20 Most Recent Lenovo Yoga Ultrabook 2-in-1 11.6" Touch-Screen Laptop - 4GB Memory - 128GB Solid State Drive Questions & Answers
if you have admin access, use control panel > users
Lenovo Yoga... | Answered on Apr 15, 2016
Infamous windows problems. You will have to hold power button down until pc shuts off. Cross your fingers and hope it will still load windows. If not, you will need to repair the mbr
Lenovo Yoga... | Answered on Sep 21, 2015
Is this a Android OS Tablet? If so you pull down the top menu hit the gear and click on wifi.
Lenovo Yoga... | Answered on May 26, 2015
If the machine actually turns off, you may need a new battery. Be sure you have a recent backup of your data, in case it's a bigger problem.
Lenovo Yoga... | Answered on Jul 27, 2014
I'm thinking that is the symbol for your internet browser home page. There is a button/key which opens your browser on your home page. That light may never go out - if it's just an indicator of the button/key function. Read your keyboard owner's manual.
Lenovo Computers... | Answered on Oct 03, 2019
For wireless, you will need to know how to select the right input source on your TV [wireless, bluetooth?]. You may then have to tell your laptop to activate wireless video output. Read your owner's manual for BOTH devices.
In my limited experience all IBM compatible computers and that is nearly all of them, work in just about the same way. Faced with your problem I would begin by getting into the bios and changing the boot order.
Access the bios during the start of the startup as directed in one of the first few screens - it all happens so fast the computer might have to be restarted several times by pressing the Alt, Ctrl and Del buttons together. Access the bios by pressing the Del, F8 or whatever at the critical time.
Once into the bios go to the page dealing with the boot order and rearrange them so the dvd/cd drive is first in the order and then save the change and exit; then put the Windows system disc in the drive and close the drawer and very quickly restart the computer.
If all is good an onscreen message should appear, Boot from disc? or similar...
Lenovo Computers... | Answered on Sep 11, 2019
you will need to open the laptop to fix this..
inside in laptop is a small c-mos battery, this needs needs to disconnected for about 10 minutes with the main battery disconnected and not plugged in.
replace the battery and the back of the laptop, and boot it up.
after unplugging the battery and mains press power button to release any power left in the system then take the battery out or replace, but this has worked for me 100%
Lenovo Computers... | Answered on Sep 10, 2019
Try changing the resolution while display 2 is plugged in and active. You can also try changing Display 1 resolution (even if its your main screen)
Lenovo Computers... | Answered on Sep 06, 2019
Find out what is causing the alarm (battery) and turn it off in the menu of that category. You can also try look in the BIOS (press F1 during boot)
Hi Schae, so you say you can have a conflict in the BIOS or Microprocessor
I suggest you look for a technician specialized in Lenovo
Greetings Franco Dosil
Hola Schae, por lo que comentasm uedes tener un conflicton en la BIOS o el MicroProcesador
Te sugiero busques un tecnico especializado en Lenovo
Saludos Franco Dosil
Lenovo Computers... | Answered on Sep 05, 2019
Hard Reset
1-Unplug the device and power off by holding the power button down
Wait 5 seconds, then
2- hold down both the volume up and power buttons (volume up is the side of the long button that is closest to the power button), until you see a screen with “Select Boot Mode” text on it. When you see that, release both buttons.
3-Press the volume up button to move the arrow until it is pointing at the “Recovery Mode” option, then press the volume down button to select it.
4-The “android” logo should appear for a few seconds, then you should be in the “Android system recovery” menu.
5-Use the volume up / down buttons to highlight the “wipe data/factory reset” option, then press the power button to select it.
6-Use the volume up / down buttons to highlight the “Yes — delete all user data” option, then press the power button to select it.
7-Once that has completed, you should be returned to the “Android system recovery” menu. Make sure the top option, “reboot system now”, is selected, then press the power button to select it.
8-The device should reboot and display the “android” logo, followed by the swirling coloured dots. You can then plug the device back in and wait for it to boot up. This will take a long time (up to around 5 minutes).
9-Once the device has booted back into the app, you should be able to set up the wifi, log in with your credentials and re-download your property data.
Lenovo Computers... | Answered on Aug 18, 2019
I have gotten over this problem in the past....
I was locked out a while but they will eventually reset it for you if you keep at it.....
Or perhaps you can remember the silly password you thought you would be able to remember...
A good option might be to start a new one but then again I know I avoided this answer....
Be wary on your way a lot of scammers out there will claim they can help you for $10 or $45 but Google won't charge you to reset your password for you.
Code 43 Error Message
The Code 43 error is one of several Device Manager error codes. The Code 43 error will almost always display in the following way:
"Windows has stopped this device because it has reported problems. (Code 43)"
Details on Device Manager error codes like Code 43 are available in the Device Status area in the device's properties: How To View a Device's Status in Device Manager.
Cause of the Code 43 Error
A Code 43 error is generated when Device Manager stops a hardware device because the hardware reported to Windows that it's having some kind of unspecified problem.
This extremely generic message could mean there's a true hardware issue or it could simply mean that there's a driver problem that Windows isn't seeing as such but that the hardware is being affected by.
Error Code 43 Troubleshooting
Restart your computer if you haven't done so already.
There is always the chance that the error Code 43 you're seeing on a device was caused by some temporary problem with the hardware. If so, a restart of your computer might fix the Code 43 error.
Note: Some users have also reported that powering off their computer completely (not just a reset) and then turning it back on has corrected their Code 43 issue, especially if it exists on a USB device. In the case of a laptop, turn it off and remove the battery, wait a few minutes, and then put the battery back in and start the computer.
Did you install a device or make a change in Device Manager just before the Code 43 error appeared? If so, it's very possible that the change you made caused the Code 43 error.
Undo the change if you can, restart your PC, and then check again for the Code 43 error.
Depending on the changes you made, some solutions might include:
Lenovo Computers... | Answered on Aug 09, 2019
If this is Windows you possibly have the wrong language set for your keyboard or the font doesn't have one. If you don't want to mess with your settings there 2 ways (possibly more) one is with the cursor where you want the ~ put keypad into numeric, press and hold the alt key type 0126 on the keypad let go the alt key
or
run charmap which is part of Windows highlight the ~ (about 4 lines down in Arial) press select then press copy and past it as required.
I hope this helps
Lenovo Computers... | Answered on Jul 12, 2019
once you insert the dvd in your laptop,it should asking you what to do in a box.You can choose to play the media and etc.If there is no box pop up,you can try open media player like cyberlink dvd or vlc player, go to file >open media from your dvd player.
Lenovo Computers... | Answered on Jul 05, 2019
Lenovo Yoga Ultrabook 2-in-1 11.6" Touch-Screen Laptop - 4GB Memory - 128GB Solid State Drive Logo
5 questions posted
Top Lenovo Computers & Internet Experts
Alun Cox
Ekse
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Lenovo Computers & Internet
Most Popular Question
asked me wanted restart toupdate pushed
  • Computers & Internet
