Hi there!
You can follow these steps to set the date:
1. Press the right navigation key and press 7.
You should see "SET MODE 1-8"
"ENTER NO. OR "V ^"
2. Press 1 for
You should see "1. User Parameters?"
"PRESS SET TO SELECT"
3. Press Copy/Set Key
You should see "DATE & TIME"
DD-MM-YYYY HH:MM
4. Enter the new Date & Time. You can use the dial pad to enter the values & move the cursor using the navigation keys. If you make a mistake, use to move the cursor over the incorrect number, then overwrite it with a correct one.
5. Press copy/set Key then press the STOP Key
Hope this helps!
Please rate if it worked.
Thanks
You can also download the manual here:
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Hope this helps
