20 Most Recent
Nabi 2 Disney Edition Tablet Questions & Answers
What charger to buy as original charger lost?
Go to a shop that sells the tablet and ask to see one, take note of the charger and your good to go. Otherwise go online to Amazon etc. They are 5v 2A and come as USB or wall charge. They are everywhere online for a few bucks.
How to install rom on Onn 100011886 tablet go edition.
"rom"? What exactly are you trying to do? Are you referring to ROM as part of the tablet's memory? If yes, you probably will not be able to do it. ROM is a memory chip built onto the circuit board itself inside the tablet. You would need to completely dismantle the tablet to do it. Most tablets are not built to be taken apart for repairs.
4/13/2024 11:56:23 PM •
Tablets &...
Answered
on Apr 13, 2024
The android process in my smart eurostar tv. screen has stopped - how can i fix this problem
eurostar tv problem fix boot issue remove tv from power outlet hold down the power button and volume less button (negetive button) to boot make it boot in usb or auto reset from default software if it does not work then you need to download the correct motherboard firmware or software and format the usb fat32 and copy into it firmware files are avalable below my button did not work so removed firmware you need a telegram account can be downloaded from the link below https://gofile.io/d/M98jbz ( if this link not working then download from telegram account this is for eurostar 32 inch tv ) original link from telegram here https://dipelectronicslab.com/eurostar-t32sled-a14-update-software/ other webiste wheich helped me https://www.kazmielecom.com/ Try the key combination if inverted screen and colour https://www.youtube.com/watch?v=pZsGDgD6JQQ if the service mode does not come then use the command when the input selection menu is open and using the remote the following command menu 1147 menu 8896 menu 2580 source and 2580 source and 308(this worked for me it worked when i was after reset i selected inside tv then i open source menu in cvbs1) source and 208 search youtube if you are still not able to open there are videos where people show menu and number in source option 1) in the service menu if your screen a)if inverted screen issue go to panel settings LVDS mirror mode if on then off it (if off then on it) b)if clour is inverted LVDS map change it to next option (if vesa change to jeda) there is any other issue this both website hav tutorial for any other isssue
1/18/2024 5:25:00 PM •
Tablets &...
Answered
on Jan 18, 2024
