20 Most Recent Toshiba CZ27V51 27" TV Questions & Answers
5answers
TV not coming on...
The same thing happened with my T.V. (although it is an RCA). The first time a repair man charged me $75.00 to fix. The next time we were told to just try unplugging it for a few minutes then plug back in...that worked. T.V. still sometimes does this, unplugging it fixes the problem
4/12/2014 2:53:58 PM • Toshiba CZ27V51... • Answered on Apr 12, 2014
manual
Quisiera saber que numero es el fly back de tv toshiba cz27v51
ustede debe abril el chasis del TV, y ver el numero del Flyback.o ver el catalogo de repuesto. o llamar a Toshiba de USA, y tengael numero de parte.Dios le bendiga.
10/12/2012 11:33:28 AM • Toshiba CZ27V51... • Answered on Oct 12, 2012
I am not getting any picture or sound
In other words, your TV is in dead condition now. You must start troubleshooting from its main power supply regulator section itself. If you have sound knowledge in electronics, inform me. Without knowledge and experience, it will be fatal to try to repair main power supply section circuits, since, most of the components on this section will he [Hot] during power On. Without applying main power, it is impossible to go forward too.
7/30/2012 11:38:51 AM • Toshiba CZ27V51... • Answered on Jul 30, 2012
The picture gets darker and
I'm sorry to tell you but this is caused by the aging of tube. There's nothing more that can be done to save this tv, time for a new one.
8/18/2010 3:49:10 PM • Toshiba CZ27V51... • Answered on Aug 18, 2010
TV picture jiggles frequently. Cable service. Is
Mine did this...jiggle the cable imput and watch the picture to see if it flashes. Mine did so..the cable imput is the prob
9/23/2009 10:54:40 PM • Toshiba CZ27V51... • Answered on Sep 23, 2009
TV Picture Pops In and Out Toshiba Color TV CZ27V51
mine was doing the same thing. If i put pressure on the cable input from left or right it would fix this.
9/23/2009 10:53:29 PM • Toshiba CZ27V51... • Answered on Sep 23, 2009
Do Ineed a converer to receive digital tv signals ?
Your TV has an ATSC tuner and will receive over-air HDTV reception available in your area with an antenna.
1/27/2009 3:29:04 AM • Toshiba CZ27V51... • Answered on Jan 27, 2009
Remote control
is it a universal remote? you may have to reprogram it. there may be a website with all the codes.
1/25/2009 10:28:58 PM • Toshiba CZ27V51... • Answered on Jan 25, 2009
TV Tuner failure after warm up
Check where the F connector is soldered inside the tuner circuitry, it may have a loose solder joint there. Also check the inside of the connector where the coax is attach, sometimes the inside conductors spreads and do not make good electrical contacts.
Good Luck.
6/20/2008 2:23:19 AM • Toshiba CZ27V51... • Answered on Jun 20, 2008
No sound or tv signal
Probably need the TUNER either fixed or replaced.
4/30/2008 11:45:46 AM • Toshiba CZ27V51... • Answered on Apr 30, 2008
3answers
COld Solder/Short
The silver box where the cable plugs into is the TUNER,there are no fuses in there and the problem is not likely to be there,the loose conection could be anywhere but you have a few places to check,with the tv unplug from the wall you can safely check for loose conections in the power supply area and around the output transistor including the areas of the horizontal drive circuit and output transformer,those are the areas most likely to the symptoms you have but you can also check the edges of the chassis for a broken or crack board.Let Us know if you need more help.Be careful when you are checking for conections.
12/2/2007 4:12:19 AM • Toshiba CZ27V51... • Answered on Dec 02, 2007
Toshiba 42RV500E sound issue
This is a known issue with this TV. The following might resolve it: Check Mute and Volume: Ensure that the TV is not muted and that the volume is set appropriately. Sometimes accidental button presses can lead to muted sound or low volume. Inspect External Speakers: If you're using external speakers, verify their connections. Loose cables or faulty speakers can cause sound issues. Test Different Inputs: Connect a non-HDMI device (such as a DVD player) to the TV. Observe if the sound distortion occurs. If it doesn't, the problem might be related to the HDMI signal from your Virgin box. HDMI Troubleshooting: If the issue persists with the DVD player over HDMI, consider the following: HDMI Cable: Check the HDMI cable for damage or loose connections. Virgin Signal: Contact Virgin to inspect the signal/lines and replace the box if necessary. Mainboard Replacement (if needed): If the sound distortion persists, it could be due to a faulty sound processor chip on the TV's mainboard. In this case, consider replacing the mainboard. TOSHIBA 42RV500E, 42RV500T, 42RV500Y, 46RV500E, 46RV500T User Guide (manualmachine.com)
4/7/2024 11:34:38 AM • Toshiba... • Answered on Apr 07, 2024
Toshiba 72HM195 has started getting red streaks
There may be loose contact or track open in main board.So try to check the main board thoroughly where you may find the loose of connection or track open.
