20 Most Recent Blackberry BERRY Z10 16GB FACTORY Unlocked GSM 2G 3G 4G LTE MODEL NO : RFH121LW GSM 2G & 3G 850/900/2100 & 4G LTE 800/900/1800/2600 Black Questions & Answers
I don't think so....it does not support CDMA.So once you have unlocked you can swap with other GSM providers only.There are many unlock providers like Prounlocking.com to unlock your phone permanently.
Blackberry BERRY... | Answered on Aug 30, 2017
It depends on your batterie's cells sometimes they die early if you don't or do use ya phone they will eventually die
Blackberry BERRY... | Answered on Sep 04, 2014
Hi. You can unlock your UK Orange network locked Blackberry Z10 safer and easier using unlock code. You can get the accurate unlock code for your Blackberry Z10 from ProUnlocking.com at affordable cost. Good luck.
..............UNLOCKING INSTRUCTIONS..............
1 - Switch ON your Blackberry Z10 with your current network/service provider's SIM card.
2 - Using the menu go to Settings Menu -> SIM card and press select.
3 - While holding the SHIFT key, type mepd.(NOTE: You may not see any text appear on the screen while typing mepd)
4 - You should now see the five locking categories listed.
5 - While holding the SHIFT KEY, type mep2.(NOTE: You may not see any text appear on the screen while typing mep2).
6 - Release the shift key.
7 - You will now be prompted to enter the Network MEP code. (it will also state how many attempts left)
8 - Enter the Unlock Code.
9 - Enter Return/Enter.
10 - The Blackberry Z10 should then be unlocked.
Blackberry BERRY... | Answered on Aug 05, 2014
A SIM lock is applied by the cellular provider that owns the phone. It is locked at firmware level and uses a 128bit RSA Encrypted password and is impossible to crack. You can only get the code by contacting them and sorting out the problem..
Blackberry Cell... | Answered on Aug 02, 2019
You can find a step by step guide on how to hard reset your phone here :
How to restore your BlackBerry Z10 when it won turn on
Blackberry Cell... | Answered on May 23, 2019
You must use the Blackberry desktop software.
Blackberry Cell... | Answered on May 11, 2019
This kind of work can be done by service engineers only... kindly do not work around it. may be handset OS get damage.
Blackberry Cell... | Answered on May 06, 2019
You Need to re-install BB Software on PC and reboot device.
I`m think the only way to unlock phone is a hard reset (You can loose all data on phone). Below is link for guide: https://hardmasterreset.com/464-2/
Blackberry Cell... | Answered on Apr 02, 2019
If it is not available in the BB store(its not) then you need to search for the apk on the internet which you may not find, and if As long as they support android 4.3, it will run on your device with some glitches. that means you need to have 4.3 running on your device. it may be possible however may not be worth what you have to go thru to MAYBE be able to use a crummy version of it. Best of luck
Questions? Just ask
Mr.Mike
https://www.6ya.com/mr.mike
Blackberry Cell... | Answered on Jan 31, 2019
flash/load developer RIM using its autoloader but some apps like gallery will be missing so you need to get some from app world.
get RIM from this site
http://developer.blackberry.com/blackberry10devalpha/allautoloaders.html
Goodluck
Blackberry Cell... | Answered on Jan 24, 2019
Blackberry BERRY Z10 16GB FACTORY Unlocked GSM 2G 3G 4G LTE MODEL NO : RFH121LW GSM 2G & 3G 850/900/2100 & 4G LTE 800/900/1800/2600 Black Logo
7 questions posted
Top Blackberry Cell Phones Experts
raysaw
Andrew Taylor
Andrew Taylor
matt
matt
Are you a Blackberry Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
  • Blackberry Cell Phones
Most Popular Question
get amp t z10 blackberry sim card
  • Cell Phones
