It sounds like it may not be fully charging.
If the port on the tablet is loose/damaged or the cable/charger is failing, then the tablet may not be charging even though its plugged in.
If you can, try a different cable.
Make sure the charger is the correct one for the tablet! Some tablets require more electrical current then a computer's USB port provides. Same thing applies if you are using a 'phone' charger with the tablet, might not be enough current.
Most USB ports/chargers output about 5 volts DC (direct current), but they can vary in the amount of Amps (A) or mili-Amps (mA) they produce.
FYI - the symbol used to represent Direct Current is straight horizontal line with a dashed horizontal line directly under it.
Most computer USB ports only produce 500mA.
Most phone chargers only produce 1A.
Many tablets require 2.1A or 2.4A to properly charge.
Check with your tablet manufacturer to find out what your specific make/model requires and the look closely at the charger you are using to see what the OUTPUT is ... e.g. 5.2V 2.4A
Checking the Computer AC Charger
When you use the computer AC Charger to charge the tablet but no power is charged, see the instructions in this topic to check the computer AC Charger.
To check the computer AC Charger, do the following:
1. Disconnect the micro-USB cable from the tablet.
2. Measure the output voltage across the connector marked B of the micro-USB cable. Refer to the following figure:
For more pictures and description check the link bellow. On search tab type Lenovo
www.electro-medical.blogspot.com/google.com/+AjinGopakumar
You can get an adapter cable that will fit into the tablet's USB port. It's called an OTG cable. With that, you can hook up cellphones, digital cameras, thumb drives, SD card readers and many more things. The best way to do that would be to get an adapter OTG cable and a card reader. You can also transfer it to a computer and then to the SD card. If you don't have a card reader most digital cameras will work as one. Hook the camera to a ps and look for it in my computer folder. (works on macs also) and opens it. There you can put any file on the SD card. If using an OTG adapter to just hook it to the device's USB port and go to your file manager app. I would recommend an app called ES File Explorer. it makes it simple to find files on Android devices. Once you locate the drive (usually it's called USBDRIVEA) just transfer the music. Here is a link to a video that will help. I take no credit of video.
please attempt to use another internet source before attempt to access the app store on your tablet. This can be either ethernet or tablet. If this fails, please restart your tablet once or twice. Otherwise, you might need to transfer antivirus apps via usb into your tablet, install/run those and then attempt to access your app store again.
Thank you.
Go to Settings and choose Default Applications. You should be able to see the list of all of the apps which you have set as default. The only thing you have to do is click on "clear" and it will delete the unwanted setting.
Google Play Services, the preinstalled app on your phone plays an extremely crucial role in the regular running of your lenvono. If anything is wrong with it, then your lenovo will start throwing fits in the form of errors and crashes including 'Google Play Services keeps stopping' error.
To remove the error, you need to fix Play Services. Here you will find numerous ways to fix any issue related to Play Services. Let's get to know them.
1 Starting with, will actually with restarting you Lenovo.
2 Another that does wonders for any issue is to "clear the cache" and date of the particular app. In this case, we need to clear cache and data for "Google Play Services" and "Google Play Store".
Doing any of that will not delete any data from your phone. However, clearing data will log you out from Play Store and reset its settings. In settings
3 "Google Play Services" is a system app, you cannot remove it from your lenovo completely. However, you can uninstall the updates, which will revert it to the factory version forcing your phone to update it automatically, thus fixing any issue.
On the Google Play Services screen, tap on the "three-dot" icon at the top-right corner. Select Uninstall updates from the menu.
4 Unlike other installed apps, you don't have to update Google Play Services manually. It's done automatically in the background by your lenovo.
However, sometimes, the issue is with the update itself. So you need to update it to the newer or older version manually. We have covered ots of ways to update google play service in detail. Do check that. And if you face any issue while updating it, check fixes.
6 Similar to restart, sometimes booting in the safe mode fixes various issues on an Android phone. Again, doing that will not delete you data and you can access it in safe mode as well. Running the lenovo in safe mode also helps in identifying the issues caused by the third-party apps.
I hope these will get you over your issue with ease.
Check the Battery charging mode. The device can only charge through the power adapter and may have shifted into the USB charging. If it shows USB charging, do the following.
Remove the USB connector from the Tab device and AC adapter from wall power outlet (Must need to remove both the ends).
Reconnect the USB cable and AC adapter to wall unit. Now check the charging mode, it shows charging with AC. Now the device can charge as normal condition.
If however it shows USB charging, do this step again by disconnecting the ports and reconnecting until you see the AC charging mode for Battery.
If the mode was correct, I'd test the charger unit for 5+ volts. It's possible it died.
To hard reset your tablet you will have to go to the recovery mode on your device and for that, you will have to Power Off your device and then click and hold on "Power and Volume Up or Down" for 2-4 seconds and after that you will feel a small vibration from your device and then leave the buttons and then you will see a recovery menu. Now using your Volume Buttons for Scrolling and Power button for selecting go to the Reset option and click on Power button and now it will ask for confirmation, click on Power button to confirm and after that, your device will do some operation and after that your device will reboot and it might take more than 4-5 minutes for the first boot so don't worry about that and now your device is successfully booted and everything is unlocked.
Is this your computer or someone else that had it before you?
If it is yours enter the email account and password for that before it was reset . If it was someone else that set this then it requires more work
You didn't provide you OS, so I'm going with Android 6.0.
Ajustes (Ajustes del sistema)> Sistema (Todos los ajustes)> Sistema> Idioma y entrada> Idioma
Slide down and choose Ingl?s. Then simply back up.
There is some useful way to fix it properly. But If you need the proper guidance you can easily visit the https://hpsupports.co/hp-support-assistant/ page.
