20 Most Recent Ematic HD Quad Core 7" Tablet 8GB Memory Featuring Android 4.2 Jelly Bean with Google Play 28858634 Questions & Answers
Did a system recovery and now it wont load properly..is stuck in a loading apps loop.
The install is checking for more information and applications. It is not able to locate them. Are you sure about the make and model?
1/26/2016 11:49:46 PM • Ematic HD Quad... • Answered on Jan 26, 2016
0answers
0answers
My fiace upgraded it to windows 10 and the touch screen is way off. where he touches on the screen is displayed elsewhere. How do we fix this problem?
Check the menu on your monitor itself. There should be a calibration area for you to re tune the touch screen.
12/12/2015 9:28:23 PM • Ematic HD Quad... • Answered on Dec 12, 2015
2answers
I have no room left on my tablet to download a game called gummy drops. Can i use a sim card to give my tablet more space to download the game app
Use the sim card and move photos and/or videos to sim card to create space for the game.
6/11/2015 12:15:31 AM • Ematic HD Quad... • Answered on Jun 11, 2015
Why do I get an echo when playing my music on my Ematic tablet?
You have a microphone on. Check your audio settings.
6/3/2015 7:06:30 PM • Ematic HD Quad... • Answered on Jun 03, 2015
What is rstech_teni on a ematic 7 HD quad core it says it stopped
rstech_teni is in your tablet as a core system app even though it may be no such thing. I believe it was put there by the tablet manufacturer in some contractual agreement with some advertising entity. The Lookout malware scanner may sometimes detect it as malware you should just ignore it and not try to delete it, as it will result in your problem again. You will not be able restore the tablet from the hardware restore menu (hold power & up vol) because it will not allow you to answer "yes" to the prompt to proceed. Two ways to fix, (Later, on how to actually select something) 1. (preferred) Go to >Settings >Apps >All scroll down to rstech_teni, select it, and then select "Clear data" If you don't see retech_teni you may find "rs_9104_v30". This may be a clone of rstech_teni, do the same to it. Your done. 2. (last resort, you will lose installed apps and data) Go to >Settings >Backup & reset >Factory data reset, Follow instructions, and your done. And now the hard part, to deal with the message that will not let you navigate. The easy way to get to "Settings" is to short tap power button to put tablet to display off/locked. Then again short tap to turn on screen. You will see the rstecc_teni MSG hit OK in MSG. The MSG should be gone and not come back, do nothing else other than pull down the right upper drop down menu where the settings button is then select settings. At this point the evil MSG will come back. From here on the frustration will start. You will need to use two hands. Tap the rstech_teni OK with one finger on one hand and then quickly tap the Apps option with a finger on your other hand. This is kind of time consuming but it works after multiple attempts. If you have a stylus pen, use it for the second tap to the option you want. It will seriously reduce the time it takes by making the second tap very accurate. Within a half hour you should be able to get through this. I know because I had the same problem.
1/26/2015 2:35:46 AM • Ematic HD Quad... • Answered on Jan 26, 2015
How do I get internet it is showing that it has it but it does't
Having connected to your WiFi router, (Choose yours by SSID (name) and supply the correct password) you then need to open a web-browser or other internet-enabled service (E-mail, Skype etc). Please provide error messages to trouble-shoot further.
1/4/2015 2:15:13 AM • Ematic HD Quad... • Answered on Jan 04, 2015
Tablet will not charge
go to this link ,Probably the battery monitor software on the tablet goes out of sync with the actual battery charge. This happens often, especially for tablets that have been used over some time. There's some good suggestion here on how to fix such kind of charging/battery problem. It's for the Kindle Fire, but the steps will work for any tablet: http://budurl.com/FixAndroids
8/4/2014 3:44:26 AM • Ematic HD Quad... • Answered on Aug 04, 2014
Why want the tablet will not charge
try this : Probably the battery monitor software on the tablet goes out of sync with the actual battery charge. This happens often, especially for tablets that have been used over some time. There's some good suggestion here on how to fix such kind of charging/battery problem. It's for the Kindle Fire, but the steps will work for any tablet: http://budurl.com/FixAndroids
8/4/2014 3:43:40 AM • Ematic HD Quad... • Answered on Aug 04, 2014
What do I do when I turn on my tablet and a picture of a battery with a triangle with an exclamation mark appears ?
battery low or not enough battery left or need a new one!!
7/28/2014 2:56:27 PM • Ematic HD Quad... • Answered on Jul 28, 2014
2answers
Forgot password
So all you have to do is power it down. Press and hold + volume button and start the tablet. It will give you 3 option . Select errase all data and factory reset. Bang it will reset to factory defaults smile.png
10/5/2017 9:21:43 PM • Ematic Tablets &... • Answered on Oct 05, 2017
Have ematic 003. When I uninstall any of preloades apps, it shows uninstall and the app no longer appears on the tablet. But the next time I turn on the tablet all the uninstalled apps are back.
It is not possible to uninstall preloaded apps on your tablet unless it is rooted. Then you have to check to make sure that no other services on the tablet depend on that app as it could mess your tablet up
6/30/2014 11:54:40 PM • Ematic Tablets &... • Answered on Jun 30, 2014
Ematic HD Quad Core 7" Tablet 8GB Memory Featuring Android 4.2 Jelly Bean with Google Play 28858634 Logo
24 questions posted
Top Ematic Tablets & eReaders Experts
Paul Bade
 Mikey
Mikey
Are you an Ematic Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • Ematic Tablets & eReaders
Most Popular Question
when turn tablet picture battery
  • Tablets & eReaders
