20 Most Recent Vtech VT-CS6114 Cordless phone w/ CID/ Call waiting Questions & Answers
After charging battery,the phone dial reads, out of range,or no pwr at base
Double check that the power cable is _fully_ plugged into the phone base, then check to see that power cable is fully plugged into wall outlet; and/or fully plugged into phone wall outlet. (Some base units have no power adapter and get their power from the phone outlet on the wall). In short, double check _all_ wired connections. Do not assume they are fully plugged in.
5/12/2020 7:27:11 PM • Vtech VT-CS6114... • Answered on May 12, 2020
How to delete a phone number from directory on a vtech dect 6.0
In the link https://www.google.com/search?q=delete+a+phone+number+from+directory+on+a+vtech+dect+6.0 Did you realise you are advertising your email address to the 12 MILLION annual viewers of this site. ..
12/19/2023 4:29:33 AM • Vtech Lands... • Answered on Dec 19, 2023
Vtech cordless landline phone When I make a call to someone the other person can't hear me but I can hear them? Please help me in how to fix. Thank you
Google make model manual you have 'Mute' set on it. All questions need 'make model (what it is)' as first 3 words. ..
12/19/2023 4:27:21 AM • Vtech Lands... • Answered on Dec 19, 2023
I live in South Africa. Ordered a vtech 2 handset phones, DS6621-2 on Amazon & it came with 12 volt charger for main cradle. Can I get 6 volt charger with the right fitting and if so, how?
You are heading at this from the wrong end. The power to the device from the charger remains the same. If the device runs on 12 volts, it needs 12 volts. South Africa runs on 230 volts, so if you bought a 110 volts version, you buy an adapter that takes 230 mains voltage in, and delivers 12 volts DC to the phone. The phone won't run on 6 volts. 230V South Africa operates on a 230V supply voltage and 50Hz. ..
12/19/2023 4:25:51 AM • Vtech Lands... • Answered on Dec 19, 2023
Why does the letter A stay in my window of my Vtech answering machine
Google make model manual It likely means the Answering system is set or not set. https://www.google.com/search?q=letter+A+in+window+of+Vtech+answering+machine 'make model (what is is)' in all questions, first 3 words please. ..
12/19/2023 4:19:55 AM • Vtech Lands... • Answered on Dec 19, 2023
2answers
Vtech cs6649 shows incorrect date and time on caller id
i like this site
12/4/2023 11:27:02 PM • Vtech Lands... • Answered on Dec 04, 2023
Deleting pre recorded answer message on vtech fs6424a
Remove greeting from the voicemail
12/4/2023 3:50:13 PM • Vtech Lands... • Answered on Dec 04, 2023
VTech CS5249 phone. How do I unmute the ringer?
Page 29 and 59 of the manual refers. Page 23 Point 16 is probably the reason. The Ringer Volume is at Zero. https://cdn-web.vtp-media.com/products/CS/CS5249/CS5249-X_WEBCIB_V2_210710.pdf a neat trick is to press CTRL+F on your computer and type 'ringer' and press Enter. There are 47 mentions of it. ..
10/24/2023 11:47:28 PM • Vtech Lands... • Answered on Oct 24, 2023
One handset on Vtech CS6919-2 has a loud buzz. I bought one CS-6919 to replace but but I cannot register it?
i can,t find my imei # for my vtech cordless landline phone. model #is cs6919-2 & the s/n is uf 203447732 all i can on the is these two numbers.i need the imei# to get it turn back on.can you help me please,please.please get to me [email protected]
10/23/2023 3:45:14 PM • Vtech Lands... • Answered on Oct 23, 2023
I have a VTech 6929 Phone system. I have tried everything in the manual instructions, but I cannot set up my mail box. I had it previously, and somehow it is gone. Can you help?
Question edited for clarity.This phone system has two features.Answerphone system which records messages to the unit.andVoice Mail System which is an extended (often paid) service from your telephone provider.Sometimes a glitch at the Telcom will remove your Voice Mail. You will need to phone their customer service number and ask why they stopped the service you previously enjoyed? They will be able to put it back in place.Page 32 refershttps://cdn-media.vtechphones.com/products/CS/CS6929/CS6929-X_WEBCIB_V3_20160224.pdfRetrieve voicemail from telephone service Voicemail is a feature available from most telephone service providers. It may be included with your telephone service, or may be optional. Fees may apply. Retrieve voicemail When you received a voicemail, the handset displays New voicemail and . To retrieve, you typically dial an access number provided by your telephone service provider, and then enter a security code. Contact your telephone service provider for instructions on how to configure the voicemail settings and listen to messages. NOTE After you have listened to all new voicemail messages, the indicators on the handset turn off automatically. Set your voicemail number You can save your access number on each handset for easy access to your voicemail. After you saved the voicemail number, you can press and hold to retrieve voicemail. Press MENU when the handset is not in use. Press or to choose Settings, and then press SELECT. Press or to choose Voicemail #, and then press SELECT. Use the dialing keys to enter the voicemail number (up to 30 digits). Press SELECT to save. You hear a confirmation tone. • 1. 2. 3. 4. 5. 33 Turn off the new voicemail indicators If you have retrieved your voicemail while away from home, and the handset still displays the new voicemail indicators, use this feature to turn off the indicators. NOTE This feature turns off the indicators only, it does not delete your voicemail messages. Press MENU when the handset is not in use. Press or to choose Settings, and then press SELECT. Press or to choose Clr voicemail, and then press SELECT. You hear a confirmation tone...
