20 Most Recent
Samsung 7100 Series UN46F7100AF 46" LED Smart TV 1920x1080, 240 Hz, HDTV, 3D Questions & Answers
How do I fix a washed out picture problem on my 46 inch samsung series 7100 led tv?
The common cause of this issue is down to a board that connects the screen to the main circuit video board of the tv. It is usually located top middle of the tv and has 2 white ribbon type wires coming from the top and is normally covered in a metal shield.
There will be a part number on the circuit board, this will be the one to find online which matches your screen. If you got an identical tv with another fault, it may not have the same part as each combination is different depending on the manufacturing line or part revisions.
The part you are looking for is called the T-Con board . Hope this helps.
Samsung le26a6 will not switch on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty.
