20 Most Recent Toshiba 50HDX82 50" Rear Projection Television Questions & Answers
2answers
How to connect headphones if tv doesn't have a jack
yes. go to radioshack and explain situation. They should have an adapter for it.
12/15/2015 9:07:17 PM • Toshiba 50HDX82... • Answered on Dec 15, 2015
DVI to HDMI
HDMI and DVI use the same encoding scheme for video purposes- the only difference is HDMI can carry audio signals and therefore have different connectors- so it is not like the lack of a picture signal is because you are using two different cables (HDMI and DVI). In theory the DVI to HDMI adapter should work. Is there a possibility that the adapter is defective? Any bent or missing pins? How long are the cables? If they are of poor quality, a digital signal can be lost at 20 feet. Again, in theory. The only other thing I can thing of, off the top of my head is to ask, did you change the input selection on your t.v.'s display screen to go from the input source that you get your t.v stations from... to the input source of the Play Station?
11/27/2013 8:08:00 AM • Toshiba 50HDX82... • Answered on Nov 27, 2013
Strong signal, but distorted image. Started by
TOSHIBA IS A GREAT TV!! SOUNDS LIKE A CONVERGENCE PROBLEM, IF IT IS, MAYBE $300 + REPAIR, FIND HONEST TV TECH. GOOD LUCK
11/17/2013 7:06:17 AM • Toshiba 50HDX82... • Answered on Nov 17, 2013
Toshiba 50HDX82 Problems: chronic-wiggly lines
I have sent via Pando this morning...
Bill
6/23/2012 3:57:18 PM • Toshiba 50HDX82... • Answered on Jun 23, 2012
How do I replace the mirror on a toshiba 50hdx82 ?
Carefully would be the first thing I would say.The entire front screen unit with its frame comes off from the front of the set and the mirror is attached to the back wall of the set behind it.If it broke be careful that it did not make scratches on the inside of the screen---they will stand out like a sore thumb it it did.With gloves (not a bad idea to have a helper) it is attached with strips on at least two sides.If you get that far make sure no finger prints (gloves ) when you install the new mirror.Also if it broke get all the pieces out as light from the new mirror will reflect on the broken mirror parts and show in the picture---seen this more than a few times.Let me know if you have questions.
3/17/2012 3:24:39 AM • Toshiba 50HDX82... • Answered on Mar 17, 2012
4answers
Toshiba 50HDX82 50 in. Rear Projection Television-HDMI to my TV?
HelloYou have to buy one converter box. Your TV does not accept or process HDMI signals.
12/19/2011 1:43:11 AM • Toshiba 50HDX82... • Answered on Dec 19, 2011
Tv shut off wont come back on makes clicking
It seems that Tv works for some time and then shuts off, if so it can be due to a thermal shunting and then it seems to hop around trying to start up with a clicking noise.You need to start by checking on this clicking noise, once this is confirmed it will be relative of the fault.perhaps it can be due to some loose links, dirt or shorting due to moisture in HT or a trip due to overload or chnages in the +B. All these means that you need to check the board for the correct voltage feed and see if there is any issues.
11/7/2011 10:45:55 AM • Toshiba 50HDX82... • Answered on Nov 07, 2011
My Toshiba 50HDX82 screen is
The only way to get this fix, is replacing the defectives convergence IC's.
8/23/2011 4:12:55 AM • Toshiba 50HDX82... • Answered on Aug 23, 2011
Yes i have a toshiba
The key here is that in PIP mode it looks fine. This is a sign that your hypermodule has gone out. If you goto www.TvRepairKits.com they will likely have a repair kit for this model.
6/11/2011 3:15:32 AM • Toshiba 50HDX82... • Answered on Jun 11, 2011
Toshiba 50HDX82 projection TV has started
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
5/9/2011 1:51:46 AM • Toshiba 50HDX82... • Answered on May 09, 2011
2answers
I HAVE A TOSHIBA 50HDX82 WHEN TURN ON ITS KIND OF
try give me idea of problem, is picture 3d looking or what?
I am here to help
SD TECH
5/1/2011 9:08:25 PM • Toshiba 50HDX82... • Answered on May 01, 2011
2answers
The TV screen flickering when
This is typical with many sets when it goes old as there is a high possibility that the components over a period of heating and cooling , tend to bring on a problem of dry soldering. So my advice is to check the set for some loose joints that have played on to give you these erratic shut downs.
Remove main plug, the covers - with caution of high voltage, check for dry joints, use a good soldering iron to solder all suspected points. Please find below a link for tips on poor start ups, as if the set is totally failed the SMPS might be faulty
SLow start ups
11/19/2010 5:41:15 AM • Toshiba 50HDX82... • Answered on Nov 19, 2010
There is a faint buzzing sound coming from the
I know this will sound stupid but try it, unplug just power cord, leave it unplugged for 2 hours then plug it back in. This will reset it to factory setting and if this issue was caused by a power issue it will fix it.
11/9/2010 10:00:54 PM • Toshiba 50HDX82... • Answered on Nov 09, 2010
2answers
So the colours match up on the left hand side of
The "Hyper board" known as the tv convergenece board,it dead.Any colors lines R,G,B mis alingnment anywhere in the picture,have colors shadows pictures or 3D pictures.The tv convergence board have 2 STK convergence ICS and some or all it resistors are dead.These parts,must be changed on the tv convergence board,to solved tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
10/13/2010 9:01:19 PM • Toshiba 50HDX82... • Answered on Oct 13, 2010
I have a toshiba 50hdx82
In the power supply by T400 look for bad resistor (R411) 4.70ohms CK the Hori out put transistor make sure it is not shorted.
Encompass Parts Distribution Has Free Service Manual that you can Print out online Google to their website and type in your Model # 1-800-638-3328
Let me know if you need anymore Help.
9/27/2010 7:22:05 PM • Toshiba 50HDX82... • Answered on Sep 27, 2010
I have a toshiba tv
Look in ur remote control see a button said CC turn all CC1,2,3 off and goto menu turn Text1,2,3 all off.U should have no more black boxes.
9/12/2010 3:41:09 AM • Toshiba 50HDX82... • Answered on Sep 12, 2010
2answers
I have an Toshiba 50HDX82, the entire screen looks
you may need to go to service mode and shif the horz center
7/31/2010 8:26:24 PM • Toshiba 50HDX82... • Answered on Jul 31, 2010
Toshiba 50HDX82 50" Rear Projection Television Logo
Popular Tags
72 questions posted
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
replace mirror toshiba 50hdx82
  • Televison & Video
