20 Most Recent
Toshiba 57H84 57" Rear Projection HDTV-Ready Television Questions & Answers
Hd picture too wide
If you are using a cable box you need to look on your cable remote for HD ZOOM or you can try the # sign on the remote. This should change your screen size and get you taken care of.
Hdmi error
u need a tech to help u the hdmi is corrupted and needs debugging a tech will use a pc set the hdmi
Have 57 " Toshiba projection TV there is way too much red in picture
TV has 3 CRTs, red, blue, green. Its possible that you have a bad blue or green crt. If that were the case the red would be prevalent and the pic would be reddish. The tv has a picture "level" adjustment that if done correctly could get it looking correct. Its probably best to have a tech. do it since you can make it worse if you do not know what you are doing, also there are high voltages present. Good luck
How to remove subtitles from sony bravia tv screen
You can download the user manual here.
http://www.retrevo.com/support/Toshiba-57H84-TVs-manual/id/311ag813/t/2/
The closed caption feature has two options:
• Captions—An on-screen display of the dialogue, narration, and sound effects of TV programs and videos that are closed captioned (usually marked as “CC” in TV listings).
• Text—An on-screen display of information not related to the current program, such as weather or stock data (when provided by individual stations).
To view captions or text:
1. Tune the TV to the desired program.
2.Press MENU, and then press x or • to display CUSTOM menu.
3. Press y or z to highlight CC, and then press ENTER.
4. Press y or z to highlight CAPTION or TEXT, and then press Enter.
To turn off the Closed Caption feature:
Highlight OFF in step 4.
My toshiba 57 inch rear
THis could be one of the CRTs (Color Tubes) is bad or the high voltage is leaking somewhere.
Toshiba projection TVs have history of yoke problems.
My guess is one of the CRTs is arcing inside. This TV has 3 CRTs red, green and blue. Replacing a CRT is not easy or cheap to buy if you can find it. If you like this try calling a TV technician to track down the high voltage arcing. DO NOT TRY TO DO THIS BY YOURSELF.
Best of luck my friend.
AAA TV SERVICE
Hello, I have a Toshiba
I am 100% sure that this is not an issue with the CRT board(the tiny board attached behind the CRT's in this case the blue CRT). The problem is usually caused due to failure of high value resistors 500K-ohm or higher. Do you have an ohom-meter and know how to use it? Do you know how to read resistor color-codes?
I just bought a used
If your TV looks 3D, warped, or distorted it likely has a convergenge problem. If however it just looks dull, washed out, redish, or if it looks like objects on the screen have halos the fluid in the lens has soured. You can search google for parts or you can get the parts with repair instructions from sites such as
www.TvRepairKits.com
There are Horizontal waves on
You need to replace both convergence ICs These are the chips that basically build your picture. Not expensive and and easy repair. Very common on these sets.
Convergence" in terms of television describes when the three projectors in a TV that produce color fall out of sync with each other. You'll know a TV with bad convergence when you see it--colors aren't meshing and are represented as thick lines, and everything seems blurry. Adjusting the convergence on a Toshiba television isn't difficult; there is a setting in the menu that you can calibrate. When that doesn't correct the issue, fixing the convergence on a Toshiba television can be quite a bit harder.
Disconnect your television from all peripheral devices (DVD players, cable boxes) and the wall. Move your TV out from the wall far enough where you'll have room to move around, and remove the back panel.
Find the PC board. This is the device containing all the components that tell your TV how to operate, and it looks very similar to a standard motherboard found on a personal computer.
Locate the convergence chips. There will be two of them, and they'll be plugged into sockets and screwed securely into place on the PC board. Unscrew them from the board and pull them off.
Put your new convergence chips in the slots where the old ones were found. Depending on your model of Toshiba television, this may require some soldering to get them in place. Screw them securely onto the PC board using the screw from the old chips.
Put the back panel back onto the TV. Once you've replaced the convergence chips, you can now move your TV back against the wall, turn it on and calibrate your convergence chips using the on-screen directions through your TV's main menu.
No picture, the little red
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this help in solving the problem.....
