20 Most Recent
Lexmark 4079 plus Color Jetprinter - printer - color - ink-jet Questions & Answers
Windows 10 driver for a Lexmark 4079 printer
No marketing technical support so to see it no drivers for windows 10 maybe the model is over time out dated
If there was no driver build above XP its a problem.
Use Lexmark driver
Note: Print drivers for Windows 10 may not be immediately available. In the meantime, you may use Windows 8 or 8.1 driver packages for Windows 10 supported printers.
How and where do I install memory cards?
www.
lexmark.com/publications/pdfs/2007/.../v7649663_en.pdf
LexmarkSetting up the printer as a copier only. ... Installing the optional XPS driver (Windows Vista users ...... Do not pinch the power cord between objects such as furniture .....Transfer photos and documents from a memory device to the computer over .... cSelect the print quality, the number of copies to print, the type of paper to be ...
www.
lexmark.com/publications/pdfs/2007/.../v7677571_en.pdf
LexmarkSetting up the printer as a copier only or fax only. .... Installing the optional XPS driver (Windows Vista users only). .... Information you will need to set up the printer on a wireless network................................................... ...... Inserting a memory card .Missing: c
How can I fix the missed OCR in Lexmark x3550 printer
Quite often the OCR portion is a third party software product and Lexmark cannot offer it as a download. Your best bet is to contact Lexmark customer support to see if they can help, but be advised they may want to charge for the disk.