3/25/2024 5:27:53 AM • Toshiba... • Answered on Mar 25, 2024
Change batteries on my toshiba se-r0001 remote
  1. Locate the Battery Cover: Look for the battery cover on the back of the remote control. It is usually a small compartment that can be easily opened.
  2. Remove the Battery Cover: Depending on the design, there may be a latch, screw, or sliding mechanism to secure the battery cover. Use your fingers or a small screwdriver to open the compartment.
  3. Remove Old Batteries: Take out the old batteries from the battery compartment. Pay attention to the orientation of the batteries, so you know how to insert the new ones correctly.
  4. Check Battery Polarity: Take note of the positive (+) and negative (-) signs inside the battery compartment. Make sure to insert the new batteries with the correct polarity to match these markings.
  5. Insert New Batteries: Place the new batteries into the battery compartment, ensuring they are properly aligned with the correct polarity. Press them down gently to make sure they are secure.
  6. Replace Battery Cover: After inserting the new batteries, close the battery compartment cover securely. If it has a latch or screw, make sure it is fastened properly.
  7. Test the Remote: Point the remote at the device it controls (such as a Toshiba TV) and test whether it responds to your commands. If the remote is working correctly, you have successfully replaced the batteries.
  8. Dispose of Old Batteries: If the old batteries are no longer usable, make sure to dispose of them properly. Many communities have designated recycling locations for batteries.
3/9/2024 3:29:56 AM • Toshiba... • Answered on Mar 09, 2024
I need a manual for my Toshiba 2010 tv serial # A10A13799C3300
Serial numbers don't work Judy https://www.google.com/search?q=A10A13799C3300 They are purely a numerical identifier of when it was made, year, day, number on the shift, whether it Joe or Billy who did final inspection. With a MODEL number I can find them easily with just 'make model manual'.
Owner's Manual
Toshiba http://www.toshiba.com > support > content PDF Thank you for purchasing this Toshiba LCD TV. This manual will help you use the many exciting features of your new LCD TV. Before operating your LCD TV, please. 62 pages
Owner's Manual - Integrated High Definition LCD Television
Toshiba http://www.toshiba.com > support > content PDF Thank you for purchasing this Toshiba LCD TV. This manual will help you use the many exciting features of your new LCD TV. Before operating your LCD TV, please ... 62 pages ..
3/2/2024 7:58:53 PM • Toshiba... • Answered on Mar 02, 2024
Toshiba GR-AG66MA-XK Inverter Refrigerator suddenly not cooling. Display (eco & quick freeze) keep blinking non stop.
This is somewhat experimental technology, although all fridges are basically inverters. The link suggests all sorts of things. https://www.google.com/search?q=Toshiba+GR-AG66MA-XK++eco+%26+quick+freeze+keep+blinking+non+stop ..
2/27/2024 7:12:55 AM • Toshiba... • Answered on Feb 27, 2024
Can I program a insignia remote NS-RC03A-13 to a Toshiba tv
No you can't the Insignia remote is for that model television only. Companies don't make their remotes so they operate other makes of televisions. Buy a Copy Remote for the Toshiba https://www.google.com/search?q=insignia+remote+NS-RC03A-13 ..
2/18/2024 7:20:13 PM • Toshiba... • Answered on Feb 18, 2024
Need a manual for Toshiba SE-R0295
That appears to be the model number for the remote control. You need the manual for the television. https://www.google.com/search?q=toshiba+se-r0295+manual ..
1/22/2024 11:59:30 PM • Toshiba... • Answered on Jan 22, 2024
Toshiba CZ27V51 27" TV Logo
18 questions posted
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
tv picture pops in out toshiba color tv
  • Televison & Video
