20 Most Recent Toshiba DVD Recorder Questions & Answers
Scheduled a timer recording of a program on a
Hi,During timer recording adjustment you must have selected what ever you want to record..i.e: Tuner Channel , or ,Video1 input ,or Video 2 input etc..This problem is related with Source selection but not with - + type Disc..wrong disc will refuse to record at the beginning..
The noise and snow shows that your recorder was Recorded an unadjusted RF channel..thus no TV signal was available during recording ..
I assume that your DVD recorder has built in TV tuner in...To correct the problem,first you make an automatic Ch set up ,search the available channels either on the Cable (if you have ) or RF local channels thru Arial Antenna..
than you try to record again by carefully selecting ..you will record TV RF channels successfully. Or you can attach another video source to your Recorder thru the RCA cables on the back panel and by selecting the respective SOURCE in accordance withe cabling you have made than you will record the AV signals available on your Receiver..
If you need more help pls let me know for further advise.
8/13/2011 5:43:57 PM • Toshiba DVD... • Answered on Aug 13, 2011
DVD w ill not eject from my Toshiba DVD
You will have to change the loading tray drive belt. For which you have to remove the top cover and then unscrew 4 screws that hold the disc mechanism and turn it upside down.You will see a small belt on a pulley which has to be replaced. Do all this only if you have access to replacement belt. In some players if you look at the bottom under the drive mechanism you will find a ****. Insert a thin screwdriver and push a plastic lever in the direction indicated with an arrow. The loading tray will eject the disc. Only some models have this feature. You have not mentioned the model # of your player.
8/8/2011 2:58:07 AM • Toshiba DVD... • Answered on Aug 08, 2011
How can I play non region DVD on my Philips DVD
you can't play non regional dvds on it
5/25/2011 11:27:36 PM • Toshiba DVD... • Answered on May 25, 2011
This program is not recordable in +vr mode
This means exactly that these are copy Once only, meaning you can not make it copy say 10 copies, at the same time, it means you must do one a at a time. If you wanted say 10 copies, you must do the entire process over and over.
4/2/2010 4:39:43 AM • Toshiba DVD... • Answered on Apr 02, 2010
2answers
Philips dvdr3480 picture problem
swap the scart inputs around. See if that solves it
9/25/2007 12:09:05 AM • Toshiba DVD... • Answered on Sep 25, 2007
Toshiba 42RV500E sound issue
This is a known issue with this TV. The following might resolve it: Check Mute and Volume: Ensure that the TV is not muted and that the volume is set appropriately. Sometimes accidental button presses can lead to muted sound or low volume. Inspect External Speakers: If you're using external speakers, verify their connections. Loose cables or faulty speakers can cause sound issues. Test Different Inputs: Connect a non-HDMI device (such as a DVD player) to the TV. Observe if the sound distortion occurs. If it doesn't, the problem might be related to the HDMI signal from your Virgin box. HDMI Troubleshooting: If the issue persists with the DVD player over HDMI, consider the following: HDMI Cable: Check the HDMI cable for damage or loose connections. Virgin Signal: Contact Virgin to inspect the signal/lines and replace the box if necessary. Mainboard Replacement (if needed): If the sound distortion persists, it could be due to a faulty sound processor chip on the TV's mainboard. In this case, consider replacing the mainboard. TOSHIBA 42RV500E, 42RV500T, 42RV500Y, 46RV500E, 46RV500T User Guide (manualmachine.com)
4/7/2024 11:34:38 AM • Toshiba... • Answered on Apr 07, 2024
Toshiba 72HM195 has started getting red streaks
There may be loose contact or track open in main board.So try to check the main board thoroughly where you may find the loose of connection or track open.
3/25/2024 5:27:53 AM • Toshiba... • Answered on Mar 25, 2024
Change batteries on my toshiba se-r0001 remote
  1. Locate the Battery Cover: Look for the battery cover on the back of the remote control. It is usually a small compartment that can be easily opened.
  2. Remove the Battery Cover: Depending on the design, there may be a latch, screw, or sliding mechanism to secure the battery cover. Use your fingers or a small screwdriver to open the compartment.
  3. Remove Old Batteries: Take out the old batteries from the battery compartment. Pay attention to the orientation of the batteries, so you know how to insert the new ones correctly.
  4. Check Battery Polarity: Take note of the positive (+) and negative (-) signs inside the battery compartment. Make sure to insert the new batteries with the correct polarity to match these markings.
  5. Insert New Batteries: Place the new batteries into the battery compartment, ensuring they are properly aligned with the correct polarity. Press them down gently to make sure they are secure.
  6. Replace Battery Cover: After inserting the new batteries, close the battery compartment cover securely. If it has a latch or screw, make sure it is fastened properly.
  7. Test the Remote: Point the remote at the device it controls (such as a Toshiba TV) and test whether it responds to your commands. If the remote is working correctly, you have successfully replaced the batteries.
