20 Most Recent
Nokia E63 C3 C6 E5 N8) Questions & Answers
Whatsapp nokia e63
Hi saroj choudhary,I can help in this matter.So what you need to do is click on the link which i am giving below from your pc or from your mobile and download it.It will surely help you.ThanksNitinand plz vote fior me it this solution helped you.
My problem is what is
Password use 12345.
Or you can reset manually as describes below :
--- SOFT RESET (basic reset)
This option restores the .ini files from the ROM. Does not erase data (photos,videos, documents) or applications from a third party. Key Code *#7780# (clickthis combination of keys on the
keyboard in the mobile)
--- HARD RESET (total reset/formatting)
This option restores the original operating system from the ROM. Formats the C:partition and deletes all data including the memory card. Key Code *#7370#(click this combination of keys on the keyboard in the mobile).
You can also achieve Total Reset by pressing and holding down following keys:
* + 3 + Green Button (call) immediately after turning the mobile on.
Important: The battery must be full and the mobile device connected to thecharger. If during the course of reset, the mobile stop receiving electricityit can ruin the internal flash memory of the mobile device and stop function
If you feel helped, RATE please !
I want to edit my date of birth i made in a wrong
what i would do as im not sure you can change it once entered is back up anything you need from your phone including contacts and Restore to factory defaults, "OOB" it (Out Of Box state)
that will fix it but maybe as a last resort.
hope this helps, if so please vote for me.
I have bought a Nokia
It is not possible to install the N78 Blue tooth software onto your C6.Because blue tooth firmware is inbuilt in the Nokia OS.So you can install N78 OS in C6
N78: Symbian OS, S60 rel. 3.2
c6: Symbian OS v9.4, Series 60 rel. 5
See the OS version varies.
You have to buy a pairable version bluetooth with c6.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
I accidently locked my Nokia
your puk code is on the sim card your network provider will tell you the code no one else can,or you could try another sim card that may work.
regards
Restriction code for Nokia 2690
It is normally recommended you Don't post your IMEI on websites. It is a security code for that phone.
Usually the IMEI number has to be reset by your network provider. It normally cannot be done directly from the handset. Did the handset accept the new sim card. Some handsets can be locked to a specific network and changing network can stop your phone from working.
Nokia 2730C-1. can I unlock the network
If the phone was not used 2012, the phone number and phone have been deactivated from the network you used to pay for service. You need to set up a new contract as they expire after about 2 years of inactivity.
