20 Most Recent Toshiba 61H71 61" Rear Projection Television Questions & Answers
2answers
The clear plastic cover that covers my screen broke
There are several different sheets of plastic that cover your screen. The outside one is the screen protector, the middle one is the lenticular screen, and the inside one is the fresnel screen. All are available at Encompass.com
11/25/2016 7:00:51 AM • Toshiba 61H71... • Answered on Nov 25, 2016
Convergence IC of panasonic lcd
Hello, the i.c.'s are a STK-392-110E, there are also small Pico fuses that open up when the i.c.'s short. if you look on-line there are kits you can buy to replace the defective parts. oh and by the way your set is a projection set not an lcd type.tks
11/8/2013 2:24:01 AM • Toshiba 61H71... • Answered on Nov 08, 2013
Why is power light blinking
is it yellow as it blinks or red? if yellow check the kill switch located at the base of the lamp compartment cover ensure it presses the switch lever in order to ser the tv to standby mode the yellow blinking will stop and u will see a stable red ready for switching on
7/19/2013 12:59:13 AM • Toshiba 61H71... • Answered on Jul 19, 2013
0answers
Toshiba 61H71 tv will not
hi
yes there about 5 other more but they are very
small and light green ranging from 2 to 4 amps
on power deflection board
10/2/2010 5:24:27 AM • Toshiba 61H71... • Answered on Oct 02, 2010
Toshiba 61 rear projection, im not sure what wrong
When was this tv has it projection lamp last replaced?If 1 1/2 or 2 years.Tv on an used like 4 or 5 hours a day.The projection lamp life is over.Require change another projection lamp.U hear alot of clickings too?That mean the board call the Ballast board it also dead,and require changing too.This Ballast board,help to ignite the projection lamp.
8/14/2010 7:37:52 PM • Toshiba 61H71... • Answered on Aug 14, 2010
tip
Why my TV does not start up and remains in standby?
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem on dvd with no receiver box connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic chargesaccumulating on capacitors, or because of a wrong voltage read by themain chip on your monitor controller board. this started the protectioncircuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing statebecause of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
I have a convergence problem please help
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony2_bing.gif,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer2_bing.gif, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
4/14/2010 4:28:42 AM • Toshiba 61H71... • Answered on Apr 14, 2010
Very little sound comming from the speakers, and
so thats why we need 2 hear some sounds but
we noticed that the speakers are sio little 2
hear and the vibrations are so little functionings..
12/31/2009 5:27:52 AM • Toshiba 61H71... • Answered on Dec 31, 2009
My toshiba 61h71 has a reddish tint to it. Turned
A Reddish tint means that the Green signal is missing. Does the on screen menu look normal? If so, this points to the signal source. The fact that this happend suddenly, I would check your cables first.
Using YUV?
If the TV's Menu also looks reddish then there is an internal problem with the display.
Good luck
12/30/2009 6:22:27 PM • Toshiba 61H71... • Answered on Dec 30, 2009
The colors on my Toshiba HD rear projection TV have seperated
Try running the convergence option as described in the manual
http://www.tacp.toshiba.com/tacpassets-images/models/61h70/docs/61h70_om_e.pdf
12/28/2009 6:53:53 PM • Toshiba 61H71... • Answered on Dec 28, 2009
I have a 61H70 with red and blue lines everywhere
You might try running the convergence as described in the manual.
12/28/2009 6:51:26 PM • Toshiba 61H71... • Answered on Dec 28, 2009
Can not get the red & blue lines to align for
Ur convergence it dead,Must know how to solders?Buy a convergence kit,replaced what in that kit.Tries Tv Repair World.com,Tvrepairkits.com.
12/23/2009 4:18:09 AM • Toshiba 61H71... • Answered on Dec 23, 2009
Whats the diference between version letters on power board
The parts available list for your 61H shows PD00764 version C as the deflection board for this particular model, it might be that version A would go to a smaller size screen model, toshiba manufactured a 43" and a 53" with this 61" also. So back to your question, all I can say is , if you already have the A version I would compare to version C and keep in mind the connectors(plugs) make sure they are a like, I would imagine that the only diference you would see in the picture would be picture width and vert size. A good idea would be to contact a module rebuilding company(tristate module for example) and get their opinion.
9/5/2009 11:18:53 PM • Toshiba 61H71... • Answered on Sep 05, 2009
2answers
I have a Toshiba 61H71 that keeps blowing F850.
Resolder jumpers on signal PCB..May be near convergence IC circuit..on 50" model they are 050 & 010. You may have solder cracks..I repaired a 50" toshiba..Let me know if this fixes
5/6/2009 6:25:57 PM • Toshiba 61H71... • Answered on May 06, 2009
The red power on light just blinks. Tried leaving it unplugged. Still didnt work
Ours was doing the same thing, we changed 3 little black fuses in it and it works. I do believe they are 5 amp but not positive, we found them through a tester. When I have the exact answer for u I will email u again sorry u have had no response till now probably does you no good now..It's been awhile since they were changed.
3/24/2009 4:52:53 AM • Toshiba 61H71... • Answered on Mar 24, 2009
Toshiba 61H71 61" Rear Projection Television Logo
Popular Tags
38 questions posted
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
very little sound comming from speakers
  • Televison & Video