  8. Dispose of Old Batteries: If the old batteries are no longer usable, make sure to dispose of them properly. Many communities have designated recycling locations for batteries.
3/9/2024 3:29:56 AM • Toshiba... • Answered on Mar 09, 2024
I need a manual for my Toshiba 2010 tv serial # A10A13799C3300
Serial numbers don't work Judy https://www.google.com/search?q=A10A13799C3300 They are purely a numerical identifier of when it was made, year, day, number on the shift, whether it Joe or Billy who did final inspection. With a MODEL number I can find them easily with just 'make model manual'.
Owner's Manual
Toshiba http://www.toshiba.com > support > content PDF Thank you for purchasing this Toshiba LCD TV. This manual will help you use the many exciting features of your new LCD TV. Before operating your LCD TV, please. 62 pages
Owner's Manual - Integrated High Definition LCD Television
Toshiba http://www.toshiba.com > support > content PDF Thank you for purchasing this Toshiba LCD TV. This manual will help you use the many exciting features of your new LCD TV. Before operating your LCD TV, please ... 62 pages ..
3/2/2024 7:58:53 PM • Toshiba... • Answered on Mar 02, 2024
Toshiba GR-AG66MA-XK Inverter Refrigerator suddenly not cooling. Display (eco & quick freeze) keep blinking non stop.
This is somewhat experimental technology, although all fridges are basically inverters. The link suggests all sorts of things. https://www.google.com/search?q=Toshiba+GR-AG66MA-XK++eco+%26+quick+freeze+keep+blinking+non+stop ..
2/27/2024 7:12:55 AM • Toshiba... • Answered on Feb 27, 2024
Can I program a insignia remote NS-RC03A-13 to a Toshiba tv
No you can't the Insignia remote is for that model television only. Companies don't make their remotes so they operate other makes of televisions. Buy a Copy Remote for the Toshiba https://www.google.com/search?q=insignia+remote+NS-RC03A-13 ..
2/18/2024 7:20:13 PM • Toshiba... • Answered on Feb 18, 2024
Need a manual for Toshiba SE-R0295
That appears to be the model number for the remote control. You need the manual for the television. https://www.google.com/search?q=toshiba+se-r0295+manual ..
1/22/2024 11:59:30 PM • Toshiba... • Answered on Jan 22, 2024
Toshiba 47" flatscreen. Power up
The information provided suggests that there might be an issue with the main board of the electronic device. However, it's important to consider a few factors before deciding to replace the main board:
  1. Check for Error Codes or Diagnostic Signals: Some devices have error codes or diagnostic signals that can provide more specific information about the issue. Check the device's manual or documentation for any error codes or signals associated with the flashing LED or other symptoms.
  2. Perform a Hard Reset: Before replacing any components, try performing a hard reset on the device. This involves turning off the power, unplugging the device, and waiting for a few minutes before plugging it back in and turning it on. Sometimes, this can resolve temporary glitches.
  3. Consult Manufacturer Support: Contact the manufacturer's customer support or refer to the product's support resources. They may be able to provide troubleshooting steps specific to your device and guide you on whether a main board replacement is necessary.
  4. Professional Inspection: If you are not familiar with electronic repairs, consider consulting a professional technician. They can inspect the device, run diagnostics, and provide a more accurate assessment of the issue.
  5. Check Warranty: If the device is still under warranty, replacing components yourself may void the warranty. Check the warranty terms and conditions before attempting any repairs.
  6. Consider Other Factors: The issue might not solely be with the main board. Power supply issues, faulty connectors, or other components could contribute to the problem. A thorough inspection can help identify the root cause.
If, after considering these factors, you still believe that the main board is the likely culprit and you are comfortable with the replacement process, you can proceed with replacing it. However, exercising caution and exploring all available troubleshooting options is advisable before making any decisions.
1/17/2024 8:35:42 PM • Toshiba... • Answered on Jan 17, 2024
Please looking for a service manual for service code tv Toshiba 49l621U, main board SBB55T VTV L55730. Thanks.
Question edited for clarity and toss in some CAPS. Unfortunately there is no service manual online, you just replace boards. https://www.google.com/search?q=toshiba+49l621u+service+manual+pdf ..
1/4/2024 8:00:29 PM • Toshiba... • Answered on Jan 04, 2024
Toshiba 49L621U 49-Inch 4K LED Ultra HD TV. Looking for a Service Manual please?
Question edited for a lot more clarity and toss in some CAPS. Unfortunately there is no service manual online, you just replace boards. https://www.google.com/search?q=toshiba+49l621u+service+manual+pdf ..
12/10/2023 10:55:18 PM • Toshiba... • Answered on Dec 10, 2023
Toshiba DVD Recorder Logo
15 questions posted
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
play non region dvd philips dvd
  • Televison & Video
