to replace. Good Luck mai
11/14/2014 8:38:26 PM • Indesit IDV 65... • Answered on Nov 14, 2014
Indesit IDCE 8450BH Dryer. Hello, I have an Indesit IDCE 8450BH and it doesn't heat up enough.
If the heating element has been replaced and you can see that it becomes red, but it still doesn't heat up enough to dry the load, there are a few possible causes:
  1. Airflow restriction: Make sure that the dryer's lint filter and exhaust duct are clean and free of obstructions. Poor airflow can cause the dryer to overheat and shut off the heating element prematurely, leading to inadequate heating.
  2. Thermostat malfunction: The dryer's thermostat controls the temperature inside the dryer and turns the heating element on and off accordingly. If the thermostat is malfunctioning, it may not be allowing the heating element to heat up to the proper temperature. You can test the thermostat with a multimeter to see if it is functioning correctly.
  3. Faulty cycling thermostat: The cycling thermostat is responsible for cycling the heating element on and off to maintain the proper temperature. If the cycling thermostat is malfunctioning, it may not be cycling the heating element on and off properly, leading to inadequate heating.
  4. Wiring or control board issue: Check the wiring connections to the heating element and thermostat to ensure that they are secure and not damaged. If the wiring is fine, there may be an issue with the dryer's control board, which controls the heating element and thermostat.
It is recommended to consult a qualified technician for further diagnosis and repair of the issue, especially if you are not familiar with electrical troubleshooting or working with appliances.
3/18/2023 8:25:49 PM • Indesit Dryers • Answered on Mar 18, 2023
My Indesit tumble dryer IS60V door is letting hot/damp air out
There is sometimes adjustment on the hinges and pulling may have moved them.. OR, you need to twist the door the other way to rectify and fill the void. Also check that the door gasket is not damaged, torn or missing.
11/11/2022 6:16:10 AM • Indesit Dryers • Answered on Nov 11, 2022
Indesit IDV75UK Tumble Dryer 2200 Watt. My Indesit dryer stops when it changes spin direction?
Question edited for clarity, full 'make model (what it is)'. Question moved from Miscellaneous to Indesit Dryer. You have an issue that no one else has encountered. My _guess_ is that the motor controller board is faulty. You will need a service call. https://www.google.com/search?q=Indesit+dryer+stops+when+it+changes+direction ..
4/26/2022 3:34:28 PM • Indesit Dryers • Answered on Apr 26, 2022
Indesit tumble dryer need a wiring diagram for timer on model IDV 75
check with a dealer locally
11/27/2021 12:20:20 PM • Indesit Dryers • Answered on Nov 27, 2021
What does error code h2 mean on an indesit condenser dryer is it dangerouse to use like this
No such Indesit code H2! Are you sure it is not H20? Error H20 in the Indesit washing machine indicated that during the allotted time the machine could not fill enough water for washing or rinsing because of some kind of malfunction.
6/6/2020 6:45:08 PM • Indesit Dryers • Answered on Jun 06, 2020
My IDC 85K indesit dryer is working but no heat generated What could be wrong
Heating element is where I’d start.
12/6/2018 4:38:07 AM • Indesit Dryers • Answered on Dec 06, 2018
2answers
My IDC 85K indesit dryer is working without generating heat. what could be wrong
Bad heating element
12/6/2018 2:55:18 AM • Indesit Dryers • Answered on Dec 06, 2018
My indesit tumble dryer won’t turn on. The power is getting to the little switch inside the machine at the back
Some dryers require the filter to be removed and cleaned and reinserted before each cycle.
11/27/2018 3:29:29 PM • Indesit Dryers • Answered on Nov 27, 2018
Indesit dryer is leaking water from bottom back sponge
Is the tube for water pumping up lose?
11/23/2018 12:54:19 PM • Indesit Dryers • Answered on Nov 23, 2018
Indesit is70c is not drying effectively. I have
possible thermostat
10/21/2018 8:55:35 AM • Indesit Dryers • Answered on Oct 21, 2018
My Indesit idca8350 tumble dryer keeps stopping mid cycle and all of the top lights flash and the clean condenser light stays on. If you switch it off and on again at plug it resets it.
Remove the condenser and clean it. They normally just need a lever to be unlocked and the whole condenser will slide out of the machine.
10/1/2018 7:09:35 AM • Indesit Dryers • Answered on Oct 01, 2018
Indesit IDV 755 tumble dryer blowing cold air. where is reset button ?
Check your heating element.
9/9/2018 11:32:14 PM • Indesit Dryers • Answered on Sep 09, 2018
Can't get back cover off to get into look at pump on my indesit idc85 condesor tumble dryer
you can go here and it will show you how to take it apart https://www.youtube.com/watch?v=5v-qtH18fiM
9/9/2018 1:17:42 PM • Indesit Dryers • Answered on Sep 09, 2018
Indesit IDV 65 White Electric Dryer 6 kg, 16 Cycles Logo
3 questions posted
Top Indesit Dryers Experts
Ngoro
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you an Indesit Dryer Expert? Answer questions, earn points and help others
View Most Popular
Indesit Dryers
  • Indesit Dryers
Most Popular Question
indesit idv65 tumble dryer plug gets hot
  • Dryers
