20 Most Recent
Samsung UN60EH6003F 60" LED TV 1920x1080, 240 Hz, HDTV Questions & Answers
How do I fix horizontal thin lines across the screen?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
11/22/2016 11:12:30 PM •
Samsung...
Answered
on Nov 22, 2016
No picture only sound on samsung tv
Test it this way. With the TV on and receiving a program, shine a flashlight on the screen If you can observe a faint picture then the T-Con board is working correctly but the back light ballast is not. Some models incorporate the ballasts on the power supply board. Others are on a separate board. Go here to get the correct parts to fix your TV
TV Parts Universal TV Stands DLP Chips ShopJimmy
8/11/2016 6:24:29 PM •
Samsung...
Answered
on Aug 11, 2016
I have a Samsung UN60EH6003F When I plug the TV in it takes 1-10 minutes for the standby to light up. Once it's lit it works until it's powered off, then it needs to be plugged in again.
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
8/6/2016 2:09:33 AM •
Samsung...
Answered
on Aug 06, 2016
No video only audio on samsung tv
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
3/22/2016 7:45:45 PM •
Samsung...
Answered
on Mar 22, 2016
Samsung le26a6 will not switch on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty.