10/21/2023 8:04:01 PM • Vtech Lands... • Answered on Oct 21, 2023
Date and time not correct when listing to voice mail
Possible battery is down. Refer to page 58 of manual CS6529-4B_UM_V5_20141120.pdf (vtechphones.com) for further details.
9/15/2023 1:43:33 PM • Vtech Lands... • Answered on Sep 15, 2023
VTech LS1350-B. Shows 4 missed calls are coming up on the screen and I cant clear them. Its not allowing me to make a call when this is on it?
Question edited for clarity. Do a Reset on it.
Reset Your Phone - VTech LS1350-B User Manual [Page 20]
ManualsLib https://www.manualslib.com > ... > User manual VTech LS1350-B Manual Online: Reset Your Phone. You can reset your phone to the default settings. After reset, all settings and entries (except phonebook) ... ..
4/29/2023 6:42:02 PM • Vtech Lands... • Answered on Apr 29, 2023
3answers
Vtech T1300 LINE IN USE displayed when line not in use
The "LINE IN USE" error message on a Vtech T1300 telephone can indicate that there is a problem with the telephone line or the telephone itself. Here are a few things you can try to troubleshoot the problem:
  1. Check the telephone line: Make sure that the telephone line is properly connected to both the telephone and the wall jack. Unplug the telephone and plug it back in to ensure that the connections are secure.
  2. Check for a dial tone: Pick up the handset and listen for a dial tone. If there is no dial tone, the problem may be with the telephone line or the service provided by your telephone company.
  3. Check for a stuck button: Make sure that none of the buttons on the telephone are stuck. If a button is stuck, it can cause the telephone to think that the line is in use even when it is not.
  4. Check for a software issue: If all the above steps don't solve the problem, it could be a software issue with the telephone. You may need to reset the telephone to its factory settings or contact the manufacturer for assistance.
If none of these steps resolve the issue, it could be a problem with the telephone itself and should be checked by a technician or contact the manufacturer for support.
1/18/2023 6:39:24 AM • Vtech Lands... • Answered on Jan 18, 2023
I got a new VTech cordless and I tried to connect it the main console but asks for a four digit PIN to complete. What is that PIN number please?
Question edited for clarity. They all have model numbers. No model number so we guess! Manual Section 6.3.5 Change the System PIN Code A 4-digit system PIN code is used for changing the system settings of the base station. It is used to protect your phone against unauthorized use. The default system PIN code is 0000. ..
1/14/2023 4:42:54 AM • Vtech Lands... • Answered on Jan 14, 2023
How to turn up volume on vtech cordless phone
How do you put your ringtone back on your phone after you have muted it
11/12/2022 10:52:14 PM • Vtech Lands... • Answered on Nov 12, 2022
Vtech headset IS6200 keeps saying out of range and it will not pair to my vtech phone
Hi, Please double check that any battery in the phone has been updated within 3 months. Vtech also suggests using an outlet not controlled by a switch. Otherwise, please take time factory reset your Vtech device and check for the error again. Thank you.
11/1/2022 1:44:12 AM • Vtech Lands... • Answered on Nov 01, 2022
Why is my VTech 6.0 CS6124 go straight to voicemail on all incoming calls?
Hi, I found an online handbook manual for the VTech 6.) CS124. I noticed on Page 20 that you can set the number of rings on your answering system. Perhaps changing the number for incoming calls to a higher number might help. Here's the link to the manual. https://cdn-web.vtp-media.com/media/p/document2/products/%7BD1C79A59-7C89-415D-830F-D57B9ACB6F33%7D/CS6124_UM_2.pdf Hope this helps.
9/23/2022 6:57:00 AM • Vtech Lands... • Answered on Sep 23, 2022
Vtech VT-CS6114 Cordless phone w/ CID/ Call waiting Logo
1 questions posted
Top Vtech Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
Vtech Lands Phones
  • Vtech Lands Phones
Most Popular Question
after charging battery phone dial
  • Lands Phones
