20 Most Recent Toshiba 42H82 42" Rear Projection HDTV-Ready Television Questions & Answers
0answers
What does the hyperboard look like
12_22_2012_1_46_12_pm.jpgThe actual board is in a box, careful the four metal pins must be un-soldered to remove the unit from the main board.
12/22/2012 1:47:04 PM • Toshiba 42H82... • Answered on Dec 22, 2012
0answers
Hyper board
Be the first to answer 12/14/2012 2:26:23 PM • Toshiba 42H82... • Posted on Dec 14, 2012Be the first to answer
Pip module location in 57h82
issue is most likley on hyper board
10/16/2012 12:07:25 AM • Toshiba 42H82... • Answered on Oct 16, 2012
4answers
Toshiba 42H82 problem
bad capacitors on the hyper module. there are 11 surface mount capacitors that need to be replace and that should fix it. the caps themselves only cost around $14 for all of them together
7/23/2012 3:59:09 AM • Toshiba 42H82... • Answered on Jul 23, 2012
It has shrunk to about 6 inches all the way around the screen so the total picture sizr is 36 inches instead of the 42 inches otherwise clear picture little fuzzy when turning on but becomes a clear
Don't know what wires your using to connect to tv. It does matter, sometimes the connections go bad, either at the tv or cable box. Have you tryed to stretch picture in settings?
2/10/2012 1:18:45 AM • Toshiba 42H82... • Answered on Feb 10, 2012
Toshiba 42H82 the screen will go black after 5 minutes, sometimes it comes back on after a minute, but most of the time I have to turn it off for about 10-20 minutes. Some days it works fine, others i
Hi.It is probably a defective ballast board or a faulty PSU. The ballast is the high voltage power board connected to the lamp.The PSU is the board that supplies power in different voltages to the other internal parts. One of the DC lines from PSU goes straight to the ballast. The repair is done testing the voltage from PSU to ballast. The job must be done by a technician.
12/15/2011 7:06:09 AM • Toshiba 42H82... • Answered on Dec 15, 2011
Touch focus error blue
The tv HYPER board it is dead aslo known as a tv convergence board.Tv have a convergence problems,it is dead.Tv Magic Focus button no longer response give error messages.Tv have any colors lines R,G,B mis alignments,have colors shadows pictures or 3D picture look alike?Yes,than the tv HYPER board it is dead also known as a tv convergence board must have it components parts replaced like 2 STK convergence ICS and some or all of resistors too.To fixed the tv HYPER also known as a tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
8/12/2011 5:57:45 PM • Toshiba 42H82... • Answered on Aug 12, 2011
2answers
Focus Error I am getting
Replace Convergence ICs ,Big black ICs will have PN# on them example STK 392-110
Mats has ICs 1-800-628-1118
6/5/2011 11:08:26 PM • Toshiba 42H82... • Answered on Jun 05, 2011
E blue is way out of convergence.... the adj only
yes. but have a pro do it or you will cause more problems.
2/26/2011 6:51:26 PM • Toshiba 42H82... • Answered on Feb 26, 2011
My 42H82 picture works but fuzzy...Letters in menu
hi,
ur tvs crt sockets have some problem. change the three crt sockets at the same time . also check for screen voltages of crt's. increase it slightly. there will be three independent screen voltage adjustments for each gun.
ok
12/23/2010 4:55:23 AM • Toshiba 42H82... • Answered on Dec 23, 2010
2answers
I have a few horizontal wavy lines at the top of
yes it is, your hyper board has bad caps and they will just get worse and worse. you can run it on an HD signal to keep it going longer but eventually even the HD will have the wavy lines too.. basically the hyper board needs new 10uf 16v surface mount capacitors, replace all those and your golden, but its a difficult repair, even for a educated and seasoned electronics tech, estimate from repair shop will run you $250-$550
if you can solder surface mount, you can fix it yourself for like $20
let me know if I can provide further assistance
9/10/2010 5:16:12 PM • Toshiba 42H82... • Answered on Sep 10, 2010
Remote not works sometime, doesn't
replace
9/3/2010 5:28:48 PM • Toshiba 42H82... • Answered on Sep 03, 2010
I'm getting a red outline on people's silhouette.
Look on your Convergence board the one that has your STK iCs STK392-110s their should be 6 resistors all 1.8 ohms Mats Elctronics has Parts for this TV 1-800-628-1118 more then likely you have a bad resistor that controls the red.
7/2/2010 10:25:03 AM • Toshiba 42H82... • Answered on Jul 02, 2010
Hi my toshiba tv is jumping and flickering i have
To things it could be connection problems in your cables, or your color wheel inside the set is in need of replacing.
5/4/2010 1:50:28 AM • Toshiba 42H82... • Answered on May 04, 2010
Image is out of focus and pulsating green lines around some image
yes it is repairable will not be cheap.a tech will have to do the convergence inside the tv,the remote only does so much.i have had 3 in the past and when they get older they become dull,i would not by rear projection any more years going back that was the only choose you had for a big screen ,now lcd and plasma have come down in price i would be looking at that if i was you.
4/26/2010 7:07:20 AM • Toshiba 42H82... • Answered on Apr 26, 2010
Television was working fine until last night,
No. Individual components have to be replaced by soldering.
4/19/2010 8:08:58 PM • Toshiba 42H82... • Answered on Apr 19, 2010
My picture is wavy and out of focus. when i touch
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
4/17/2010 2:51:10 AM • Toshiba 42H82... • Answered on Apr 17, 2010
Toshiba 42H82 42" Rear Projection HDTV-Ready Television Logo
56 questions posted
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
toshiba 42h82 problem
  • Televison & Video
